Old Feb 01, 2005, 03:09 AM
nihil is offline
Find More Posts by nihil
^-- breaks stuff
nihil's Avatar
Joined Apr 2004
Originally Posted by Gwelan
The pink styrofoam has the best density/weight ratio for my projects. It's less brittle than the white foam, and lighter than the extruded foam.
-Wing chord is 9.5". (Same ugly wing but fitted with Wingrids)
-Overall wing surface will be still around 510 sq inch with Wingrids
-Typhoon15/13 and a 12/6 APC-E prop
-The V-tail is inverted in this twinboom version
I still have to find an accurate method to shape the 8 small wings for the Wingrids. The hot wire method is just not accurate enough for the job.
Have you thought about sandpaper? I havent tried it on the pink foam, but sanding depron and EPP isnt too bad.
nihil is offline Find More Posts by nihil
Old Feb 01, 2005, 08:18 PM
Gwelan is offline
Find More Posts by Gwelan
Peakaboo!
Gwelan's Avatar
Sakinee, Canada
Joined Sep 2004
I just cut some sturdy board bands. I will sand the bands to form -roughly- a leading edge, before giving the bands some airfoil-like curvature. I have to make a sort of gig to give all the 8 sturdy board bands the same curvature.
Gwelan is offline Find More Posts by Gwelan
Old Feb 05, 2005, 01:22 PM
nihil is offline
^-- breaks stuff
nihil's Avatar
Joined Apr 2004
The dreaded "middle" part of a build, where your initial enthusiasm has worn off, and you arent close enough to the end to get excited...
Got the tail boom receiver tubes mounted, stop rings mounted to the booms, and holes drilled for the retaining pin:
And retaining pins with CF spring type clips:
I have wrapped the booms, and the spars with tape to make things a snug, quiet fit. Still waiting on the lights from curtek to arrive before I can skin the wings. I think next will be mounting the tail servos, receiver, and whatnot, getting the tail linkage setup, and making the tail. Same bat time, same bat channel.
Old Feb 05, 2005, 11:19 PM View Post
ededge2002
A moderator felt this post violated the following rule: Trolling (Provocation). It is temporarily hidden while ededge2002 edits it. Show it to me anyway.
Old Feb 06, 2005, 06:12 AM View Post
nihil
A moderator felt this post violated the following rule: Personal Attack. It is temporarily hidden while nihil edits it. Show it to me anyway.
Old Feb 06, 2005, 09:15 AM
nihil is offline
^-- breaks stuff
nihil's Avatar
Joined Apr 2004
Little bit more done. Here is the hinge for the tail, 4 short sections of CF tube and a sanded down 2mm CF rod. I am going to leave the pin removable so the tail can come off in two pieces. The booms fit snugly into the receivers, and trying to get them both in at the same time would be quite a pain.
And the magnets on the tail servo arms. I added a 1mm CF rod to act as a pry bar of sorts to break the magnetic bond by rocking the servo side magnet back and away from the control rod magnet.
Old Feb 06, 2005, 02:56 PM
nihil is offline
^-- breaks stuff
nihil's Avatar
Joined Apr 2004
Finally starting to look the part (propped up for dramatic effect):
Old Feb 10, 2005, 11:54 PM
nihil is offline
^-- breaks stuff
nihil's Avatar
Joined Apr 2004
Been real busy latey, no major progress, but I did get a motor mount done. When I sketched out the template, I lined up the holes wrong so the wires stick out to the side instead of down as I had intended, but I'll deal with it. If it gets to me that much, I can always make another one later.
Old Feb 13, 2005, 11:53 AM
nihil is offline
^-- breaks stuff
nihil's Avatar
Joined Apr 2004
and going and going and going.....
I re-drilled the motor mount so the wires would face down, that was bugging the hell out of me. Also got the mount for the pod done, with dampeners installed:
(ignore the paper template still on the mount, there are a couple more holes to drill)
Old Feb 14, 2005, 01:02 AM
nihil is offline
^-- breaks stuff
nihil's Avatar
Joined Apr 2004
Do de do de do...
Old Feb 14, 2005, 02:13 AM
nihil is offline
^-- breaks stuff
nihil's Avatar
Joined Apr 2004
All crammed into a tidy 16"x32"x4" package
Close up of the pod:
And one of the many reasons I never get anything done:
Old Feb 14, 2005, 09:36 AM
patrickegan is offline
Find More Posts by patrickegan
SlowStick Test Pilot
patrickegan's Avatar
Yumastan RCAPA.NET
Joined Feb 2003
Oh now I see who’s running the show
patrickegan is offline Find More Posts by patrickegan
Old Feb 14, 2005, 10:56 AM
TeamTEOR is offline
Find More Posts by TeamTEOR
Off 2 The Edge of Reality
TeamTEOR's Avatar
Scottsdale, AZ
Joined Sep 2003
Lol
TeamTEOR is offline Find More Posts by TeamTEOR
Old Feb 14, 2005, 01:12 PM
Gwelan is offline
Peakaboo!
Gwelan's Avatar
Sakinee, Canada
Joined Sep 2004
It looks like the next James Bond suitcase kit.
Nice work "Q" !
Old Feb 14, 2005, 02:13 PM
ToyBoy is offline
Find More Posts by ToyBoy
2 Mistakes Downwind
ToyBoy's Avatar
Portland, OR
Joined Nov 2004
Looking nice, Nihil. What's your estimated cost of the airframe (including material offcuts)? I know nothing about what CF sheeting and Depron cost.
ToyBoy is offline Find More Posts by ToyBoy
Build Log My first attemt at DIY AP platform build - Jumbo-Stick Nesquik Aerial Photography 13 Jan 19, 2009 10:12 AM
Yippee! Telescoping Pole AP Camera Build Thread! Bluecor Aerial Photography 438 Apr 09, 2008 09:12 PM
Discussion Help w/ SS AP Platform build in/near DC? brobak Beginner Training Area (Aircraft-Electric) 0 Aug 01, 2006 06:51 PM
Discussion Miss Stik as AP platform build P-51 fan Aerial Photography 7 Mar 12, 2006 04:23 AM
My "soon to be' new AP ship (build thread) Vince inTX. Aerial Photography 70 May 12, 2005 11:40 PM
