| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#61 |
R/C unconditionnal
honestly i have'nt tested it yet,but as soon as i get my spare M24 tail rotor motor i will try it out since i will have 2 of these,so far i can tell you that when i hooked it to my br it seemed to be running fine but that was not a flight test,just a bench trial,by the way that motor has a capacitor and apparently it was not inclined to over heating as much as the original motor
#62 |
how about making a high powered battery with one main rotor motor bit bigger than the type already in
rotate the tail rotor to the side 90* ant have it like a normal heli but with two main rotors |
#63 |
R/C unconditionnal
i do not quite understand what you mean Carl!
#64 |
not many do
#65 | |
R/C unconditionnal
#66 |
R/C unconditionnal
the next generation of BR should come with carbon brushes motors,stronger built main rotors and have a circuitry check before leaving the factory line,in other words it should be upgraded to at least match(being better would be ideal) the copy counterpart wich right now is way ahead as far as reliability goes (for those who can't take the truth;sorry but i don't suck up to anyone...boy am i dumb...lol)
#67 | |
NooB Crash Expert
Steve |
#68 |
Restricted User
Fotta,
short list: - make it easily available in Germany/ Europe. You may sell thousands... - read carefully posts of user jogiheli on this board. you will find the cheap electronic solution for the burning motors major topic. (higher freq.) - give more response on this board, so that we may believe, that someone listen..... Stephan |
#69 |
StephanB - yes, listening. There are some excellent suggestions coming out of this thread and doubtless some will be incorporated. This has been brought up here and elsewhere - ITC must be very careful to stay within the niche that the BR is intended for in terms of complexity and very significantly, price point.
#70 |
Restricted User
Fotta,
i agree in general, but had to import my BR to Germany myself, which costs me EUR 25 for p and p and EUR 13 for customs, all together i paid around EUR 90,-- Bad price. You should look for new markets :-) Stephan |
#71 |
Well, I guess that could be classified as an improvement for the next generation. In fact Nimex is going to handle distribution in Germany and Switzerland. We're finalizing the details now.
#72 |
Restricted User
God news, Fotta! Thumbs up.
Thanks. Stephan |
#73 |
Here is my pennies worth.
I have had my BR for just 3 days, and it's a superb product! WELL DONE! The switch and charging socket are of course the weak points, I could easily see those breaking without extreme care!.. Obviously stronger body construction and longer fligh times would be more desirable that goes without saying, perhaps consier thin aluminium type foil instead of plastic blades - would that work? Is there any way the rotors could be made a smaller diameter? perhaps by using 5 blade rotors instead of 4? (when navigating doorways etc the blades are so big they could collide with doorframes etc)... What about having a small adjustable sliding weight (piece of plastic) that you can slide forward or backwards to trim the forward pitch?. mine hardly moves forward at all, so I will need to add a small piece of clay/blue tack, underneath to make it go forward! an adjustable balance weight (it would onloy need to be a tiny piece of plastic tube on one of the landing legs. A low battery indicator would be good, perhaps adding a small surface mount red flashing LED underneath on the electronics PCB might a be good idea? If it flashed green it would look like a real strobe, then changed to red to warn you to land, as the power dropped off. - The current consumption would be tiny, so do it! I haven't come accross any problems yet, but it looks like better motors are surley going to be on the list. Hope that helps. Mark |
#74 |
R/C unconditionnal
Mark fly it a few more weeks(or days depending on how long it will last...) and you might come up with some realistic suggestions,
In the mean time you should read more of this forum,it will teach you a thing or two,"SO DO IT"... lol The battery indicator means more weight and anyway you have one by watching the behavior of the BR, Smaller rotors?!?! no comments(your colliding is due to sucking effect(read forum), The switch and charging outlet,besides sometimes not being wired correctly at the factory has not been an issue so far, Stronger body construction...not an issue either, And finally yes the rotors could be made of a more resilient material but it could also mean higher cost for us consumers. louis Last edited by omdunor; Mar 21, 2005 at 12:04 PM. |
#75 |
Infinitisqrd
Mark: Take your laptop with you when you go to the "reading room", and spend endless hours reading the posts from dozens and dozens of BR owners who have already re-engineered this fine "toy" in just about every way possible. There is one thread that is over 1000 posts long, another one that is some 46 pages long at present, and, of course this part. Feel free to use the search feature - that's what it's for.
As far as bodies are a concerned, they are just a waste of time to even think about, since you will find it necessary to dump the body in order to do normal maintenance work (lubrication, motor replacement, cg shift, etc.) If you are after a "shelf queen", have at it and make a paper body or learn to vac form. No matter, a body still adds uneeded weight to a chopper that is in need of a diet right out of the box. |
| Thread Tools | |
| Discussion Charger manufacturers, time for next gen? | MrMel | Batteries and Chargers | 34 | Jul 07, 2007 09:56 AM |
| Whoops! Next Gen BR | gizmointhesky | BladeRunner Heli | 5 | Feb 05, 2005 11:18 AM |
| suggestions for next plane | LuckyArmpit | Beginner Training Area (Aircraft-Electric) | 11 | Jun 29, 2001 12:29 PM |
| Want a Biplane for next model | sgil2001 | Electric Plane Talk | 7 | Jun 14, 2001 07:12 PM |
| What transmitter for next step ?? | JensJakob | Electric Plane Talk | 1 | Jun 04, 2001 07:39 AM |
