Old Jan 14, 2005, 01:08 PM
ninjamonk is offline
Find More Posts by ninjamonk
Joined Jan 2005
Question
What do you use to put attach the tinfoil heatsink? CA?
Forgive me as this quite probably falls into the realm of stupid questions...
but what? Super glue? Epoxy? Elmers? The luck of the irish? Snips, snails, puppydog's tails?
yer resident dumb question asker (everyone needs one, I swear)
ninjamonk is offline Find More Posts by ninjamonk
Old Jan 14, 2005, 01:27 PM
Steve McBride is offline
Find More Posts by Steve McBride
Steve McBride's Avatar
Agra, Oklahoma
Joined Feb 2000
For plain foil, I used just a tiny bit of double sided tape. I didn't want to insulate the foil from the motor can though so just used enough to stick one end. The other end I stuck back to itself with double sided tape too.
For my subsequent aluminum heatsinks, I used aluminum duct tape and it works like a charm.
Steve
Steve McBride is offline Find More Posts by Steve McBride
Old Jan 14, 2005, 02:45 PM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
Puppy tails might be interesting to try I just used glue stick on mine. I was able to pull the heat sinks off the old motors and reuse them on the new ones, not that it would have taken long to make a new set.
Tres Wright is offline Find More Posts by Tres Wright
Old Jan 14, 2005, 05:42 PM
WhatDoIKnow? is offline
Find More Posts by WhatDoIKnow?
Atlanta
Joined Jan 2005
A little guidance for metal duct tape:
http://www.rcgroups.com/forums/showt...&page=180&pp=1
WhatDoIKnow? is offline Find More Posts by WhatDoIKnow?
Old Jan 14, 2005, 06:01 PM
Kwok_Yu is offline
Find More Posts by Kwok_Yu
Maryland, USA
Joined May 2004
Yep, I used a glue stick, also.
Kwok_Yu is offline Find More Posts by Kwok_Yu
Old Jan 14, 2005, 07:19 PM
Joined Jan 2005
WhatDoIKNow? You know lots! That is a great walkthrough and Im doin it as soon as I gets me some tape!
Old Jan 14, 2005, 09:40 PM
ukgroucho is offline
Find More Posts by ukgroucho
ukgroucho's Avatar
Stratford upon Avon
Joined Jul 2004
FANTASTIC!...I tried to make some sinks from alu foil but they did not look so good - and when I marker penned my motors black they did not seem to get above 'quite warm' so I never fitted the sinks.
After brush replacement surgery today (one motor just stopped) they seem to get much hotter so I'm off to find alu tape tomorrow.
Very nice diagram and description.
Incidentally the failed motor was the left hand unit (looking from the back) - top blades. Upon inspection it seemed to have got a little warmer than the other motor...which I also changed the brushes on. The failure was caused by one of the brushes being mangled..all chewed up. Not quite sure what happened, not overheating IMO. My wife did have a couple of newbie flights just prior to the failure, and some minor 'incidents' (mainly the dreaded "ceiling sticker") ....gotta wonder if something worked loose.
ukgroucho is offline Find More Posts by ukgroucho
CA bottles suck, what do you use? CooHead Parkflyers 22 Dec 04, 2004 12:10 PM
Looking for a small battery connector. What do you use ? RonJ Parkflyers 18 Jul 12, 2002 10:04 PM
What do you use to measure thrust? ls77 Power Systems 9 Nov 08, 2001 10:44 PM
What do you use most..... planematt Electric Plane Talk 4 Oct 01, 2001 10:48 AM
What do you use for an end insulator on a foam cutter? AW Power Systems 8 Jun 20, 2001 10:49 PM
