Old Mar 11, 2002, 08:53 PM
fritts is offline
Find More Posts by fritts
Markle, In. US
Joined Oct 2000
CR-2 lithiums with RFS-100
I was wondering if anyone is powering their planes with a CR-2. I lightened one down to 10.5 grams. Its on my RFS-100 design. Total weight with direct drive KP-00 motor is 26.3 grams. I'm under an ounce, hehe. Gonna test drive it tomorrow. Will give a flight report. Hopefully with the 75 sqin of wing area it will fly pretty slow. Any thoughts on the CR-2 though. I know they are not rechargeable but seems like a good alternative to rechargeables with comparable weights.
fritts is offline Find More Posts by fritts
Old Mar 12, 2002, 04:22 PM
fritts is offline
Markle, In. US
Joined Oct 2000
Just to let you know I'm running the KP00 motor direct drive to a B2 prop, all powered by the CR2 lithium. I only got to fly for about 5 minutes,didn't have time for more flying so there is more in the battery. Controls were very responsive, flew with athority at 2/3 throttle. Mainly just circle patterns tightest circle was around 25 foot, mainly do to the wind and being on the street. I am very pleased with results though. Flew at about a fast walking pace against the wind much faster with the wind. I am going to work on getting it inside and see how well it handles.
CR-2 should be able to run for 45 minutes on 2/3 throttle, how about that for a flight. To bad they aren't rechargeable, or at least I won't recharge them.
Old Mar 12, 2002, 07:30 PM
opualuan is offline
Find More Posts by opualuan
high-speed freak
opualuan's Avatar
San Jose, CA
Joined Sep 2001
well, there were murmurs that you could stuff charge back into it, but I wouldn't recommend it and any info about it will be swiftly deleted by the ezone ss (hi guys! ) it's not worth the effort or the risk, really. I remember these being sold very cheap on ebay. dave lewis has recommended them to me in the past, and the in the startlite it's a recommended battery (rc microflight).
opualuan is offline Find More Posts by opualuan
Old Mar 19, 2002, 11:38 AM
Taniwha314 is offline
Find More Posts by Taniwha314
Bayville, New York
Joined Jun 2001
Hey Guy's,
I'm thinking of using the CR2 for the RFS-100 system and was wondering... since it's my first try at Lithium Batt.'s can you just solder leads to them? I wasn't sure if this was ill advised or if I should just tape them on? Thanks.
Brandon
Taniwha314 is offline Find More Posts by Taniwha314
Old Mar 19, 2002, 11:57 AM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Ryan,
I've wondered about this battery. Do you remember off hand its voltage? Also, my 3-cell 120 NiMH pack with shrink wrap and JST wire and plug weighs 11.7g (I could probably lighten this a bit more). So, what do we get from a CR-2 other than really long flight times and almosta gram less weight? If it has more volts, that's a plus. If it can't supply as many amps, that's a minus (although your flight performance suggests that's not the case). Anyway, I don't even own one of these. I do have a smaller Lithium on my workbench that does weigh less and I've been thinking of trying it on a static test compared to NiCd and NiMH packs. Just haven't gotten around to it yet.
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Mar 19, 2002, 12:24 PM
opualuan is offline
high-speed freak
opualuan's Avatar
San Jose, CA
Joined Sep 2001
cr-2 should be 3-3.6v, can't remmeber which for non-rechargeables... it's useful up to an amp. would probably be a good match for the rffs with long flight times, anyone know of someone selling a crate of them on ebay, as they are non-rechargeable?
Old Mar 19, 2002, 12:35 PM
fritts is offline
Markle, In. US
Joined Oct 2000
The CR-2's are good up to about an amp from what I have heard. I believe this to be true from the way the plane flies too. The voltage on the CR-2's is 3 volts. I just thought I would check out another option for powering these planes. Since I used this with the tyco/echargers plane I made. It flew but not all that well. I mainly to do with the bang bang type control you got with the tyco reciever. The CR-2's have like 650mah to them too.
Idea A simple circuit with metering for CR-2's. John255 Hand Launch 12 Nov 13, 2006 07:36 PM
Discussion charger rc cr-2 with pictures!!! prodigy Foamies (Kits) 1 Aug 27, 2006 07:38 AM
For Sale 2.5 Inch Tru Turn Aluminum Spinner with Saito 100 Adapter rino Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jan 29, 2006 12:54 AM
Confirmation abt Wes Technik DC5-2.4 motor with RFFS-100 ESC quarkz Scratchbuilt Indoor and Micro Models 1 May 22, 2003 06:53 AM
FS: GP Spectra with MM 2.5-1gb for $100 Beachernaut Aircraft - Electric - Airplanes (FS/W) 3 Jul 13, 2002 01:33 AM
