| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#1 |
BP21 brushless & GWS 1047 prop
Hi folks,
anyone recommend against this combination or got specs on it? I just have a spare GWS 1047 prop hanging around to play with. Otherwise I'll have to head down to the LHS to get one of the direct drive props. FYI...I'll be using this motor to drive a 3Dfoamy F18 when I finish building it. Ex. |
#2 |
How many cells are you running?
#3 |
I've got a 2s and 3s lipo between this one I'm building and two others. I'll probably use the 3s in the F18.
It's a GWS 3s 1050mah Lipo battery. Ex. |
#4 |
I measured a 1047 with 3s on this motor. I stop pushing the throttle when it hit 17A....almost at WOT. You would be frying your batteries pretty quickly. The GWS cells are only 6C so 6A is a good max target to aim for.
I believe with the original specs, a 8043 on 3s is still pushing 10+A. You could try a 7035 prop to bring it down further and not use WOT too much. This is the reason why I rewound the motor to 19T WYE. Now pulls around 9A with 3s 1400 at WOT. Still has plenty of kick for a 400g 3D plane. |
#5 |
Crash Master
Are you running the 8040HD prop?
#6 |
Oops...didn't mention the prop! the rewound 19T WYE is pulling a 1047sf with 3s and 9A draw.
#7 |
Balsa Abuser
what size wire did you rewind it with?
as I am looking at rewinding mine as well |
#8 |
Been There! Done That!
I get a kick out of the people that think the 8 X 4 prop is wimpy on the BP 21. Check out the vid on my website what it does in a 24.1oz Slow Stick with 3S1P Lipos! Most of the flying was at 55% throttle.
boomer www.boomerseflight.com |
#9 |
Thanks dtm...much appreciated. Looks like another battery investment so my F18 might not fly for a while yet.
Ex. |
#10 |
8x4 is not wimpy.....there is no mention of "wimpy" in any of the posts neither....the point of re-winding the motor was to keep the amps down (my cells could not handle the draw)..... However, if you read my post you would have probably figured that out yourself!
Trikky- I used the 26 awg stuff than comes with the Gobrushless CDR motors. Correction...the plane I'm using the motor on is 375g AUW...not 400g. I'm getting confused! |
#11 | |
#12 |
Yes, there is a lot of "mis-information" on the internet, that's why is better to do some filtering. There are a lot of people who will always knock cheap stuff and made in China stuff. If they wish to remain in their life of ignorance then I'm certainly not going to be the one to bring them out of it. Providing me (or you) aren't in that same "ignorant" state!!
Anyway...getting off my soapbox now. Has anyone dissected a B12 motor to find out the turns of the thing? |
#13 |
Besides rewinding, can you reduce AMPs by installing a gearbox? I think I read in another thread about installing this motor in a gearbox...??
Ex. |
| Thread Tools | |
| Sold GWS Spitfire + BP21 Brushless Motor, $60 shipped | Doubletap | Aircraft - Electric - Airplanes (FS/W) | 0 | Apr 17, 2006 07:27 PM |
| Brushless GWS Corsair prop size? | RickAvery | Parkflyers | 7 | Jun 08, 2005 09:24 AM |
| Cool GWS Spitfire BP21 motor 7x6 APC prop TP 3s 2100 Battery | mike7130 | GWS (Grand Wing Servo) | 4 | Feb 25, 2005 11:10 AM |
| Brushless to replace lps-b with 1047 prop | sloper steve | Power Systems | 8 | Dec 28, 2003 03:51 AM |
| HELP! How do you mount the orange 1047 prop on the GWS DX-A? | EFoil | Parkflyers | 6 | Sep 09, 2001 12:41 AM |
