| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
Thread Tools |
| This thread is privately moderated by Fotta, who may elect to delete unwanted replies. |
#1 |
Bladerunner Links
Please use this thread to post BladeRunner related links. Please include a *brief* note describing the link.
#2 |
Here are a couple of very cool home-made bodies :
http://www.rcgroups.com/forums/showp...&postcount=758 http://www.rcgroups.com/forums/showp...&postcount=728 http://www.rcgroups.com/forums/showthread.php?t=319184 http://www.rcgroups.com/forums/showthread.php?t=318514 And, a long, Battery Thread here http://www.rcgroups.com/forums/showthread.php?t=318040 Last edited by Fotta; Jan 26, 2005 at 11:21 AM. |
#3 |
BR spinning - solution, and more info:
http://www.rcgroups.com/forums/showthread.php?t=326964 Tail Rotor Spinning Constantly http://www.rcgroups.com/forums/showthread.php?t=325338 A home made pitch gauage http://www.rcgroups.com/forums/showthread.php?t=326898 Last edited by Fotta; Feb 10, 2005 at 04:09 PM. |
#4 |
la la la la la
ha ha fotta, no one likes your post |
#5 | |
There have been 160+ views of the thread. What exactly was the point of your post? I've seen a number of questions posted by yourself which have been constructively answered - folks are taking time to spread the word and help each other. Maybe you would like to do the same rather than sniping at other peoples posts. |
#6 |
some information on N20 motor:
http://www.mabuchi-motor.co.jp/cgi-b..._ID=ff_n20papn also, a bunch of similar motors here: http://www.gws.com.tw/english/product/MOTOR/MOTOR.HTM Last edited by TueLe; Jan 17, 2005 at 01:55 PM. |
#7 |
TueLe -- I see the CN10-Plus is a close match to the FF-N20. Have you tried it out as a replacement? Thanks for posting the FF-N20 spec page - very useful! Jerry
#8 | |
Sorry, i haven't try the CN10-Plus yet, but it is a very close match to the FF-N20, as you said. |
#9 |
#10 |
R/C unconditionnal
for replacement motors i found out i could fit my Kyosho caliber m24 tail rotor motor on my br for they are of identical size but of a much better quality on my Schweizer 300(m24)i have'nt check for prices yet tough.
http://www.gpmd.com/cgi-bin/wgpprt100p?&I=KYOE07**) stock number;KYOG 1901,mfr number;70502, third from bottom of the list;Kyosho S Power Motor Tail Rotor M24 |
#11 |
R/C unconditionnal
http://www.aircraft-world.com/prod_d...system/lps.htm bottom of that page there are B2C motor charts
#12 |
if you have a spare 130-size motor with carbon brushes, you can take them out and soldier them on the N20 motors. they seems a bit chunky so you have to add spacers on the top of the shaft to prevent the comm from rubbing them.... i already tried this and it WORKS!
#13 |
R/C unconditionnal
what do you mean tuele?actually the brushes HAVE to rub against the comms otherwise motor can not run...anyway,check in the "crap" thread(started by talktodan) you might find my approach a little easier,i posted some pics to show what i did
#14 |
my bad... i didn't explain it clearly..Ok, if you take the N20 motor apart, you'd see a small disk above the comm...well, the carbon brushes i took out of the 130 size motor were a little too tall, and they slightly rub against that disk. this causes some friction and not allowed the comm to spin smoothly and work efficiently...so i added a small spacer on top of the shaft to slightly raise the comm to make more clearance while still allow the brushes to contact the comm.... hope this help.
#15 |
R/C unconditionnal
yep thanks
