Old Jan 19, 2005, 08:00 AM
mluniewicz is offline
Find More Posts by mluniewicz
Practice makes pieces..
mluniewicz's Avatar
North Berwick, ME
Joined Jan 2002
Vinyl cutter for making airbrush masks?
I was thinking of getting one of the inexpensive (relatively) vinyl cutters for making masks for airbrushing. Any opinions on how well this would work? Is there material available like frisket paper that could be used in the cutter (I'm looking at the Stika cutters from Roland - www.rolanddga.com)? I imagine the standard vinyl used for signs would be too tacky to use as a mask (would lift existing paint, etc.).
Any opinions or info on experience with using a vinyl cutter for making masks would be appreciated.
- matt
mluniewicz is offline Find More Posts by mluniewicz
Old Jan 19, 2005, 08:09 AM
mluniewicz's Avatar
North Berwick, ME
Joined Jan 2002
Hmm... noticed two typos in my post - and can't find the edit button... where did it go???
Last edited by mluniewicz; Jan 19, 2005 at 08:19 AM. Reason: Found it - the graphic for the edit button didn't load for some reason.
Old Jan 19, 2005, 08:15 AM
Joules is offline
Find More Posts by Joules
United Kingdom, England, Sheffield
Joined Dec 2003
Hi Matt,
I have one of the larger desktop Rolands (PNC-960)... The Stika in my experience is not really man enough for cutting lots of mask film. You can actually buy a low tack vinyl that is sold as paint mask. Normal vinyl has too good a grab to be used. I have no problem in using Frisket paper, just test until you get the blade pressure right, and it only just scores the backing. For very intricate designs, do the cut in two passes, this lessens the chance of the blade snagging the film (reduce the blade pressure), and watch for worn blades, as they also snag.
Joules
Sorry, that should have been Frisket film...
Joules is offline Find More Posts by Joules
Old Jan 19, 2005, 08:24 AM
mluniewicz's Avatar
North Berwick, ME
Joined Jan 2002
This wouldn't be getting lots and lots of use, just for my own stuff and a couple of friends. I've found the SX-8 on ebay for about $360 and am just wondering if it's worth the investment.
Thanks for the info!
- matt
Old Jan 19, 2005, 10:10 AM
Joules is offline
Joined Dec 2003
I would say if the cost is spread around you and your friends, it's probably worth it. Just weigh up how much sign work you could buy in for that. You still have a learning curve, and possibly software to buy before you are going. Keep an eye open for a larger machine, once people know what you can do, it usually ends up being more than just a few friends asking for your services.
Joules
Old Jan 20, 2005, 06:08 AM
GordonTarling is offline
Find More Posts by GordonTarling
Supersonic Engineering
GordonTarling's Avatar
UK, Greater London, Uxbridge
Joined Mar 2001
I've got a larger Roland vinyl cutter and use it to cut paintmasks all the time - it works very well. In fact, I cut the canopy masks for most of Jim Ryan's kits. You do need to use the special paintmask films, but other than that, there should be no problems. Any machine which you buy would also be invaluable for cutting vinyl decals etc. The older Stika machines were somewhat limited in their suitability, but I can't speak for the current range. Might be worth seeking out a used larger (pro type) cutter - they can be found at reasonable cost and are much more suited to the job.
GordonTarling is offline Find More Posts by GordonTarling
Old Mar 21, 2005, 03:13 PM
Jim Frahm is offline
Find More Posts by Jim Frahm
MSgt, USAF Ret.
Jim Frahm's Avatar
USA, WA, Spokane
Joined Nov 2003
Take a look at this sight... http://www.signsupply.com/Vinyl/FDC/3503.asp
They offer the mask you're looking for. I just pruchased the Roland SX-12 and really like it. The included software is not that bad. You'll have to make a lot of decals before the machine pays for itself, but the convenience is priceless.
Can anyone recommend the best vinyl for decals? I'm going to use it on foamy planes and larger RC gas planes, boats, cars etc.
Jim Frahm is offline Find More Posts by Jim Frahm
Need software for a stika vinyl cutter scp85 tbstep Aircraft - Electric - Airplanes (FS/W) 2 Jan 27, 2003 11:43 AM
What is the cheapest laser cutter in the world,suitable for making RC model parts? bipeflyer The Builders Workshop 7 Dec 03, 2002 01:45 PM
Little bit improved method for making actuators Jim McPherson Scratchbuilt Indoor and Micro Models 2 Dec 09, 2001 07:32 AM
Info for making battery packs? Mike Wood Beginner Training Area (Aircraft-Electric) 4 Nov 04, 2001 12:27 PM
Ideas for making $$ with an E-plane maciek Electric Plane Talk 7 Aug 07, 2001 06:31 PM
