Old Jan 15, 2005, 11:17 PM
Basil is offline
Find More Posts by Basil
GraysonHobby.com
Basil's Avatar
Grayson, GA
Joined Jan 2003
55 dollars brushless with speed control problems..
Thought I would bring this up in the Power Forums...
My LHS had the combo for 52$ so I could not resist...Got home and installed it right away..Not sure if this is normal, however, when 1st starting out, it hesitates for a bit, then kicks in fine...Also, at full thorottle i hear some hesitation/strange noises, but when I back off to 75-50% it runs smooth..
What could this be?
Standard 8x4 GWS DD prop with LHS 3mm prop adapter...
Today in a test flight after i spent a good 30 secs trying to get the motor started, (Everyone at my field was giving me crap about buying such a chep Setup) Finally started and took off. I throttled down in flight to about 10% or so and then gave it full throttle and the motor sound like a record stratching i cut throttle to 0% then i tired to restart and couldnt get the Inuenndo Removed thing started again...Luckily I had plenty of field to drop out of the sky...FYI
Fresh 3 cell right off the charger...Tried a different pack and same proplem with and with out the stupid jumper on. Very Unhappy...
I have to have a bad motor, My motor ,if it ever spins, pulsates at full throttle, however, it stops at about 50% or so...at this rate, I should of stuck with my IPSA
Basil is offline Find More Posts by Basil
Last edited by Fred Bronk; Jan 16, 2005 at 04:52 PM. Reason: Language and Inuenndos
Old Jan 16, 2005, 12:14 AM
xoon is offline
Find More Posts by xoon
don't think.. just fly!!!
Littleton, Colorado
Joined Apr 2004
that got to sux... $50 of nothing
xoon is offline Find More Posts by xoon
Old Jan 16, 2005, 12:55 AM
ryanl2006 is offline
Find More Posts by ryanl2006
ryanl2006's Avatar
Ames, Iowa
Joined Oct 2002
Do you have any other brushless motors and/or brushless esc's? I only ask because I am curious as to whether the problem is the motor, the esc, or both?
ryanl2006 is offline Find More Posts by ryanl2006
Old Jan 16, 2005, 02:57 AM
NoM'rcrashPlease is offline
Find More Posts by NoM'rcrashPlease
"Walk of shame" Master!!!
NoM'rcrashPlease's Avatar
West Chicago Il
Joined Jul 2004
are you using the combo, like the one that Balsapr is selling???
This setup?
NoM'rcrashPlease is offline Find More Posts by NoM'rcrashPlease
Old Jan 16, 2005, 10:10 AM
Ecaf is offline
Find More Posts by Ecaf
Heli Addict....
Ecaf's Avatar
West Dundee, Il.
Joined Nov 2003
Originally Posted by Basil
TURNS OUT THIS IS HAPPENING ALL OVER!!!
Who else is having problems?
If this setup is the BP21 from BalsaPR, I dont have a problem at all with the motor or the ESC.
I have used the 2 combined on a 10oz 3D Foamie. Worked great with 3 cells (TP 1320 G2). The ESC itself works great with Ryans Double CDR motor and I have run the BP21 motor with a CC10. No problems at all.
I didnt experience any of the issues you listed above.
Have you tried different ESC's with the motor?
TB
Ecaf is offline Find More Posts by Ecaf
Old Jan 16, 2005, 11:21 AM
gunfighter is offline
Find More Posts by gunfighter
Joined Jun 2004
HMMM... I've got 3 of the BP-21 / 18A ESC combo's from Balsaproducts and have not had a second of trouble from any of them. They are a little louder than other brushless set-ups but they operate well.
gunfighter is offline Find More Posts by gunfighter
Old Jan 16, 2005, 12:48 PM
Thatovalguy is offline
Find More Posts by Thatovalguy
Foam rules
Thatovalguy's Avatar
HdG Md.
Joined Jan 2003
http://www.rcgroups.com/forums/showt...44#post3177044
Thatovalguy is offline Find More Posts by Thatovalguy
Old Jan 16, 2005, 02:44 PM
Basil is offline
GraysonHobby.com
Basil's Avatar
Grayson, GA
Joined Jan 2003
well if everyone's is working, then i must be in the minority...ill take the proper steps off line to resolving this issue
Old Jan 16, 2005, 04:54 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Basil, is this your setup? Sounds like it is.
Can't help if you don't tell us.
Fred Bronk is offline Find More Posts by Fred Bronk
Old Jan 16, 2005, 06:57 PM
Foam Crazy is offline
Find More Posts by Foam Crazy
clever phrase here
Foam Crazy's Avatar
Atlanta, GA
Joined Dec 2002
hey basil,
i know the frustration. even a mighty company like castle creations sometimes put out a dud. one of the phoenix-25 brushless esc's i bought stuttered and sputtered and did not work nicely at all. awesome customer service and replaced it with a brand new one in 3 days flat.
don't lose heart about bargain shopping for electronics. we all do it, with mixed results. there are bound to be a dud in a good batch, and a gem in a bad batch.
seeing as it is from a local store, i'm sure they'll work with you on this purchase. good luck and see you out there.
-james
Foam Crazy is offline Find More Posts by Foam Crazy
Old Jan 16, 2005, 08:26 PM
sa-10 is offline
Find More Posts by sa-10
sa-10's Avatar
United States, GA, Kennesaw
Joined Jul 2002
Basil, what volt/ma batts are you using?
sa-10 is offline Find More Posts by sa-10
Old Jan 16, 2005, 08:38 PM
Ben Lanterman is offline
Find More Posts by Ben Lanterman
Ben Lanterman's Avatar
St. Charles, MO USA
Joined Jan 2001
The jumper pretty well describes the same systems even if different names are put on them.
I have 3 and all work fine. Good price for something that is going to hit nose first if I make a mistake.
Ben Lanterman is offline Find More Posts by Ben Lanterman
Old Jan 19, 2005, 12:52 AM
Basil is offline
GraysonHobby.com
Basil's Avatar
Grayson, GA
Joined Jan 2003
Hate to double post but the main thread is over in the Foamies which I havent figured out why it hasnt been moved here yet, but anyway, turns out Im making some progress, but still not there..
http://www.rcgroups.com/forums/showt...42#post3190442
I didnt want to make any more of this, but do to all the PMS I received, I thought I should keep a progess report.
Old Jan 19, 2005, 08:50 AM
Basil is offline
GraysonHobby.com
Basil's Avatar
Grayson, GA
Joined Jan 2003
Ok We Have A Winner!!!! Works Great!!!!
Old Jan 19, 2005, 10:21 AM
taekwondo is offline
Find More Posts by taekwondo
taekwondo's Avatar
USA, FL, Orlando
Joined May 2003
I don't understand why you didn't return it to the LHS?
taekwondo is offline Find More Posts by taekwondo
$24 brushless motor - $49 with speed control part II arx_n_sparx Foamies (Kits) 310 Dec 13, 2005 07:36 AM
24 dollar brushless motor 49 dollars with speed control! 68Strat Foamies (Kits) 691 Mar 26, 2005 03:54 PM
astro 020 brushless motor with speed control jeffery arthur Aircraft - Electric - Airplanes (FS/W) 5 Feb 21, 2005 08:16 AM
Brushless Motor with Speed control for $89 shipped CONUS BrunswickOH Aircraft - Electric - Airplanes (FS/W) 7 Apr 18, 2004 08:07 AM
Help with speed control please! rdogg32 Parkflyers 3 Jul 03, 2001 05:09 PM
