Old Jan 21, 2005, 09:57 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Astro Flight 109 Facts or Fiction.
First let me state that I have this charger and think it is great.
Now a few areas of confusion.
Front(?) box flap states that Discharge is automatically terminated at 3 volts per cell.
WRONG
Discharge is a percentage of voltage when pack is connected. If not fully charged pack will be over discharged. Instructions in manual are correct but how many read manual or keep track of it?
Box Front :
Charges 1 to 9 cells
Rate 50 ma to 8 Amps
Chart in manual show approximately 7.5 A for up to 12 cells and 4 amps at 24 cells.
Perhaps the chart should be labeled volts instead of cell.
Mode 1
Dumb mode and charges at whatever rate set.
I have checked mine with both Analog and Digital Amp. meters as well as an Astro Flight Watt meter and mine only charges at 1/2 of the rate set during stage 1.
Charger set at 1 A all meters read 0.5A and Watt meter shows 25 mA in 3 minutes which just happens to be correct for 0.5A not 1.0A.
Link to astrobob's post on same:
http://www.rcgroups.com/forums/showp...3&postcount=38
Charles
Old Jan 21, 2005, 10:28 AM
astrobob is offline
Find More Posts by astrobob
Los Angeles
Joined Oct 2002
in answer to your questions.
1. discharge is to 69% of initial voltage
discharge is designed to measure the capacity of fully charged pack.
the voltage will drop to between 2.8 and 3v per cell and discharge will stop.
if pack is removed and reconnected to measure resting voltage on will
usually see between 3.5 and 3.7 volts. Even if the pack were at 3.7 when
starting dischage the voltage would drop to 2.5v for few seconds then
jump back up to over 3v. if i am going to solder on new connectors
i allways discharge to 3.7 volts first.
2. after over a year of selling these chargers you are the first guy to
actually study the instructions. Congratulations.
yes that chart was copied from the 110 and those were nicads cells
got to fix that on next printing.
3. during model 1 the charger is actually pulsing the battery at a high rate
and a 50% duty cycle. so for the first three minutes the average current
is 1/2 of the set current. we do this to condition the pack before charging
at full current. congratulations you just figured out another of our
secrets but don't tell anyone.
astrobob
astrobob is offline Find More Posts by astrobob
Old Jan 21, 2005, 10:29 AM
GBR2 is offline
Find More Posts by GBR2
Stress Be Gone
GBR2's Avatar
Snohomish, WA
Joined May 2000
You are right about the discharge. I never use it anyway. As to the Mode 1, yes the current is 1/2 the set charge rate and then it ramps up from there to the full rate by Stage 2. Think of it this way, say you were charging a 2000ma pack at 2 amps. You forget to turn the dial down, plug in a 1000ma pack, the charger will say 2 amps at first but due to the way it works, it has just prevented you from over charging the pack at first. Of course, this is all relative as you might have the knob all the way up but at least it is something.
Personally, I wish the firmware was changed so that if the knob was not turned down before starting, the charger would not start till you do so. I don't see why this couldn't be done and would certainly prevent the problem of having the knob not at zero to begin with. I've used my 109 a lot but still forget to dial down the knob numerous times.
GBR2 is offline Find More Posts by GBR2
Old Jan 21, 2005, 10:37 AM
unbalanced prop is offline
Find More Posts by unbalanced prop
unbalanced prop's Avatar
Washington, PA, USA
Joined Aug 2003
astrobob
I am a little confused here. If the knob is set to zero as you suggest, how is the charger "pulsing the battery at a high rate and a 50% duty cycle"? Isn't 50% of nothing still nothing? So Bob..........should the knob be turned to zero when starting a charge or not?
Doug
unbalanced prop is offline Find More Posts by unbalanced prop
Old Jan 21, 2005, 10:42 AM
Southern Pride
starting discharge the voltage would drop to 2.5v for few seconds then
i always discharge to 3.7 volts first.
astrobob
Thanks Bob for confirming my findings. I have tried to get these points across to others in the past but some refuse to believe anything unless it comes from the manufacture and then others refuse to believe anything the manufactures say.
Charles
Old Jan 21, 2005, 10:55 AM
Mark Wood is online now
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Charles
That's when Darwin steps in.
mw
Mark Wood is online now Find More Posts by Mark Wood
Old Jan 21, 2005, 10:56 AM
navkan is offline
Find More Posts by navkan
Ottawa
Joined Feb 2004
I know at least one lipo balancer that states not to use with a pulsed charger such as the 109. does anyone know if this true with all balancers?
navkan is offline Find More Posts by navkan
Old Jan 21, 2005, 11:12 AM
astrobob is offline
Los Angeles
Joined Oct 2002
Doug
I recommed always to set the current to zero when first connecting
pack so that you can observe the pack voltage at rest. that way
you can make an informed decision on how to charge pack.
the turn up voltage slowly and observe voltage. if pack is allready fully
charged no need to charge again. if half full charge at 1.2 C or 2/3 C,
if pack is aroung 3.7 to 3.9 volts it is practically empty so charge at
1C . If pack is at 3.2 volts or less charge a c/10 until pack voltage
reaches 3.7 volts and stays there for 20 seconds after turning current
down. Charging a deeply discharged pack at 1C can cause pack to
puff up and be ruined.
astrobob
Old Jan 21, 2005, 11:19 AM
Washington, PA, USA
Joined Aug 2003
Thanks for setting me straight Bob.
I like getting info straight from the horses mouth.
BTW.............great charger!!
Doug
Old Jan 21, 2005, 01:28 PM
Southern Pride
Doug
astrobob
1.2 C
We all suffer from typos and I am very sure astrobob meant to type 1/2C not
1.2C
Charles
Old Jan 21, 2005, 07:42 PM
Dan Baldwin is offline
Find More Posts by Dan Baldwin
Dan Baldwin's Avatar
United States, CA, Norwalk
Joined Apr 2004
Bob saved me from taking my scope to the field Sunday to confirm that the 109 charges at 50% duty cycle in stage one.
Dan
Dan Baldwin is offline Find More Posts by Dan Baldwin
Old Jan 21, 2005, 10:18 PM
Dave Hederich is offline
Find More Posts by Dave Hederich
Walled Lake, MI, USA
Joined Feb 2000
Yep, that's a good summary of RC Groups' Batteries and Chargers forum.
Dave Hederich is offline Find More Posts by Dave Hederich
Old Jan 22, 2005, 11:27 AM
Washington, PA, USA
Joined Aug 2003
Funny but true Dave.
Doug
Discussion Triton2 or Astro Flight 109 Abrams Batteries and Chargers 12 Feb 04, 2007 01:55 PM
FS Astro Flight 109 Lipoly Charger NIB Bud Morrison Aircraft - Electric - Airplanes (FS/W) 4 May 04, 2004 08:40 PM
WTB Astro Flight 109 LiPo Charger thangd Aircraft - Electric - Airplanes (FS/W) 3 Apr 02, 2004 01:18 PM
astro flight 109 lipoly charger flygilmore Batteries and Chargers 1 Mar 15, 2004 08:46 AM
Question Can Astro Flight 109 charge Li-Ions? Rotary Rocket Batteries and Chargers 8 Jan 12, 2004 09:30 PM
