College Park, MD
Joined Sep 2002
Trying to equate the Kv of a motor with the actual head speed of the heli is wishful thinking. It's a measure of the no load speed.
And saying that a 3s lipo will put out 11.1 volts under a heavy load is also wishful thinking. You'll most likely see a voltage of 10 volts under load and the Kv is probably at least 10-30% less under load. The numbers you list are interesting to look at but are certainly not realistic. I'm using a Himax 2025-4200 with 8 tooth pinion and 3s Lipos in my T-Rex and the calculated head speed is 2466 RPM. The max I've measured is only 2000 RPM. And the motor runs pretty hot even with the 8 tooth pinion. It's 160 degrees after just a few minutes of indoor hovering. Here's a head speed estimator: http://www.e-helis.com/helicalc.php |
Say what ya want but that equation was dead on perfect with my Shogun... granted I use Apogee packs that can keep up and deliver whatever the motor asks too. Sure the crappy Kokam packs may not keep up but the Apogee's have no problems. Also note that thos number are true for running with zero pitch or no load on the blades. I ran my Shogun with a Himaxx 2025-3200 and a 10t pinion. At 100% throttle it would turn 2800 on the head speed. I ran it in high governor mode with the throttle backed down so that it maintained a constant 2400 on the head speed. It was the sweetest running spot I found for the Shogun and I tested many, many setups. This is why I'm having a hard time deciding on another Shogun or the Trex 450. |
| Thread Tools | |
| Discussion What kind of gear for Trex 450? | larsen2000 | Mini Helis | 2 | Oct 30, 2006 02:59 PM |
| Discussion hummingbird 3Dpro, how many teeth on main gear? | aftica | Micro Helis | 2 | Mar 11, 2006 09:25 PM |
| How many teeth on shogun belt drive pulleys? | msg73 | Mini Helis | 1 | Nov 03, 2004 11:16 PM |
| How many teeth on the main gear of a hornet? | UAVProducts | Micro Helis | 1 | Sep 27, 2004 11:12 AM |
| How many teeth on the main gear of a zoom? | UAVProducts | Mini Helis | 2 | Mar 10, 2004 04:33 PM |
