Mar 12, 2002, 07:55 AM
Stamford, CT
Joined Oct 2000
Arggghhh!
Brian
If you do these conversions you will rapidly come to the conclusion that glow motors have far superior power to weight than electric motors when everything is included in (even the weight of the fuel- often omitted.) However, the mfg of electric motors are not stupid- there's a good reason not to try and come up with a direct comparison. Glow motors use very inefficient props- they are often way too small for the airframe.
Example- take a cheap 40 which is often rated at 1.5 hp or about 1100 watts. Most of these hp ratings are nonsense since they are given at rpms far from where the engines are operated. How many times have glow mfg stated 1.5 hp at 16,000 rpm while the recommended operating limits for the motor are 3,000-12,000? In practical terms- somewhere between 600-800 watts will swing a 10 x 6 prop at 11k-12k rpm- effectively similar to a glow 40. Hence the 40s true output is closer to 1 hp, not 1.5.
Now look at propellor sizes- A typical 40 size airplane has a wingspan of around 4 ft. A prop should be 1/4 to 1/3rd the size of the wingspan (1/4 works well in lots of cases) hence a 12 inch prop. You can swing this size prop with an e- motor on 500 watts, and the additional efficiency will more than make up the power difference between the glow engine and the electric motor.
I've been down this road before. I had a model, and I was convinced that to get it to fly properly, all I needed to do was spin the same prop as was called for on the glow motor version at the same rpm, at the same weight, and I'd have similar performance to glow. Typically what happens is the electric version comes out heavier, and then people whine about the lack of performance of the electric. However, if you look at the airplane unbiased by glow engines- you will have a much better shot at coming up with a suitable power plant. My best conversions have not involved matching watts to horsepower, but matching propellors and motors to airframes. This flexibility is where electrics shine.
Sam
