Old Mar 11, 2002, 09:32 AM
Joined Mar 2002
Why wont this fly my Zagi well?
Could someone recommend what i should change in this configuration to get better performance than what i have now?
Zagi 400 plane flying weight = 23 oz
7cell 650mah battery
Graupner 480 competition motor
Jeti 25 speed control
tried both 6.5X4 and 5.5X4 prop (neither fly well)
I thought that i would see this plane scream thru the air by upgrading to this new motor, but the thing is very sluggish and
slow. My stock prop and 400 motor out perform this setup. Do I need different batteries, different prop? Could someone help me out here. I dont want to have wasted my money going to the 480, shouldnt i see a huge performance difference now?
Thanks for any advice.
Mr. Foam.
Mr. Foam is offline Find More Posts by Mr. Foam
Old Mar 11, 2002, 09:52 AM
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
Use eight cells. What kind of cells are the 650s? What Graupner # is on the motor?
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Mar 11, 2002, 10:49 AM
Joined Mar 2002
Though i am not at home rite now, the motor is GR6304L 7.2V (a reverse rotation motor made for pusher planes). The cells are Sanyo. Dont have the rest of info off hand though. The batteries are about 2 yrs old, but dont have more than 35 flights on them.
Ill post the exact cell specs tonight.
Would going to 8 cell and higher capacity batteries also help power (probably stupid question, but hey, i dont know the answer!)?
Mr. Foam
Old Mar 11, 2002, 11:03 AM
RPatrick's Avatar
Hurst, Texas USA
Joined Jan 2002
Another battery tip - If you are looking for power use Nicd cells rather than NiMH, in general they have a higher discharge rate.
I agree with the 8 cell suggestion.
Good Luck!
RPatrick
RPatrick is offline Find More Posts by RPatrick
Old Mar 11, 2002, 11:14 AM
Rochester, NY, USA
Joined Aug 2000
Ahhh, Mark nailed the problem with his motor # question.
A 7.2 motor like your Speed 480 Reverse should be run on 8-10 cells...preferably 10 cells.
Greg Covey is offline Find More Posts by Greg Covey
Old Mar 11, 2002, 02:56 PM
Clu
Glavin!
Clu's Avatar
Southern NJ
Joined Aug 2001
Your original speed 400 was 6volt, your new is 7.2. That's why the old flies better.
7 cells on the stock speed 400 is not all that great to begin with. I'm surprised it flies with the 480 7.2v.
You're definately going to want to go to 10 cells. Every additional cell add 1.2 volts.
A better combo would be a 6v 480 with 8 cells
Clu is offline Find More Posts by Clu
Old Mar 11, 2002, 03:44 PM
Joined Mar 2002
Wow, thanks for all your input..Im leaving town for this week so no flying but ill give that 10 cell pack a try next week, and possibly look at exchanging the motor for a 6v motor.
thanks again.
Mr. Foam
Old Mar 11, 2002, 09:37 PM
staten island new york
Joined Sep 1999
I fly 3 different zagi clones and P-cat on that motor. Don't exchange it for a 6v yet. I use 8cells and anything from 800ar, 1400ae and 1300cp with a Master Airscrew 5.5x4.5. It's a great balance of perfomance and flight times. Make sure you have the prop facing the right way.
mrneutron is offline Find More Posts by mrneutron
Old Mar 12, 2002, 08:13 AM
characters welcome!
Mark Wood's Avatar
Joined Feb 2000
What mrneutron said.
mw
Old Mar 23, 2002, 07:11 PM
Joined Mar 2002
Thanks.
Had a chance to finally fly with a 10 cell. My zagi now screams through the air as i hoped it would. Thanks for all the help!!
Help - Why can't I fly my GWS Corsair geoff_s14 Parkflyers 34 Dec 11, 2004 05:55 AM
Will this fly my DR1?? randall1959 Engines 4 Jul 09, 2004 12:10 PM
Where can I fly my Zagi in the NYC area? areaman Electric Plane Talk 5 May 17, 2004 02:49 PM
Why would this happen to my Flash 5x soholingo Radios 5 Mar 09, 2003 05:32 PM
Can I fly my Zagi when its snowing? RandyK1 Foamies (Kits) 12 Jan 06, 2003 04:19 PM
