The 2826 is more then enough to power that size plane. I have some real life numbers for it. With a 13 x 8 APCE on 3S2P pack it puts out 410 watts at 41 amps at 7600 rpm.
I am using a mega 22/20/2 geared 3.18 x 1 in a similar size plane. Output with a 12 x 8 APCE on 3S2P pack is 450 watts at 45 amps at 7900 rpm. I also am using on Orbit 15\18 in a 61 oz AUW sport plane. With a 12 x 8 APCE prop on 3S2P pack that putsout 430 watts at 42 amps and 7700 rpm. They all fly very well and fit my flying style perfectly. Doug |
I used contact hinges all round, elevator, aileron and rudder. The have held up fine. Personally I think the existing elevator is fine.
The landing gear does need bracing up a touch. I used two sticks of balsa to spread the load a bit further. You can also use nylon bolts (4 mm) if still in doubt. An outrunner with a prop up to 14x10 works well. Use at least 12 BRJ (big round jugs) or equivalent. Its really a 14-16 cell plane or lipo equivalent. |
Doug |
Plettenberg 25/16
The Orbit 25/16 fits. The only mod is to make those square supports sticks into triangles like Rob shows on the plan.
I began removing the purple transparent covering last night;thank goodness that it comes off easily. What would be the best way to remove the white pigment left after the clear part was peeled off? Sanding? Acetone? By the way, I'm very impressed with the construction and fit of the parts after taking the covering off! Aside from the asthetics of the colors, a real nice airplane. |
Thank's for the answers! BV |
I bought a second one for the $99 price. The one that I've been flying since July has an astro 25G (brushless) on 4s4p lipo (soon to be 5s4p), about 650 watts, we'll see how it likes more power.
BTW, I also put the R and E servos in the tail, and it is quite difficult to balance the plane that way- I would not recommend it. Part of the reason that I'm going to a 5s pack is because I need noseweight. At first I had a mega 45/3e in the nose, a honkin' 11 oz. motor, and I still had to move the battery pack far forward to balance. When going to the astro motor, wich weighs 8oz with gearbox, the plane is still tail heavy even with a higley heavy prop hub. Put the servos as shown in the plans and the plane will be fine. The elevator is fine, tape works well on planes even larger than this. I also replaced the LG with a carbon unit for more prop clearance. My only complaint is that I don't like the covering scheme as produced. I prefer opaque colors in a 40-sized pattern ship. My plan is to compete in my first pattern competition this spring, hence the slightly over the top power. You wont need 800 watts for sport flying! Local pattern flyers have flown this plane and said that it flies surprisingly well for a 40 sized plane- it is at least as good as the venus. These guys tend to be pretty critical ("anything smaller than 90-sized sucks"). |
Thanks, Twest!
Wow, you saved me some grief about the servo location! It use to be that electrics were notoriously nose heavy- quite a change!
I added some ply strips to the LG area ala, the plans. I also added some balsa triangle stock along the front of the plate to add some more stress relief. I have the carbon fibre LG made for the E3D and it gives about an inch more clearance plus it's wider, too. I cut a cooling hole in the nose and ground down those square motor sticks to a triangle shape to give me clearance for the 25/16. I added some carbon fibre plate to the rear of the firewall plus added fiberglas strips on each side of the plate. The 25/16 exerts a heck of a twisting motion so this was the strongest and lightest way to stiffen the nose. I'll have to order a 2" spinner from Zb to fit. All that I have on hand are 2.25". I finished stripping the wing this morning. I plan to add the 2" strip of fiberglas cloth to the center section. I noticed that the manufacturer would piece together pieces of balsa to make up for shortages. Nothing major, just little splices here and there. I'm not complaining- their joint work is superb! Balsa is expensive everywhere! My Mouse sander did a good job of removing the leftover pigment. Until, it died! Oh well, time to go to Home Depot and get a replacement. Frank |
| Thread Tools | |
| Rob Smith's E-Sport 10 Pilot's Report | EricBjorn | Sport Planes | 351 | Oct 07, 2011 01:38 PM |
| Rob Smith's E-Sport 8 | GaryK | Sport Planes | 640 | Apr 23, 2007 09:14 PM |
| Sold E-Sport 10 F/S NIB | nrthwing | Aircraft - Electric - Airplanes (FS/W) | 2 | Oct 13, 2005 05:31 PM |
| E-Sport 10 Electric ARF | kionapub | Aircraft - Electric - Airplanes (FS/W) | 15 | Mar 04, 2004 02:02 PM |
| FS: E-Sport 10 Partially assembled | a2zprod | Aircraft - Electric - Airplanes (FS/W) | 2 | Feb 07, 2004 06:16 PM |
