Old Feb 02, 2005, 11:40 PM
boomerace is offline
Find More Posts by boomerace
Been There! Done That!
boomerace's Avatar
Eugene, Oregon, United States
Joined Sep 2001
Total Slow Stick Kit
FYI www.allerc.com just added a Slow Stick Total Kit to their website with savings on the combo. I notice Dave also allows some options. Finally you can get everything you need to build and fly a Slow Stick in one order and get some choices of Radios ETC. Check it out you new SS builders. Been trying to convince GWS to do this since the SS came out!
boomer
www.boomerseflight.com
boomerace is offline Find More Posts by boomerace
Old Feb 02, 2005, 11:42 PM
boomerace's Avatar
Joined Sep 2001
Originally Posted by Clayton76
Greetings again. Flying is going great; well I guess it is always going great when you come home with nothing broken. Question: now I suppose this is a charactoristic of the plane, but it seems to be sluggish with left and right rudder. I have modified the control arm, drilled hole closer to fin, and I am all the way out on the servo, so I think I have enough throw (through ?) I can bank into a turn well, but pulling out seems to take longer then getting in. What should I expect?
-Clayton
You sure you aren't nose heavy. Double check your CG!
boomer
Old Feb 03, 2005, 01:43 PM
mohillbilly is offline
Find More Posts by mohillbilly
Yep I got another one.
mohillbilly's Avatar
Springfield, Mo.
Joined Jan 2005
Ok I'm sick of this crap need a cheap METAL gear box. I barly nosed in today dur to grass, no broke prop but smashed the gear case. Tried one I glued and it got about 30 FT the fell off. I saw one but it was over 30 bucks. anyone make there own?
mohillbilly is offline Find More Posts by mohillbilly
Old Feb 03, 2005, 01:54 PM
Ron H is online now
Find More Posts by Ron H
Night flying
Ron H's Avatar
Bishopville S.C.
Joined May 2003
Stick with the GWS box. A screw through the side will hold it on. Replacing it with a stronger box merely means a broken motor or bent fuse next time. If something must break, It's a good thing that it is a cheap part.
Ron H is online now Find More Posts by Ron H
Old Feb 03, 2005, 06:26 PM
flatfenderman is offline
Find More Posts by flatfenderman
flatfenderman's Avatar
Florence Arizona
Joined Dec 2004
Durn Arizona wind!
I got a little $20 Vivitar digital from Walmart and set it up with a servo on my landing gear Ch5. I'm dying to fly it but the wind has been 30 mph+ all week As soon as I do I'll post the pics and some of the camera if anyone is interested in a cheap SS AP set up...
Flatty
flatfenderman is offline Find More Posts by flatfenderman
Old Feb 03, 2005, 06:59 PM
kc8tad is offline
Find More Posts by kc8tad
Zanesville, Ohio
Joined Jan 2004
SS Almost Done.. i have a couple (more) questions
Hello all.. the SS is almost done but I notice that the tail wing just isnt level and straight (nothing ever is that i assemble! LOL) will this be a really bad problem? LOL..
I need to also get some information on putting the main wings and parts on the thing.. like measurements and "where" they should go in relation to the center of gravity.
Also i need some information on putting these Deans Micro Plugs on my LiPo battery...i was suggested to get 2 packs and change the ends on the charger and the ends on the battery... (the batt has no ends as it sits)
Heres a pic of what i have:
Any info would be GREATLY appreciated!
Thanks guys!
-R-
kc8tad is offline Find More Posts by kc8tad
Old Feb 04, 2005, 01:51 AM
Clayton76 is offline
Find More Posts by Clayton76
Sacaramento, CA
Joined Jan 2005
Boomer, when I balance the plane on my stand, it is almost flat, maybe 2-3 inches from horizontal. Would that have a large effect on handling? Should I be checking it after every hard landing/crash?
-C
Clayton76 is offline Find More Posts by Clayton76
Old Feb 04, 2005, 05:38 AM
Vanning is offline
Find More Posts by Vanning
WAA pilot #21
Vanning's Avatar
Princeton NJ
Joined Dec 2003
THose are the wrong plugs - you wanted the deans Ultras....but dont let that stop you. They'll work for the time being. Just order the ultras soon and replace when convenient.
Those are polarized plugs, meaning they cant be plugged in backwards. Note theres one pin on each and one socket. You'll need to be doubly sure that when everything is finished, your red wire goes to red and black goes to black.
Tip: you must slip the heat shrink tube onto the wire BEFORE you solder, otherwise you cant get it on. I like to hold the tubing onto the wire several inches back from the joint with a piece of scotch tape so it doesnt fall into the heated area and shrink up before you want it to. After the joint has cooled some, remove the tape, and slip the tubing over the joint. Hold a match or lighter several inches below to shrink it up.
Its extremely important to NOT accidentally short across the battery leads when your soldering. This is a lesson you really almost hafta learn the hard way, but do take precautions. Its wise to do one wire completely, including heatshrink tubing, while the second wire is taped up out of the way.
As for the tail, you need to determine if its the tail, wing landing gear or fuse thats crooked. Place two soda cans on a flat table. Remove landing gear. Rest the fuse on the soda cans (front and rear of the fuse) so you know the fuse is level & square with the ground. If the fuse is twisted, one corner will be a little high. If the tail is level, then likely your landing gear isnt bent exactly right - dont worry about that at all. If one wingtip is higher than the other, see if you can just shim the opposite wingseat to even em up.
If the fuse is level & the tail is not, then drive a wedge (toothpick, balsa, folded cardboard ...get creative) on the high-side between the tail & fuse.
Vanning is offline Find More Posts by Vanning
Old Feb 04, 2005, 10:39 AM
millerhill is offline
Find More Posts by millerhill
millerhill's Avatar
USA, VT, Brandon
Joined Aug 2004
fix
I fixed one with epoxy and a wire tie to hold it all together. It's still in one piece.
millerhill is offline Find More Posts by millerhill
Old Feb 04, 2005, 11:06 AM
AlexAlex is offline
Find More Posts by AlexAlex
uhh registered user
California
Joined Jan 2005
Well any notes or warnings before a start construction of my slowstick?
-Alex
AlexAlex is offline Find More Posts by AlexAlex
Old Feb 04, 2005, 11:57 AM
boomerace's Avatar
Joined Sep 2001
-C
As long as it balances 4-1/8" back from the front of the wing it should be OK also check for fuse bent up and left looking from the back. Assume you don't have a thrust mod installed to point the motor 3 degrees down and right looking from the back?
boomer
Old Feb 04, 2005, 12:31 PM
millerhill's Avatar
USA, VT, Brandon
Joined Aug 2004
-Alex
Create a seperate bank account hidden from your wife....
Old Feb 04, 2005, 04:07 PM
Florence Arizona
Joined Dec 2004
From Vermont to Arizona, this riens true!
Old Feb 04, 2005, 06:03 PM
JMBRAD is offline
Find More Posts by JMBRAD
Jody Bradshaw
JMBRAD's Avatar
Salisbury, North Carolina, United States
Joined Feb 2004
Help!!! Plane stuck 50' up in tree.
I shouldn't have been flying this late. It was getting dark and I hadn't flown in over 3 weeks. I had already drained a partially charged battery and said, "OK I can fly some more." In the failing light I lost my orientation and stalled my SS about 5 feet over an Elm tree. It is in my yard and I still have some power left on the battery and can see the LED on my ESC blinking, but don't have enough torque to spin the prop. It is caught in some twigs right at the top of the tree. I don't have the strength to throw anything that high to hit it and my aim is not good enough to shoot the twigs out from under it with my .22. I even pulled out the .35 Rem and my 12 guage with OO buck and still couldn't chew the limbs up enough to drop the plane. I am out of daylight and ideas. I can't afford to loose everything to the elements by the time the wind blows it down.
Does anyone have any ideas besides renting a cherry picker.
Jody
JMBRAD is offline Find More Posts by JMBRAD
Old Feb 04, 2005, 07:23 PM
Popsflyer is offline
Find More Posts by Popsflyer
Oldie but goodie
Popsflyer's Avatar
United States, CA, Orange
Joined Jun 2003
One quart plastic jug filled with dirt or sand. Tie a strong twine or thin rope to handle. You should be able to throw it high enough to grab the branches, then just tug away to shake the plane down.
Popsflyer is offline Find More Posts by Popsflyer
The Ultimate Slow Stick Help Thread - Part 6 Ron H Beginner Training Area (Aircraft-Electric) 544 Feb 16, 2005 09:59 AM
The Ultimate Slow Stick Help Thread - Part 5 boomerace Beginner Training Area (Aircraft-Electric) 793 Sep 13, 2004 08:01 AM
The Ultimate Slow Stick Help Thread - Part 4 Martin Hunter Beginner Training Area (Aircraft-Electric) 824 May 31, 2004 01:00 AM
The Ultimate Slow Stick Help Thread - Part 3 Martin Hunter Beginner Training Area (Aircraft-Electric) 639 Apr 11, 2004 11:17 AM
The Ultimate Slow Stick Help Thread - Part 2 Martin Hunter Beginner Training Area (Aircraft-Electric) 565 Feb 17, 2004 10:35 AM
