Old Feb 14, 2005, 04:06 PM
nihil is offline
Find More Posts by nihil
^-- breaks stuff
nihil's Avatar
Joined Apr 2004
Originally Posted by patrickegan
Oh now I see who’s running the show
Ah yes, my faithful sidekick. The hairy one whose breath is something akin to the north end of a southbound pack mule.
Gwelan, you should see the transmitter im building into my shoe
ToyBoy, I couldnt even begin to estimate the cost on this one. Its a prototype though, and so naturally costs more than I anticipated. Figure less than $300 in materials, with a *lot* left over for other projects
I have already started the design of ap2, which may end up kitted if I can find a decent source for a few custom parts. It certainly wont be slowstick cheap, but it will use more OTS components, possbily larger in span, lighter airframe, able to carry heavier payload, and a lot easier to put together. If I can do it cheap enough, additional wing panel types might be an option as well. Straight, poly, different spans, different airfoils, etc... This is just planning stages though, if ap1 performs as expected, and I dont see much of a market for a collapsable airborne utillty type craft, I probably wont put much effort into ap2.
The lights from curtek showed up today, very nice looking kit. Now I can start wiring and get those wings covered.
nihil is offline Find More Posts by nihil
Old Feb 14, 2005, 07:07 PM
Transition is offline
Find More Posts by Transition
Professional Poster
Transition's Avatar
Minneapolis, MN
Joined Jul 2004
Lookin good.
What's the big CF hook-lookin-thing in the front of the plane for?
Transition is offline Find More Posts by Transition
Old Feb 14, 2005, 07:29 PM
nihil is offline
^-- breaks stuff
nihil's Avatar
Joined Apr 2004
Originally Posted by Transition
Lookin good.
Needed somewhere to put the camera
Old Feb 18, 2005, 12:20 AM
nihil is offline
^-- breaks stuff
nihil's Avatar
Joined Apr 2004
No new construction progress, but I have been doing vibration tests with the camera on board, and weighing components to narrow down AUW. I am going to tentatively estimate 30-32oz with 6oz of camera gear on board. I also changed the lower dampening rings to a single slice of foam. I was getting slight vibrations at around 35% throttle (testing with an intentionally unbalanced prop), and now there are none at all, through the entire throttle range. Wingloading is looking like 7-7.4oz/sq.ft, and with flaps, I am quite happy with that number. Now I just need to take some time off work to finish building the silly thing
Old Feb 24, 2005, 02:28 AM
nihil is offline
^-- breaks stuff
nihil's Avatar
Joined Apr 2004
No pictures, but I got the tail servos installed, and the radio programmed for both the V-tail and the flaperons. I am going to skin the wings without lights and get it in the air to do some flight tests, then worry about adding the lights and making it pretty. All thats left is attaching the control surfaces, skinning the wing panels, and finishing the landing gear (I might go ahead and make some snow skis for it the way the weather is looking around here).
Old Feb 24, 2005, 04:29 AM
CactusJackSlade is offline
Find More Posts by CactusJackSlade
Whadda YOU lookin' at?
CactusJackSlade's Avatar
United States, CA, Folsom
Joined May 2002
NiHil,
When you get it together how about posting some spec's... All up weight, wing area etc. Very cool project, I guess I'll have to spruce up my Depron Dragon with a little more carbon fiber!??!
Very nice, keep it up!
CJS
CactusJackSlade is offline Find More Posts by CactusJackSlade
Old Feb 25, 2005, 06:02 AM
nihil is offline
^-- breaks stuff
nihil's Avatar
Joined Apr 2004
Thanks! And yeah, you might want to CF up that monster of yours, and make it fold up a lot smaller too
I skinned the outer wing panels and got the ailerons attached tonight, will probably do the center panel and tail surfaces tomorrow. Then I guess I will be forced to do the landing gear, and I say "forced" because the scroll saw I bought for this project SUCKS. Its called "red eye" from global machinery or central machinery or something, I got it at lowes. Biggest piece of crap *ever*. Anyway, I get to use this POS to cut out the landing gear. It averages about 2.5-3 inches of cut per (fine toothed spiral type) blade with the 0.055" CF sheet.
Specs so far are:
- 52" span, 12" (constant) chord
- 4.3333333333333 sq.ft. wing area (yes really)
- AUW ~32oz w/nikon 3700 camera
- ~7.38oz/sq.ft. wingloading
- flaperons+ v-tail control
- collapsable, CF+depron, etc....
- berg6 rx
- axi 2212/26 w/10x4.7 prop (to start with)
- kokam/worley 3s1p 2000mAh lipo (rated 20C discharge, 2C charge)
- phoenix25 ESC
- 4x HS-55 servos (5x including shutter release)
- 5V, 3A BEC
- two all beef patties
- and a partridge in a pear tree
Old Feb 25, 2005, 09:42 AM
CanopicJar is offline
Find More Posts by CanopicJar
CanopicJar's Avatar
Bethel, Ohio USA (SE of Cincinnati)
Joined Dec 2004
Does the partridge affect the flight characeristics?
CanopicJar is offline Find More Posts by CanopicJar
Old Feb 25, 2005, 09:50 AM
nihil is offline
^-- breaks stuff
nihil's Avatar
Joined Apr 2004
Nope, its just there for decoration, it hangs out on the pear scented "little tree" air freshener thats hanging off the rear view mirror.
Old Feb 27, 2005, 11:18 PM
nihil is offline
^-- breaks stuff
nihil's Avatar
Joined Apr 2004
<filler post for those with posts-per-page set to 50 to keep from overloading with image loading>
Old Feb 27, 2005, 11:23 PM
nihil is offline
^-- breaks stuff
nihil's Avatar
Joined Apr 2004
Woohoo, the forums are back. Here is an update.
Wiring, grommets, tape, and stuff:
Magnet control rod linkage:
Almost looks like a plane:
The belly of the beast:
Old Feb 27, 2005, 11:53 PM
trashbug is offline
Find More Posts by trashbug
trashbug's Avatar
United States, OH, New Franklin
Joined May 2004
I was hoping for a sesame seed bun option but....
Impressive work!
I am looking forward to hearing about the test flights.
Well, back to lurking
trashbug is offline Find More Posts by trashbug
Old Feb 28, 2005, 11:22 AM
nihil is offline
^-- breaks stuff
nihil's Avatar
Joined Apr 2004
trashbug: Thanks! I just hope the silly thing gets off the ground
I have received a few queries as to how I was going to facilitate the tail control surface linkages, and to be honest, until a couple hours ago I was wondering this myself. I had a general idea, but had not worked out exactly how I was going to make it happen. I knew I would want the shaft centered to eliminate slop, so I took some CF tube and balsa strips and made a guide of sorts:
Then spent some time plowing through a box of random parts, mostly dubro bits and found a ball link that I drilled out to accept some stiff wire (first run landing gear wire from a MIA hughes500 g10 frame/canopy set for a piccolo that I never used because the heli kept falling on its arse):
A dry fit:
Ta da:
Now all thats left before flight testing is landing gear, and slapping a skin on the center panel.
Old Mar 02, 2005, 02:36 PM
Zodiac7 is offline
Find More Posts by Zodiac7
Champaign, IL
Joined Jan 2005
snip
Zodiac7 is offline Find More Posts by Zodiac7
Old Mar 02, 2005, 05:32 PM
TeamTEOR is offline
Find More Posts by TeamTEOR
Off 2 The Edge of Reality
TeamTEOR's Avatar
Scottsdale, AZ
Joined Sep 2003
Hey buddy, are the pics working?
TeamTEOR is offline Find More Posts by TeamTEOR
Build Log My first attemt at DIY AP platform build - Jumbo-Stick Nesquik Aerial Photography 13 Jan 19, 2009 11:12 AM
Yippee! Telescoping Pole AP Camera Build Thread! Bluecor Aerial Photography 438 Apr 09, 2008 10:12 PM
Discussion Help w/ SS AP Platform build in/near DC? brobak Beginner Training Area (Aircraft-Electric) 0 Aug 01, 2006 07:51 PM
Discussion Miss Stik as AP platform build P-51 fan Aerial Photography 7 Mar 12, 2006 05:23 AM
My "soon to be' new AP ship (build thread) Vince inTX. Aerial Photography 70 May 13, 2005 12:40 AM
