Old Apr 26, 2005, 11:26 AM
Daniel G is offline
Find More Posts by Daniel G
It's been a while.
Daniel G's Avatar
Irvine, CA
Joined Jan 2005
Originally Posted by jack620
which prop and how many cells? I assume no gearbox required?
10x7 prop and a 3x1gearbox on 3cell lipo.
Daniel G is offline Find More Posts by Daniel G
Old Apr 26, 2005, 09:15 PM
Popsflyer is offline
Find More Posts by Popsflyer
Oldie but goodie
Popsflyer's Avatar
United States, CA, Orange
Joined Jun 2003
Originally Posted by park-n-fly
I forgot to ask you, popsracer...did you do any modifying of the airframe or wing for your setup? Or did you just go stock with most everything but the motorplant?
Thanks to the recommendations here in the thread, I decided to mod mine a little from the get-go.
1) Balsa square inside fuselage.
2) Used 2" wide fibre reinforced packaging tape over the fiberglass rods on the wing. Added another strip at the center joint. Then a strip of 2" wide clear tape on the bottom of the wing from tip to tip.
3) Lastly I reinforced the landing gear to keep them from bending.
With the wing reinforcement, I can do consecutive loops and do not see any wing flexing at all.
Popsflyer is offline Find More Posts by Popsflyer
Old Apr 26, 2005, 10:25 PM
park-n-fly is offline
Find More Posts by park-n-fly
better than park-n-work
park-n-fly's Avatar
California
Joined Jan 2005
Any chance of you posting a few pics of your wings, popsracer? If not, no worries.
park-n-fly is offline Find More Posts by park-n-fly
Old Apr 27, 2005, 01:44 AM
Daniel G is offline
It's been a while.
Daniel G's Avatar
Irvine, CA
Joined Jan 2005
I got my Slowstick from Balsa products(the slope version) and it came with carbon fiber rods instead of the fiberglass ones that everyone else seems to get.
Did I luck out or do all Slowsticks come with carbon fiber now?
Old Apr 27, 2005, 03:33 AM
boomerace is offline
Find More Posts by boomerace
Been There! Done That!
boomerace's Avatar
Eugene, Oregon, United States
Joined Sep 2001
I think you will find they are black fiberglass. I have some fiberglass rods that are white and some are black. The fiberglass I use for IFO Landing gears as it will flex more than the carbon without breakage.
boomer
boomerace is offline Find More Posts by boomerace
Old Apr 27, 2005, 08:03 AM
omba is offline
Find More Posts by omba
Space Cowboy
omba's Avatar
Flagler Beach, FL
Joined Aug 2004
Gearbox Guru?
Hello again.
I've asked this once before, but I am not sure that I asked things properly. (It helps to ask clear questions, doesn't it?) I have "attempted" putting together 2 other electrics with gearboxes. Both times the gears seemed to slip, strip, or die. I really want to put together a Slow Stick that works in 10mph winds. So here goes:
1. Is there a "gourmet" motor/gearbox combo that I should consider?
2. Is there a motor/prop combo to use that would completely eliminate the gearbox without altering the SS character?
I appreciate any help you might offer. I picked up my kit from the LHS, and I just noticed it is the EPS-400C version. This a problem? Should I exchange. I really don't mind putting the power sytem in a drawer and purchasing a whole new setup. Is the plane the same for all versions except for the power system? Thanks again. I'm just a bit lost. Well ... I might be more lost than I think!
Peter
omba is offline Find More Posts by omba
Old Apr 27, 2005, 10:18 AM
JWarren is offline
Find More Posts by JWarren
Just one more plane!
JWarren's Avatar
Port Saint Lucie, Florida, United States
Joined Aug 2004
It's time to create part 8.
Boomer, would you like to do the honors?
John
JWarren is offline Find More Posts by JWarren
Old Apr 27, 2005, 01:04 PM
boomerace's Avatar
Joined Sep 2001
John
Done!
New thread at
http://www.rcgroups.com/forums/showthread.php?t=364276
boomer
PLEASE POST TO NEW THREAD!!!!!
John,
would you please close this one................
The Ultimate Slow Stick Help Thread - Part 6 Ron H Beginner Training Area (Aircraft-Electric) 544 Feb 16, 2005 10:59 AM
The Ultimate Slow Stick Help Thread - Part 5 boomerace Beginner Training Area (Aircraft-Electric) 793 Sep 13, 2004 09:01 AM
The Ultimate Slow Stick Help Thread - Part 4 Martin Hunter Beginner Training Area (Aircraft-Electric) 824 May 31, 2004 02:00 AM
The Ultimate Slow Stick Help Thread - Part 3 Martin Hunter Beginner Training Area (Aircraft-Electric) 639 Apr 11, 2004 12:17 PM
The Ultimate Slow Stick Help Thread - Part 2 Martin Hunter Beginner Training Area (Aircraft-Electric) 565 Feb 17, 2004 11:35 AM
