Go Back   RC Groups > Aircraft - Electric - Airplanes > Beginner Training Area (Aircraft-Electric)
Closed Thread Post New Thread  Previous Thread Next Thread
Old Jan 21, 2005, 05:56 PM   #1
Been There! Done That!
Bronze Member
boomerace's Avatar
The Ultimate Slow Stick Help Thread Part 7
OK Time for a new Thread
Links to previous threads
Part 1
http://www.rcgroups.com/forums/show...threadid=122951
Part 2
http://www.rcgroups.com/forums/show...315#post1502315
Part 3
http://www.rcgroups.com/forums/show...861#post1841861
Part 4
http://www.rcgroups.com/forums/showthread.php?t=219399
Part 5
http://www.rcgroups.com/forums/showthread.php?t=235707
Part 6
http://www.rcgroups.com/forums/showthread.php?t=274907
boomer
www.boomerseflight.com
boomerace is offline Find More Posts by boomerace
Old Jan 21, 2005, 08:07 PM   #2
Bronze Member
boomerace's Avatar
Just posted the Video of the SS with BP-21 (Balsa Products) Outrunner on my website. Beautiful combo! It would maintain altitude at 55% throttle setting and keep in mind that's at a "lead sled" AUW of 24.3oz! I didn't like the stick mount setup they furnished so revised the mount to allow easy removal of the motor for maintenance and prop shaft replacement if it becomes necessary. Reamed out the mounting holes at an angle to allow angling of the screws to clear the motor bell. The pics show the result. The 8 X 4 HD prop presents no deterioration in flight ability!
boomer
  • Name: Modified Mount Bottom.jpg
  • Name: Modified Mount Front.jpg
  • Name: Motor install 1.jpg
  • Name: Motor Install 2.jpg
  • Name: Motor on SS.jpg
Old Jan 21, 2005, 08:13 PM   #3
Cross Into The Blue
migdestroyer999's Avatar
Cool!!! I got one of their Feigao motors with the ESC for $65. WIth a weight of 15oz and 23.7 oz of thrust, the plane should hover at about 1/2 to 3/4 throttle! I also made some other mods including homemade Wheel Covers that look great! and an inverted pair of Landing Gear for inverted landings!!!
migdestroyer999 is offline Find More Posts by migdestroyer999
Old Jan 21, 2005, 09:26 PM   #4
flatfenderman's Avatar
Wow! Boomer that thing flys great! The verticle take off and the snap turns really surprised me!I bet it'll pull my tank around good too. I'm gonna order one, thanks for being my guinia pig
Flatty
flatfenderman is offline Find More Posts by flatfenderman
Old Jan 21, 2005, 11:19 PM   #5
Where did you pick up that combo?
cyphe2001 is offline Find More Posts by cyphe2001
Old Jan 21, 2005, 11:25 PM   #6
Just "PLANE" crazy
Spy king's Avatar
Send a message via AIM to Spy king Send a message via MSN to Spy king Send a message via Yahoo to Spy king
www.balsapr.com or directly http://www.balsapr.com/catalog/motor...ductId=V934359
-AShwin
Spy king is offline Find More Posts by Spy king
Old Jan 22, 2005, 05:56 AM   #7
WAA pilot #21
Vanning's Avatar
Thanks Boomer! Its amazing how small those things are.
Anybody try a GoBrushless GBX motor? Im thinking of ordering a double-stator kit to fiddle with.
Vanning is offline Find More Posts by Vanning
Old Jan 22, 2005, 12:23 PM   #8
Ron H's Avatar
Nice video boomer. That motor must be running at high rpm to put out that much power with an 8x4, but I could barely hear it.
For you guys looking at the Fiegao combos, I suggest the 22t motor. Using 7 cell packs or 2s lipos and a 1260 prop w/d gear, I get 20oz. thrust at just under the 10 amp limit. The motor doesn't get hot so I suspect it could be pushed a bit harder, but I use the 10 amp ESC, so I'll leave it alone. It will also fly nicely with 6 cell packs, even the GWS ones.
If I switch to 3s and a 1147, I get 27 oz. thrust at @ 10 amps.
Over 100 flights (mostly with 7 or 8 cells) and still going strong. I have gone through a few gearboxes though.
Got a few videos to compare 2s to 3s. The Steelhead clips are both 2s. The other two are 3s. Weight is 18.5 oz. using 2s2p 720's, and 18 using 3s 1200's.
Not very good qaulity, but they do demonstrate the power, and the flyability of the wing. They don't show the speed very well though, it looks like slow motion filming.
http://www.rcgroups.com/gallery/show...0&ppuser=17312
Vanning, I've got one waiting for me to assemble but I don't know when I'll get to it. But I tried a single in a gearbox and got 21oz thrust from it! I think 20 oz. thrust is average for a double using a 9-10" prop, so it should work great. I'm thinking a hot wound double in a gb should produce 30oz.+ with plenty of speed for the SS.
Ron H is offline Find More Posts by Ron H
Old Jan 22, 2005, 04:56 PM   #9
Whatever happens..Happens
jswjimmy's Avatar
landing gear for twin stick
i need landing gear for my new slow stick its 32oz with out camera 38oz with camera. what should i make.
this was my first attempt
http://www.jswjimmy.com/rcgroupsforu...k/IMAG0044.JPG
http://www.jswjimmy.com/rcgroupsforu...k/IMAG0045.JPG
it was strong but it just twisted when i turned.
here is the whole plane
http://www.jswjimmy.com/rcgroupsforu...k/IMAG0046.JPG
http://www.jswjimmy.com/rcgroupsforu...k/IMAG0047.JPG
http://www.jswjimmy.com/rcgroupsforu...k/IMAG0048.JPG
http://www.jswjimmy.com/rcgroupsforu...k/IMAG0049.JPG
jswjimmy is offline Find More Posts by jswjimmy
Old Jan 22, 2005, 05:48 PM   #10
Bronze Member
boomerace's Avatar
Originally Posted by jswjimmy
Bend it out of 1/8" Music Wire and CA and wrap it to the fuse with braided fishing line at least 20 lb. test... No monofiliment!
boomer
www.boomerseflight.com!
  • Name: SS LG.jpg
Old Jan 22, 2005, 06:07 PM   #11
jswjimmy's Avatar
would you happen to know of anything less permanent.
Old Jan 22, 2005, 07:10 PM   #12
Bronze Member
boomerace's Avatar
Not that works. This can be removed fairly easy with a cutoff disk in a Dremel by cutting the threads and glue each side and the rest just peels off.
boomer
Old Jan 22, 2005, 08:40 PM   #13
Need some advice guys: Flying around today and I wished I had some more power to get me out of trouble. Using a stock SS with a 300 and a D gear spinning a 1260 and a 7 cell pack. What could I change to get a little more thrust? Or should I just learn not to stall?
C-
Clayton76 is offline Find More Posts by Clayton76
Old Jan 22, 2005, 10:12 PM   #14
jswjimmy's Avatar
C-
a 350c-c and 1047 prop should give you more thrust but flight times will be shortened.
300c-d prop:EP1260 volts:8.4 amps:8.5 thrust(g):427 watts to prop:71.40
350c-c prop:EP1047 volts:8.4 amps:10.3 thrust(g):470 watts to prop:86.52
Old Jan 22, 2005, 10:14 PM   #15
jswjimmy's Avatar
boomer
i have a spruce stick fuse so what about something the clamps or screws on.
The Ultimate Slow Stick Help Thread - Part 6 Ron H Beginner Training Area (Aircraft-Electric) 544 Feb 16, 2005 10:59 AM
The Ultimate Slow Stick Help Thread - Part 5 boomerace Beginner Training Area (Aircraft-Electric) 793 Sep 13, 2004 09:01 AM
The Ultimate Slow Stick Help Thread - Part 4 Martin Hunter Beginner Training Area (Aircraft-Electric) 824 May 31, 2004 02:00 AM
The Ultimate Slow Stick Help Thread - Part 3 Martin Hunter Beginner Training Area (Aircraft-Electric) 639 Apr 11, 2004 12:17 PM
The Ultimate Slow Stick Help Thread - Part 2 Martin Hunter Beginner Training Area (Aircraft-Electric) 565 Feb 17, 2004 11:35 AM
Congratulations SimpleM!
