Fantastic plans are available through Cleveland Models (http://www.clevelandairline.com). These plans were drawn in the late 1930's or early 1940's and have excellent scale features.
Planeman |
Joined Dec 2012
Boeing 314
I designed a 1"=1' Boeing 314 Clipper. The plans are available from Scale RC Models.
http://scalercmodels.com. Hope you enjoy it. There are two dozen of my design there. The site is under construction and may not ne useable quite yet.. Keep checking. |
Martin " China Clipper"
Foamyfoam:
I have an old printed cover of Model Aviation December 1983 hanging on my wall. The cover photo is a young lady holding what appears to be a 90" Martin "China Clipper" The magazine has the build article and plans. I have the cover hanging on my wall to remind me that I am going to build it someday. The build article is a great read describing the maiden flights. B. Bradley |
USA, PA, Westmoreland Co.
Joined Aug 2008
I've seen this site before but have never purchased anything from them. didn't they used to have a lot more plans? |
Joined Aug 2008
the guy who goes by NeffWaffe also built a 314 out of foam/depron.
http://neffwaffe.com/the-videos/boeing-314-clipper http://neffwaffe.com/pictures/boeing-314-clipper not much detail on the construction, but I believe he scaled up a set of 1/72 drawings. these drawing were previously available on the web, free. The only place I see them now may charge a fee. http://www.the-blueprints.com/vector...rican_clipper/ curious that it was never done for RC in any magazines. |
Joined Dec 2012
Scale RC Models is redoing their site. Check back for a world of new plans including the 314. A preliminary look is at http://scalercmodels.dyndns.biz/. It's not yet functional but you can see some of what is coming.
Chris Marco Marcoplanes |
dang, i was excited for a moment but at 12 foot that is a bit large for my tastes, plus 75 bucks for just plans seems a bit high. im in process of designing a cad model of this to hopefully be in the 1400mm size range made of blucore foam glassed and powered by 4 electric motors off maybe a 4cell 3300 or 2 2200 3s packs in paralell
For a 1400mm plane, a single 2200mah 3S 30C ought to power it.
2.2A *30C = 66Amax 66Amax * 11.1V = 732W 732W * 80% (typical efficiency) = 586W 586W / 4motors = 147W/motor 147W / 11.1V = 13A So basically, a single 2200mah 3S 30C lipo could run four 150W motors which will give you 24oz of thrust per motor or 6lbs thrust total. That's a lot of thrust for a 1400mm (55") plane. By comparison, the 1400mm FMS warbirds weigh less than 4lbs AUW. You could probably dial it down to four 100W (400-size) motors and 9A+ ESCs... which is like 1:1 power/weight if you can keep it to 4lbs AUW. That should be totally do-able. |
Here is my buddy's build thread for his 314:
http://www.rcgroups.com/forums/showthread.php?t=81766 My favorite pix attached. |
| Thread Tools | |
| Build Log Mini size Boeing 314 Clipper | Vyceroy | Waterplanes | 50 | Jun 05, 2007 12:04 AM |
| Build Log Mini Boeing 314 Clipper | Vyceroy | Foamies (Scratchbuilt) | 27 | Jun 04, 2007 09:05 PM |
| Boeing 314 Clipper build thread | fliir | Waterplanes | 0 | Jul 11, 2005 03:51 PM |
| Comet Clipper Plans | uniflite | Aircraft - Fuel - Airplanes (FS/W) | 0 | Aug 12, 2004 08:08 PM |
