Old Jan 22, 2005, 10:19 PM
boomerace is offline
Find More Posts by boomerace
Been There! Done That!
boomerace's Avatar
Eugene, Oregon, United States
Joined Sep 2001
Originally Posted by jswjimmy
i have a spruce stick fuse so what about something the clamps or screws on.
I have no idea!
boomer
www.boomerseflight.com
boomerace is offline Find More Posts by boomerace
Old Jan 22, 2005, 10:45 PM
Block is offline
Find More Posts by Block
Syracuse, NY (USA)
Joined Dec 2004
I've been thinking of a better gear as well. How about cutting a strip of alumnium and bending it so it fits over the top of your sitck? One screw or bolt going through the top would hold it I think. You can also buy metal landing gear online (I tried at attach a photo - the link is
http://www2.towerhobbies.com/cgi-bin...?&I=LXFBC5&P=7).
You'd have to drill a hole in it and run an axle across or make a 90 degree bend in some wire and glue it near the bottom for the axle. I'm surprised everyone uses wire for the landing gear. Not sure if my attachment made it.
These are cool, but perhaps they are too short or too heavy?
http://www.toddsmodels.com/Wheels/landinggear.htm
Block is offline Find More Posts by Block
Old Jan 22, 2005, 10:48 PM
Block is offline
Syracuse, NY (USA)
Joined Dec 2004
Too nice for a slow stick!
http://www.nesail.com/detail.php?productID=2974
Old Jan 23, 2005, 12:12 AM
loc nar is offline
Find More Posts by loc nar
loc nar's Avatar
Joined Jan 2005
boomer, what batteries are you using with that balsa products motor?
thanks
loc nar is offline Find More Posts by loc nar
Old Jan 23, 2005, 12:19 AM
boomerace's Avatar
Joined Sep 2001
thanks
I was using a 3S1P iRate 2200 for the video as I was wanting to load the plane. However my 1500 3S1P iRate would fly it just fine. Of course the 2200 at the 55% throttle used for most of the Video would fly it longer that I would be able to without getting a sore neck!
boomer
Old Jan 23, 2005, 01:04 AM
Clayton76 is offline
Find More Posts by Clayton76
Sacaramento, CA
Joined Jan 2005
Where do you guys find these cool websites?
C-
Clayton76 is offline Find More Posts by Clayton76
Old Jan 23, 2005, 01:28 AM
Spy king is offline
Find More Posts by Spy king
Just "PLANE" crazy
Spy king's Avatar
Chennai, India
Joined Dec 2003
Check out this Pic.. It looks like the Al one 4rm tower..
http://www.rcgroups.com/forums/showp...17&postcount=6
Spy king is offline Find More Posts by Spy king
Old Jan 23, 2005, 10:23 AM
lehma is offline
Find More Posts by lehma
lehma's Avatar
USA, TX, Lewisville
Joined Nov 2004
I was racking my brain for this for a while also.
I bought an off the shelf aluminium LG designed for electrics, but couldn't figure a way of connecting it to the plane. I went through a number of methods but the best by far was just using another piece of aluminium, drilling two holes on the LG, two holes on the new piece of aluminium and sandwiching the spruce in between. Two #4 bolts either side snug up to the stick.
Picture can show better. This didn't work well on the stock SS because every landing caused the aluminium to bend...
lehma is offline Find More Posts by lehma
Old Jan 23, 2005, 11:29 AM
flatfenderman is offline
Find More Posts by flatfenderman
flatfenderman's Avatar
Florence Arizona
Joined Dec 2004
Where are you guys getting your spruce sticks? Or are you cutting your own? What is the benifit?
Flatty
flatfenderman is offline Find More Posts by flatfenderman
Old Jan 23, 2005, 11:31 AM
lehma is offline
lehma's Avatar
USA, TX, Lewisville
Joined Nov 2004
I get mine from my local hobby shop. Lowes and Home Depot didn't have any when I last looked.
Old Jan 23, 2005, 01:03 PM
boomerace's Avatar
Joined Sep 2001
Spruce.... well they are heavier than the stock aluminum and they splinter and shatter on impact instead of bending!
boomer
Old Jan 23, 2005, 01:11 PM
lehma is offline
lehma's Avatar
USA, TX, Lewisville
Joined Nov 2004
Maybe on a very hard landing. If you have a small ding with the aluminium (I have had many) then it has no give and creases. The spruce has a little give in it.
I have had more luck with the spruce (now I can fly) than with the aluminium...
Old Jan 23, 2005, 03:44 PM
Florence Arizona
Joined Dec 2004
boomer
Boomer, I kinked my aluminum fuse and broke it when I tried to straiten it. What do you think about the balsa inside the alum trick?
Flatty
Old Jan 23, 2005, 04:16 PM
boomerace's Avatar
Joined Sep 2001
Flatty
I run the fuse end of my thrust mod stick back to just past the front wing mount and epoxy in place. Haven't had a kinking problem since!
boomer
Old Jan 23, 2005, 07:12 PM
lehma is offline
lehma's Avatar
USA, TX, Lewisville
Joined Nov 2004
I used to have a weight problem (on the plane) with the stock motor when I had a (not balsa) 3/8 dowel inside it.
I guess now with the HiMax motor I can go back to the aluminium rod with dowel. Still, flew the plane today with a 2025-4266, 8cell NiCd and 12x8 prop and it was great. Cruising at half throttle, take off in a couple of feet with a 45deg climb! A 2S LiPo didn't seem to have enough Oomph for me so I went back to the old and trusty packs.
Andy
The Ultimate Slow Stick Help Thread - Part 6 Ron H Beginner Training Area (Aircraft-Electric) 544 Feb 16, 2005 10:59 AM
The Ultimate Slow Stick Help Thread - Part 5 boomerace Beginner Training Area (Aircraft-Electric) 793 Sep 13, 2004 09:01 AM
The Ultimate Slow Stick Help Thread - Part 4 Martin Hunter Beginner Training Area (Aircraft-Electric) 824 May 31, 2004 02:00 AM
The Ultimate Slow Stick Help Thread - Part 3 Martin Hunter Beginner Training Area (Aircraft-Electric) 639 Apr 11, 2004 12:17 PM
The Ultimate Slow Stick Help Thread - Part 2 Martin Hunter Beginner Training Area (Aircraft-Electric) 565 Feb 17, 2004 11:35 AM
