Old Jan 16, 2005, 08:14 AM
olddog is offline
Find More Posts by olddog
olddog's Avatar
To oil or not to oil?
Do small electric motors like the GWS EPS 350 or 400 motor require oil and what kind of oil and how much?
Put in your 2cents on this subject.
olddog is offline Find More Posts by olddog
Old Jan 16, 2005, 08:49 AM
Al Offt is offline
Find More Posts by Al Offt
Boston, MA subburb
Joined Sep 2004
OldDog,
I use a drop of "White" sewing machine oil from a toothpic on each end of the motor shaft. Check out http://www.rcgroups.com/forums/showthread.php?t=319551 for information on breakin.
Alan
Al Offt is offline Find More Posts by Al Offt
Old Jan 16, 2005, 09:19 AM
bildo baggins is offline
Find More Posts by bildo baggins
Chillin till SEFF
bildo baggins's Avatar
Warner Robins, GA
Joined Aug 2003
Yes. Only a small drop on the front and back bushing. I use Trinity motor oil. It's the stuff The car guys use.
bildo baggins is offline Find More Posts by bildo baggins
Old Jan 16, 2005, 09:40 AM
PGR is offline
PGR
Find More Posts by PGR
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
After trying several oils, I also settled on Trinity oil. The stuff I buy comes in a slender cylindrical plastic squeeze bottle with a needle-point metal oiling tube (like a hypodermic needle without the sharp point). This makes it simple to control where and how much oil you apply.
Great oil in an excellent container.
Pete
PGR is offline Find More Posts by PGR
Old Jan 16, 2005, 10:04 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Any machine oil is good on motors WITHOUT bearings - the frequency with which it is applied is more important than the type. Oil before and after every flying session if you can get at the motor. NEVER oil motors that have ball bearings (search and you'll find plenty of previous discussion on this - bearings are lubricated at the factory, usually designed to last thousands of hours, oil will wash this lube away).
..a
Old Jan 16, 2005, 11:27 AM
PGR is offline
PGR
PGR
Low AltiDude
PGR's Avatar
Joined Jun 2004
This, I believe, is contrary to the information Astro Bob provides. I can't find my instruction sheet for my Mighty Micro 010 so I might be wrong but my personal experience supports the use of oil on ball bearings:
I'm on my 3rd set of bearings in 10 months on my 010. This last set is the first set I've oiled and they have outlasted the last two sets by at least twice as long. They're also noiseless to this day.
Some bearings are actually sealed but many are just shielded. Sealed bearings are "lifetime" lubricated but shielded bearings typically aren't.
Pete
Old Jan 16, 2005, 11:47 AM
aeropal is offline
Find More Posts by aeropal
aeropal's Avatar
Joined Jan 2003
Radio Shack Oiler - Slick Zero Bushing Oiler
aeropal is offline Find More Posts by aeropal
Old Jan 16, 2005, 11:59 AM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
Marvel Mystery and STP Mix- Boater's Lube
Most brushed motors use oillite bronze bushings with what looks like stainless steel shafts, but I still feel it better to wet them with some 3 in 1 sewing machine oil or Marvel Mystery mixed with STP
hall woo is offline Find More Posts by hall woo
Old Jan 16, 2005, 12:15 PM
Chillin till SEFF
Warner Robins, GA
Joined Aug 2003
I don't know about ball bearings. I would think thaey would use a thin grease of some sort. The bushings are what I oil.
Old Jan 16, 2005, 03:41 PM
olddog is offline
olddog's Avatar
Hey Guys,
Thanks for all the replys.
OLddog
Old Jan 16, 2005, 03:51 PM
rumme is offline
Find More Posts by rumme
Joined Apr 2004
on a himaxx direct drive brushless..should they be oiled??...
rumme is offline Find More Posts by rumme
Old Jan 16, 2005, 05:38 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Gerneral practice is that phosphor bronze plain bearings need oil, and regularly. 3 in 1 is a reliable cheap brand. Camn motors don';t have stainless shafts: They don;t even have hard steel shafts. they have almost wire shafts as anyone who has bent obne or cut it will tell yoiu.
Better motors have better shafts.
Ball races don't need oil, except to prevent rusting. But a thin oil does no harm. Grease may cause the balls to sieze and wear out very quickly - sometimes ball races come packed in gerase, and its important to wash that out wioth oil. Light oil in general does no harm to ball races.
Gearboxc gears though do need grease - and thick stuff - the sliding forces on the teeth will cause rapid wear if not lubricated by an oil that will stay functional at high temperatures and shear rates. I don't know a suitable brand, which I ought to, so if anyone else does, tell me!
Old Jan 16, 2005, 07:02 PM
rumme is offline
Joined Apr 2004
Vintage..thanks for the reply..unfortunatley..im not sure if it answered my question...I have no idea what type bearings are in my himaxx...I have only flown it once..and also wanted to know if the motor should be oiled before it is used...
Old Jan 16, 2005, 07:35 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Vintage's advice is in direct conflict with what I was told by Mike @ Kontronik and by a Hacker rep. I trust the manufacturers on this.
That said, not all motors are created equal - perhaps there are brands that require oil. I've not found one yet, however..
..a
Old Jan 17, 2005, 10:37 AM
hall woo is offline
Permanently Banned
Joined May 2003
Brushless Motors have Sealed Bearings
Sealed bearing R what I've seen when repairing BL motors
Discussion NONI juice-magic potion or snake oil? ElectRick Life, The Universe, and Politics 28 Jul 07, 2009 09:54 AM
Cool castor oil or synthetic bogas Fuel Plane Talk 15 Mar 18, 2005 06:02 PM
Castor or synthetic oil? W'rkncacnter Engines 10 Aug 18, 2004 04:25 AM
GWS 300C "B", Oil it or not? KeithLuneau Parkflyers 4 Jul 27, 2002 08:55 AM
