Old Jan 25, 2005, 06:02 PM
nihil is offline
Find More Posts by nihil
^-- breaks stuff
nihil's Avatar
Joined Apr 2004
Originally Posted by Cebola
Well, you see, I live in Brazil, and Carbon Fiber is not common , at this side of planet, can you inform where and how to buy this Carbon Fiber sheet.
Tks
Cebola
Brazil
Sierras online distributor will ship internationally, check them out here (they also have a lot of other neat stuff too ):
http://robotcombat.com/marketplace_carbonfiber.html
nihil is offline Find More Posts by nihil
Old Jan 30, 2005, 02:37 AM
nihil is offline
^-- breaks stuff
nihil's Avatar
Joined Apr 2004
Progress report
Got the ribs attached. I have been rather busy with work lately, and havent had much time to spend working on the plane. It looks like the guitar case idea might just be possible. I stacked the panels with the ribs in place, and still came in under 4"
Old Jan 30, 2005, 09:52 PM
Gwelan is offline
Find More Posts by Gwelan
Peakaboo!
Gwelan's Avatar
Sakinee, Canada
Joined Sep 2004
Hi Nihil,
I'm into some serious building too. My next plane is, roughly, a copy of the last one, except it's a twin boom pusher.http://www.rcgroups.com/forums/showt...&page=24&pp=15
The blue circles represent water noodle sections, used as a bumper (in front) an to protect the Aiptek camera (on top).
By the way, I will also replace the rounded Wingo-like wing tips with some home made Wingrids, in order to obtain a surprise free behaviour on landing.
Here is a picture of the fuselage core:
http://www.rcgroups.com/forums/attac...d=397951&stc=1
Gwelan is offline Find More Posts by Gwelan
Old Jan 30, 2005, 11:34 PM
nihil is offline
^-- breaks stuff
nihil's Avatar
Joined Apr 2004
Looks good, how big are you going to make this one? I am starting to like the pink foam, I had about half a sheet of it get blown into my backyard recently, I figured it was a sign from god.
Old Jan 30, 2005, 11:35 PM
patrickegan is offline
Find More Posts by patrickegan
SlowStick Test Pilot
patrickegan's Avatar
Yumastan RCAPA.NET
Joined Feb 2003
nihil- I would be happy to beta test when you go commercial. P.
patrickegan is offline Find More Posts by patrickegan
Old Jan 30, 2005, 11:43 PM
nihil is offline
^-- breaks stuff
nihil's Avatar
Joined Apr 2004
I hadnt really thought about kitting it, but if theres enough call for a collapsable AP plane I could see it. No more parts like those CF subframes are going to be made until I get a CNC router, or at minimum a scroll saw. The scissor technique left me with a huge blister/dead skin spot on my thumb that came off the other day. Now I have this adorable little festering wound
Old Jan 31, 2005, 06:41 AM
nihil is offline
^-- breaks stuff
nihil's Avatar
Joined Apr 2004
Got a little bit more done on the wing tonight.
Aileron servos are mounted:
Wire routing holes, aileron servo access cutouts, and magnets:
Another panicked test fit to make sure everything lines up:
The magnets work pretty well:
I am going to wire the aileron servos and the lights into single multipin connectors right at the wing joints to make assembly and disassembly easier. I dont think I would trust the magnets as contacts for the servos, and if im going to use a connector I may as well run all applicable wires through it. The magnets hold pretty good, I can shake the center panel pretty vigorously up and down with a wing panel attached below, and it doesnt fall off. If I do the same with all panels attached, and shake it from the top panel, the center panel and bottom panel fall off. I dont see it being a problem in flight unless I somehow end up with a roll rate in the 2 per second range.
Old Jan 31, 2005, 06:59 AM
Inflexo is offline
Find More Posts by Inflexo
Magicsmoke maker
Inflexo's Avatar
Australia, QLD, Charters Towers
Joined Dec 2003
Hey Nihil, I love your fridge doing the hover move... it's so close to the ground, what a mere inch or so? Very skilled.
Inflexo is offline Find More Posts by Inflexo
Old Jan 31, 2005, 09:01 AM
Yumastan RCAPA.NET
Joined Feb 2003
PLD- That's what I love about this fourm
Old Jan 31, 2005, 10:48 AM
RCFEVER is offline
Find More Posts by RCFEVER
Team HeliProz
RCFEVER's Avatar
Saint Clair, MI
Joined Jan 2004
I wonder if he moved the water melon to the lower middle shelf for an aft CG!
Looking good nihil!
Matt
RCFEVER is offline Find More Posts by RCFEVER
Old Jan 31, 2005, 11:08 AM
Yumastan RCAPA.NET
Joined Feb 2003
nihil- where did you get the Kozmo com fridge mag I have one too. P.
Old Jan 31, 2005, 05:22 PM
nihil is offline
^-- breaks stuff
nihil's Avatar
Joined Apr 2004
Oh man, I personally am the only reason kozmo stayed around as long as it did. I ordered so much garbage from them, that they gave me a staff t-shirt, which I still have, still sealed in its original plastic bag. I threw out a whole box full of their post-it notes and probably a couple hundred magnets. I still have some of the bottle openers around here somewhere. I miss them
Old Jan 31, 2005, 05:28 PM
Yumastan RCAPA.NET
Joined Feb 2003
I donít even know what they did I just got the sticker at a dot com Christmas party in S.F. years ago! P.
Old Jan 31, 2005, 05:36 PM
nihil is offline
^-- breaks stuff
nihil's Avatar
Joined Apr 2004
Kozmo used to be a delivery service for pretty much everything. Food, movies, gadgets, etc.. I was living in chicago at the time (may satan cast the fires of hell upon that miserable city), and pretty much everything I needed to survive came from kozmo for about 6 months, then they went under.
Old Jan 31, 2005, 07:29 PM
Gwelan is offline
Peakaboo!
Gwelan's Avatar
Sakinee, Canada
Joined Sep 2004
The pink styrofoam has the best density/weight ratio for my projects. It's less brittle than the white foam, and lighter than the extruded foam.
-Wing chord is 9.5". (Same ugly wing but fitted with Wingrids)
-Overall wing surface will be still around 510 sq inch with Wingrids
-Typhoon15/13 and a 12/6 APC-E prop
-The V-tail is inverted in this twinboom version
I still have to find an accurate method to shape the 8 small wings for the Wingrids. The hot wire method is just not accurate enough for the job.
Build Log My first attemt at DIY AP platform build - Jumbo-Stick Nesquik Aerial Photography 13 Jan 19, 2009 10:12 AM
Yippee! Telescoping Pole AP Camera Build Thread! Bluecor Aerial Photography 438 Apr 09, 2008 09:12 PM
Discussion Help w/ SS AP Platform build in/near DC? brobak Beginner Training Area (Aircraft-Electric) 0 Aug 01, 2006 06:51 PM
Discussion Miss Stik as AP platform build P-51 fan Aerial Photography 7 Mar 12, 2006 04:23 AM
My "soon to be' new AP ship (build thread) Vince inTX. Aerial Photography 70 May 12, 2005 11:40 PM
