Old Jan 16, 2005, 07:17 PM
600Burger is offline
Find More Posts by 600Burger
600Burger's Avatar
Sacramento, CA
Joined Jun 2004
Canard/Delta Wing glider?
Has anyone ever seen a delta wing shape glider? Or ever flown one? I ask because I'm thinking of building a glider that would have to withstand large accelerations as a way to put itself into orbit....i mean, the air.
-Burg
600Burger is offline Find More Posts by 600Burger
Old Jan 16, 2005, 08:57 PM
dustn is offline
Find More Posts by dustn
cranium accessories
dustn's Avatar
Raleigh, NC
Joined May 2004
you could try a pibros... its a very quick FFF build, and flies nicely! now i'm just curious how you are going to create this large acceleration?
pibros plans
dustn is offline Find More Posts by dustn
Old Jan 17, 2005, 11:22 AM
600Burger's Avatar
Sacramento, CA
Joined Jun 2004
Scaled version of this...
I have alot of estes rockets left over from when I was 10. Also have a very large rocket that could turn into a glider type plane. Probablly won't have a very good glide slope, but thats ok. I'm mainlly doing it to experiment/tinker.
Old Jan 17, 2005, 07:04 PM
kingbee is offline
Find More Posts by kingbee
Upper Michigan
Joined Jan 2003
How about this?
It's called Stormfighter 2, RCM plan # 843
Cheers,
Dave
kingbee is offline Find More Posts by kingbee
Old Jan 17, 2005, 08:23 PM
600Burger's Avatar
Sacramento, CA
Joined Jun 2004
Thats it!!!!
Did you make that, or is it a kit?
I'd like to try and make mine from "scratch"
-Burg
Old Jan 17, 2005, 08:29 PM
kingbee is offline
Upper Michigan
Joined Jan 2003
It's a plan for a slope glider, available from RCM magazine. Check their web site, they'll be more than happy to sell you the plans.
http://www.rcmmagazine.com/e/env/000...m=plans:pl-843
Cheers,
Dave
Old Jan 18, 2005, 04:37 AM
xtc is offline
xtc
Find More Posts by xtc
xtc
outrageously large member
xtc's Avatar
no-where near tx
Joined Feb 2004
its not that simple,in fact ,in order for the rocket to keep from trying to chase its tail ,you need to have the c/g somewhere near the nose while under thrust which makes for a very poor glider
try to contact a local rocket club for advise,there is usually one guy in each club that has played around with rockets on gliders
xtc
xtc is offline Find More Posts by xtc
Old Jan 19, 2005, 02:25 PM
Aerofoam is offline
Find More Posts by Aerofoam
Always Tinkering
Aerofoam's Avatar
United States, AZ, Tucson
Joined Jan 2005
I routinely launch my 36" delta wing at speeds up to 150 mph.
with a 1/2" HoseMonster bungee. It achieves that speed in less than 1 second.
That is much more force than you will see with the rocket unless you are using
J-engines or larger.(bungee imparts 35 to 40lbs. of pull) I have seen the plane
launched with an Aerotech reloadable motor. (21oz. thrust/9sec.) and it flew
very well. It is EPP and will weigh about 12oz. with standard tape construction.
It can be made lighter with a matrix of .015 or .020 carbon rod.
It thermals very well once you are use to flying it.
Aerofoam is offline Find More Posts by Aerofoam
Old Jan 19, 2005, 09:14 PM
600Burger's Avatar
Sacramento, CA
Joined Jun 2004
Thanks aero,
Do you have a pic of that plane? You said it was about a 12oz plane and 36" wide, but do you know the total wing area? I think that might help me in making a good prototype model to test fly (not RC, just ff glider).
That fact that its out there is encouraging, now I just have to find time between classes to build some of this stuff.
-Burg
Old Jan 21, 2005, 12:17 AM
Aerofoam is offline
Always Tinkering
Aerofoam's Avatar
Joined Jan 2005
There are pics on my site, it has about 345sq.in. of area.
If you were trying to work cheap and disposable, you could build a pibros.
My delta wing has the same plan form, but it has a definite foil that
is suited for the speed range and loading.
MM.
www.aerofoam.com
Old Mar 24, 2005, 11:00 PM
FoamCarver is offline
Find More Posts by FoamCarver
Joined Mar 2005
Estes made a kit of a canard that was a rocket launch RC glider. I built one years ago and flew it with a cox 0.49 in place of the rocket. It flew well until I tried to use a rocket motor. To trim it with the 0.49 it had a lot of up elevator. I assumed that this was going to be a problem so I returned it to what looked to be neutral and let it rip. When nosed over in an arc with about a 12 foot radius and smashed into the ground. Before I could react my plane splinters with a still burning rocket engine stirring them up.
I still have the pieces and have glued them to together in an attempt to slope soar it but it really need rebuilt from the ground up. There is still enough left that I can get some dimensions from it if you are entrusted.
Troy
FoamCarver is offline Find More Posts by FoamCarver
Old Mar 25, 2005, 06:45 PM
kingbee is offline
Upper Michigan
Joined Jan 2003
Was it this? This is an RCM plan that was kitted by Estes as the Astro-Blaster. It's RCM plan # pl-1148
Cheers,
Dave
Old Mar 26, 2005, 10:53 AM
Delta 1 is offline
Find More Posts by Delta 1
Serious Builder
Delta 1's Avatar
Winnipeg, MB CANADA
Joined Jun 2004
what you have here look incredibly like an XP-55 Acsender
WWII There were only three of the ever mad ever production
There area couple of things about this plane that puts it into that ID catagory
1) front cannards
2) mainwings where they are
The verticals on the main wingtips on the original are moved in about 20% of the from the end also, there is another vertical set of fins that is missing on this model that was on the fuse just in front of the pusher prop
DELTA 1
Delta 1 is offline Find More Posts by Delta 1
Old Apr 07, 2005, 12:49 AM
Aerofoam is offline
Always Tinkering
Aerofoam's Avatar
Joined Jan 2005
[QUOTE=Delta 1]what you have here look incredibly like an XP-55 Acsender
I think the similarity ends once you get past the swept main wing.
Old Apr 07, 2005, 08:08 AM
Thermalin is offline
Find More Posts by Thermalin
I'm a pilot, 100 yrs too late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
here is the estes rocket grlider.. not canard though..but very cool.. may give you some ideas... more plane like....http://www.hobbylinc.com/htm/est/est2201.htm ... saw a video of somewhere on the web... leaves the pad in a hurry.. blink and its gone!
Burger... I have actually gotten back into the rocket thing... contests are quite fun... spot landings.. designing your own and all use the same motor to see can get max altitude.... slowest descent, who can lift same weight the highest. etc etc.. all ages participate which is the neat part 40 yrs olds next to some whipper snappers..
Thermalin is offline Find More Posts by Thermalin
Anyone fly the Foxbat delta wing pusher? sticktime Foamies (Kits) 26 Feb 21, 2005 07:34 AM
F3 Delta Wing Glider emoone Foamies (Kits) 12 Jan 06, 2003 07:31 PM
DeltaSTAR 500 Electric Delta Wing Gary L Trapp Jr Aircraft - Electric - Airplanes (FS/W) 0 Sep 29, 2001 04:03 PM
60 Delta wing... exowatt Foamies (Kits) 5 Jul 20, 2001 02:54 AM
Looking for delta wing foamie sloper Ben74 Foamies (Kits) 3 Jul 09, 2001 11:12 AM
