Old Jan 21, 2005, 12:07 PM
Tumbler is online now
Find More Posts by Tumbler
Tumbler's Avatar
United States, NJ, Vineland
Joined Feb 2003
Easy way to make a quick, good looking jet
Here is a way for you guys to build a quick little jet. I don't have plans, but it is so simple you don't need them. I just took a pic from the BVMJETS.com web site and blew up the top view to 300%, then tap[ed the pages together and kept doing that to the size I wanted. I made an 18" using a GWS 50 fan and fegio 5800 motor and now last night(took 6 hrs) made the 23 inch version using blue foam and a gws 55 fan and 4200 kv motor.
just cut the whole bottom out,glue on two fuse sides, lay three lyaers on top, sand to shape, cut and hinge ailerons, moutn equipment. Thats it!!
Tumbler is online now Find More Posts by Tumbler
Old Jan 21, 2005, 12:08 PM
Tumbler's Avatar
Joined Feb 2003
Blue Foam 23"
Old Jan 21, 2005, 12:14 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
How much did you cut the interior of the fuselage out? Looks great BTW...
Eric B.
AirX is offline Find More Posts by AirX
Old Jan 21, 2005, 12:19 PM
Tumbler's Avatar
Joined Feb 2003
Eric,
Didn't have to ciut anything out...........I layed two sides for the fuse and then layed 3 layers of foam on top just gluing and taping one layer at a time to go around curves, then carve to shape and cut a hatch.
Answer your question or no?
Brian
Old Jan 21, 2005, 12:26 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Hi Brian,
Very good, I thought you might have used the techniques that Jetset uses on his designs of layering and sanding to shape then hollowing to lighten.
Cheers,
Eric B.
Old Jan 21, 2005, 01:55 PM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Very nice, and the price is right!!! I'll bet that it really hauls the coals.
It sort of reminds me of the Matney Models Project-X.
GregG is offline Find More Posts by GregG
Old Jan 21, 2005, 01:59 PM
Tumbler's Avatar
Joined Feb 2003
geez that thing weighs 40ozs!!!!! Mine is 10.7. Going to stronger motor and bigger battery but even then it will only be like 15!!
Old Jan 21, 2005, 02:04 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Brian,
More Pics...
Eric B.
Old Jan 21, 2005, 02:09 PM
Tumbler's Avatar
Joined Feb 2003
havne't put the bottom fuse on yet, but i use the same technique as the top with just enough depth to clear the servos and horns and rond it and put packing tape on it so it slides along the ground and takes off like My Alpha Mig.
jet_jer is offline
Find More Posts by jet_jer
Buffalo Intl, New York, United States
Joined Feb 2002
Brian,
Another nice looking BVM jet. Here is one of his other threads on the bandit:
http://www.rcgroups.com/forums/showthread.php?t=269367
I am trying to get the templates made up into CAD format so we can all have this beauty (bandit). I'm a little new to the cad thing so its slow going.
Jer
jet_jer is offline Find More Posts by jet_jer
Old Jan 21, 2005, 02:10 PM
Tumbler's Avatar
Joined Feb 2003
you can the CG is right where the larger dot are.........it is pretty critical to get it righ on i have found
Old Jan 21, 2005, 02:11 PM
Tumbler's Avatar
Joined Feb 2003
jet jer,
Old Jan 21, 2005, 03:06 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Nice work on the Bandit Tumbler, I know how building and making it pretty can make it not fly. Very nice job.
Eric B.
Old Jan 21, 2005, 04:55 PM
rdeters is offline
Find More Posts by rdeters
United States, IL, Dixon
Joined Mar 2004
Very cool Tumbler! Is that a brushless power set-up?
Ron
rdeters is offline Find More Posts by rdeters
Old Jan 22, 2005, 12:55 PM
keven64 is offline
Find More Posts by keven64
Model Designer
keven64's Avatar
United Kingdom, England, Burnley
Joined Apr 2001
That is minifan powered and will do 130mph on ten cells...
Yours is great, Brian !
Keven.
keven64 is offline Find More Posts by keven64
Question Is there a newby(easy) way to make wheel spats Jagzilla Composites Fabrication 6 Oct 08, 2006 05:13 PM
Discussion good easy way to make a battery door in fff? rumplestilskin Foamies (Scratchbuilt) 12 Sep 02, 2006 01:11 AM
Discussion Easy way to make home made PCB to tinker with brucej Scratchbuilt Indoor and Micro Models 0 Apr 20, 2006 11:00 PM
Quick easy way to make tabs in Autocad 2006?? duhaas88 The Builders Workshop 9 Oct 26, 2005 10:16 PM
Quick EP Looking Good Phoenix-IT Electric Heli Talk 16 Nov 29, 2003 04:21 PM
