Old Mar 11, 2002, 09:26 AM
dmarnel is offline
Find More Posts by dmarnel
Coral Springs, FL
Joined Jan 2002
Yet another screwed up order!
About 2 weeks ago I inquired with Cyberheli about a Plettenberg 300/25/A3 heli motor for my Logo 20. They said yes they have them in stock. Great, I said, I'll take one of those! I send the necessary info via email and I get a reply back stating "Sorry, I've caught the HK flu and have to lie down for a while, thanks for your patience and understanding." What does this mean??? I reply back asking if this means my order will not be fullfilled. No reply. A few days later I finally get an acknowledgement of my order and an email confirmation.
Today my motor arrived! That was FAST! I was very impressed since this came all the way from the orient. I opened the box and on the outside label it read: 300/25/A4, NOT 300/25/A3 as I had ordered. I figured maybe it was just shipped in the wrong box. I open the box up and on the motor label it reads: 300/25/A4!!!! I know the A4 is rated for 20-24 cells, but how does it compare in terms of power? My Logo 20 has a 9-tooth pinion. Should I keep this motor or send it back?
dmarnel is offline Find More Posts by dmarnel
Old Mar 12, 2002, 01:30 PM
dmarnel is offline
Coral Springs, FL
Joined Jan 2002
Does anyone use the HP 300/25/A4 Heli motor? How does it differ from the A3?
Old Mar 12, 2002, 02:42 PM
bradpaul is offline
Find More Posts by bradpaul
USA, FL, Apopka
Joined Dec 2000
If you go to the Plettenburg web site you can get the datasheets on the two motors.
http://www.plettenberg-motoren.com/index_uk.htm
It looks like the A3 has a higher Kv and is the 3D motor while the A4 has better duration for hovering FF.
It is all in the datasheets.
Brad
bradpaul is offline Find More Posts by bradpaul
Reply With Quote  (Disabled)
Old Mar 12, 2002, 02:45 PM
nullman is offline
Find More Posts by nullman
Mission Viejo, CA, USA
Joined Apr 2000
I suspect the KV of the A4 is a little lower than the A3. Looking at the specs the A4 is designed for 24-26 cells where the A3 is designed for 20-24 cells. This is typical for motors of similar size/weight to have higher cell count capability and lower KV.
I don't have a pletti motor but have seen an excellent set up with the A3 in it. On 24 cells and 9 tooth pinion the power is amazing. I would hazard a guess that you would have to go to 26 cells and a 10 tooth pinion on the A4 to get similar performance.
I can't find anywhere where it is actually specified what the Kv for the motors is though so I am only guessing here!
Nick
nullman is offline Find More Posts by nullman
Old Mar 12, 2002, 02:49 PM
nullman is offline
Joined Apr 2000
You found the Kv in the datasheets? Where? I couldn't find the typical motor constants you normally get with motors. Kv, Io, etc.
There was some datasheets of motor performance at certain voltages and load (I think that's what it was, they were in German but my brain is in English).
Nick
Old Mar 12, 2002, 03:11 PM
bradpaul is offline
USA, FL, Apopka
Joined Dec 2000
The column headings are:
Voltage
Amps (current)
RPM
performance in (watts)
performance out (watts)
efficiency
torque
Divide RPM by the voltage at the appropriate range of voltages you expect to use to get a very accurate Kv.
So for 20 cells use 24V at start to 22V at shutoff.
Brad
Discussion ServoCity double checked screwed up order 7thSon Radios 7 Dec 25, 2005 01:03 AM
Yet Another Happy Brushless Convert...Hopped Up GWS Spitfire FLIES! mu2freighter Parkflyers 8 Nov 08, 2005 03:51 PM
Just can't build yet another Spitfire ? ChrisP Scale Kit/Scratch Built 0 Jun 25, 2001 04:42 AM
Yet another newbie wondering what to buy... Dro Electric Heli Talk 2 Apr 26, 2001 03:03 PM
