Old Jan 15, 2005, 06:33 PM
schaubro is offline
Find More Posts by schaubro
schaubro's Avatar
Colorado Springs, Co
apc props on gws 350 gearbox
Hello,
This has probably been asked before, but the search seems to return no results no matter what I put in it.
How do I get an APC E series prop to mount to an GWS EPS 350 gearbox? The smallest adapter that comes with the props seems to be to large and the prop wobbles on the shaft rather being snug.
thanks,
tim
schaubro is offline Find More Posts by schaubro
Old Jan 15, 2005, 06:53 PM
Bjorn Tore is offline
Find More Posts by Bjorn Tore
Team Visa
Bjorn Tore's Avatar
Norway
I have used the rubber bushnings that comes with the servos. Slide one or two over the shaft, use a bigger washer and when you tighten the nut then the rubber will compress and expand to fill the gap...
Bjorn Tore is offline Find More Posts by Bjorn Tore
Old Jan 15, 2005, 10:40 PM
Dennis Everett is offline
Find More Posts by Dennis Everett
Dennis Everett's Avatar
United States, CA, Ontario
Joined Mar 2002
I use thease,got em from allerc ,aeromicro..Dennis
Dennis Everett is offline Find More Posts by Dennis Everett
Old Jan 15, 2005, 10:45 PM
Joined Mar 2002
You did say e props,did you mean slowflyer?They wont work with e props,I think you will find that the slowflyer prop will work much better,....................Dennis
Old Jan 15, 2005, 11:01 PM
Trogdor is offline
Find More Posts by Trogdor
ElectriGlo Pilot
Trogdor's Avatar
Ashburn, Virginia, United States
Joined Dec 2003
You can use GWS prop savers.... the saver engages the nut on the shaft and then the shaft of the savers come in a couple diameters that fit (I think) both diameters of APC SF prop inserts.
Trogdor is offline Find More Posts by Trogdor
Old Jan 15, 2005, 11:52 PM
CSI is offline
CSI
Find More Posts by CSI
CSI
I promise, just ONE more order
CSI's Avatar
Del Rio Intl, Texas, United States
Joined Feb 2004
I use the E props all the time with no problems. There is a old thread on here with a picture of a prop saver type setup. The key was to use a piece of silicone medium size fuel tubing. Cut a piece slightly longer than the thickness of the hub, just a little should stick out of the front of the prop hub. Slide this on the GWS shaft, put the washer on, then tighten down the nut. It will compress the fuel tube that sticks out and mount the prop nice and straight. It works well and acts as a prop saver too. I don't know where the picture and thread is located, but it is on here somewhere.
Ken
CSI is offline Find More Posts by CSI
Question apc props on gws gearbox? ccchris Beginner Training Area (Aircraft-Electric) 1 Jan 04, 2006 05:14 PM
Idea Prop adapter for APC Props on GWS G-Boxes PaddyinDublin GWS (Grand Wing Servo) 8 Mar 11, 2004 03:27 AM
APC props on GWS shaft? Windysurfer Power Systems 9 Sep 27, 2003 07:12 PM
Using APC props on GWS gear boxes for IFO Nowell York Power Systems 5 May 07, 2003 11:18 PM
Using APC prop on GWS 300C gearbox? akh223 Parkflyers 13 Jan 21, 2003 08:39 PM
