Old Jan 16, 2005, 08:38 PM
Bart8 is offline
Find More Posts by Bart8
Joined Nov 2004
Best Lipo Battery
Hi guys....I'm running a brushless Shogun that I am currently running a 3 cell Kokam 1200 lipo, but would like some feedback before I purchase another battery. What are you running and where do you get them at the best price? Thanks a bunch for your help. Don
Bart8 is offline Find More Posts by Bart8
Old Jan 16, 2005, 08:45 PM
Geoffrey109 is offline
Find More Posts by Geoffrey109
Blade Springs "Rock"
Central Coast, CA
Joined Apr 2004
You should get lots of feedback on this.........I'm guessing you are under powerd and have short flights......maybe a good TP 3s1P2100......You have to love lipolys........dont make me bring out the bucks photo!!!
G109
Geoffrey109 is offline Find More Posts by Geoffrey109
Old Jan 16, 2005, 09:03 PM
Bart8 is offline
Joined Nov 2004
Thanks for the super fast reply. I'm just hovering around the house right now , but power IS NOT the problem. I get bored B4 battery dies. I just want to get a good second battery. Also, how warm is too warm for a lipo? My infered thermometer says it's about 106-110 F after 8-10 minutes of flying.
Old Jan 16, 2005, 09:05 PM
TheX is offline
Find More Posts by TheX
Old new guy
TheX's Avatar
United States, TX, Austin
Joined Sep 2004
What motor are you running? I have an E-Flight Park 400 4200KV in one and a HiMaxx 2025 4200KV in another (basically same motor). I run Kokam 1500 3s 15c, Thunder Power 1320 and some Tanic packs (that are too wide to fit right so they are retired). The 1200 pack you have will be nice and lite but you can get a lot more flight time. Doe's you Shogun balance properly (slightly nose heavy) with that pack?
TheX is offline Find More Posts by TheX
Old Jan 16, 2005, 09:48 PM
Cerberus is offline
Find More Posts by Cerberus
Joined Aug 2003
Im using Polyquest 1800s 12C with a Himax 4200 9T. They go for about US$61 at either www.bpp.com or www.cheapbatterypacks.com (called IRate cells instead of polyquest I think). I have no trouble with duration, motor bogs a bit on pullout but I think thats more to do with the motor and pinion than the cells.
Ive got two and have no trouble balancing, but I do have the tailmounted gyro and servo as well as a belt drive.
Cheers
Will.
Cerberus is offline Find More Posts by Cerberus
Old Jan 17, 2005, 03:41 PM
Bart8 is offline
Joined Nov 2004
Thanks TheX for your response. I mistakenly said I had a 1200 but I really have a 1500 Kokam. I'm using the 2025 like you and flight duration is not a problem. I just want to make sure I'm not buying a looser due to advertising hype. (Like the Hummingbird I just sold!) The Kokam has been fine, although I do have to extend the battery tray to get a good CG, and I had to raise my elev and ael servo to get the clearance the battery needed. A pair of 1/16" shims took care of that. I've got the goods to do a belt drive conversion as soon as my gear goes. I just need info on good reliable batteries from the users viewpoint. Thanks for the imput, and keep um flyin!
Old Jan 17, 2005, 04:38 PM
Cerberus is offline
Joined Aug 2003
I also had a 1500 first, It tends to get very hot (I got an 8C pack), so thats why I went looking for an alternative. I also had the issues with raising the servos and extending the tray. The 1500 flies a bit lighter, but the 1800s stay cool and last alot longer.
Also my suggestion, if you have the belt drive kit swap it, I wouldnt wait till the tail loses it and you wind up having to replace a $30 set of blades and $10 main shaft + $8 spindle shaft because you waited too long to swap.
Old Jan 17, 2005, 05:56 PM
TheLost is offline
Find More Posts by TheLost
My Bulldog is my copilot ..
TheLost's Avatar
Joined Feb 2004
Also check out BattlePack and Aircraft-World for PolyQuest packs.
One nice thing about PolyQuest packs is the build quality. Rubber sheath covering and shock pad caps on both top and bottom. Not that i ever crash ... but its nice to have...
TheLost is offline Find More Posts by TheLost
Old Jan 17, 2005, 06:43 PM
Dunedinflyer is offline
Find More Posts by Dunedinflyer
United States, FL, Dunedin
Joined Nov 2003
a really good pack is a tanic or apogee 1660 3s2p weighs 127 gms with a deans
made of 830 cells holds its voltage really well i use the tanics as they balancing
taps built in rember you get what you pay for to me kokams are the bottom of the deck 1500 8c is 135 degrees low on power tanic after after 10 94 degrees
power wise way better than the kokam was at the start of the flight
Dunedinflyer is offline Find More Posts by Dunedinflyer
Old Jan 17, 2005, 07:56 PM
Bart8 is offline
Joined Nov 2004
Good point Cerberus!!! I will heed your advice even though I'm just hovering around the basement. 3-4 feet is still a crash.
Old Jan 17, 2005, 08:03 PM
Joined Nov 2003
Tp has the bulk of the market along with kokam but they are by far not the best packs its all in marketing
Old Jan 17, 2005, 08:11 PM
Central Coast, CA
Joined Apr 2004
If you don't mind, the remind us of what is the best battery.........??? Because I'm getting ready to buy some more myself......
The 10C Rating on the New Gen 2 Thunderpower.....is really worth every penny spent....if you have something that is better I'd like to know.....
G109
Old Jan 17, 2005, 08:29 PM
Joined Nov 2003
i hade logo ten flies on 5s2p 4350 tanics alsoa shogun like yours himas cc 35
belk drive 401 all up 566 grams i use tanic 3s2p 1660 apogee makes the same pack i chose tanic because of the taps also Brian at tanic packs had a good deal on this particular pack unblieve difference in power than a kakam 1500
and weighs 12 grams incuding deans ultra the packs are 79.00 list callbrian
RC TOYS6 he may have some left i ment to say 12 grams more than the kokam i guess i need to tpes at the same speed as i think
Old Jan 17, 2005, 08:35 PM
Central Coast, CA
Joined Apr 2004
G109
Old Jan 17, 2005, 08:48 PM
Joined Nov 2003
thats strange i hare 3ecos a logo several glos with belt drives i ve never broke a belt before i crashed it always seemed to happen after the fact i've been playing with these big boy toys for 25 years
Best brand of Lipo battery? flierbk Batteries and Chargers 31 Nov 16, 2007 02:11 PM
Help! Lipo Battery buying help needed--Where's best price??? GFX Micro Helis 15 Apr 09, 2007 11:34 AM
Discussion Best Lipo Battery for Zagi XS w/Mega 16/15/3 Lithuanian Flyer Flying Wings 9 Jul 30, 2006 04:19 PM
Discussion best choice of Lipo Battery -help please funkenstein Power Systems 5 Jul 01, 2006 02:18 AM
Best LiPo Battery Select? blueprints Micro Helis 7 Feb 20, 2004 04:53 PM
