Go Back   RC Groups > Vendors > BladeRunner Heli
This thread is privately moderated by Fotta, who may elect to delete unwanted replies.
Old Jan 15, 2005, 11:43 AM   #31
No Dear its not a new one
hotairflyer's Avatar
1. Longer lasting, easily obtainable & replaceable main motors
2. Cooling vents thru body over motors & batt
3. Consistant battery quality, replacements plug in from bottom allowing sale
of backup batteries and charging of more than 1 pack
4. TX charges to more consistant cutoff voltage
5. Mix and match different color and CLEAR paintable/customizeable bodies
that easily snap on and off (one with FLAMES )
6. A micro pager one
hotairflyer is offline Find More Posts by hotairflyer   Reply With Quote
Old Jan 15, 2005, 02:30 PM   #32
Hmmm... a thought on motor duration and trim issues...
What about a single motor system with a larger (and brushless) motor. Two gears on the motor shaft, one to turn the lower rotor in current design and one with an intermediary gear to counter-rotate the top rotor. Other than initial rotor pitch adjustment for initial trim it should require little if any future trim adjustments.
Brad
psyopper is offline Find More Posts by psyopper   Reply With Quote
Old Jan 15, 2005, 04:57 PM   #33
Brad
AFAICT It steers by varying the seperate rotor rpm, I think this would be hard with a single motor and no swashplate.
Old Jan 15, 2005, 05:03 PM   #34
Crash Master
Gene Bond's Avatar
Send a message via Yahoo to Gene Bond
What about using a 2nd tail rotor? One for vertical (F/B), and one for horizontal (R/L) ? Might be worth a shot....
Gene Bond is offline Find More Posts by Gene Bond   Reply With Quote
Old Jan 15, 2005, 11:12 PM   #35
Seems nearly everything mentioned here can be had already. But from megatech's Housefly. I agree that the BR is an awesome toy heli, but it is after all a toy. If you incorperate many of the wants into it the price will go up to probably the same as the Housefly. I would be willing to buy an upgraded model if the upgrades were made for an extra $50.00 or so added to the price tag.
Assasin is offline Find More Posts by Assasin   Reply With Quote
Old Jan 16, 2005, 01:33 PM   #36
RIP ElectRick
Jerry Combs's Avatar
The only change that I see needed ( based on my Blade Runner ) would be motors that last longer. I was able to obtain a replacement set from Paul, thanks Paul! Mine is from QVC and so has the better battery. I have gotten it flying well enough to fly through every doorway etc in my house and have a ball with it. A hearty thanks to Petter for designing such a fun model and thanks to ITC for producing it!
For those who are have problems breaking the rotors give this a try: Wrap a 1" long piece of "Blenderm" tape around the blades at the tips. Blenderm tape works much better than "Scotch" tape.
Jerry Combs
Jerry Combs is offline Find More Posts by Jerry Combs   Reply With Quote
Old Jan 16, 2005, 02:14 PM   #37
Pedestrian! Don't Shoot
Tim Wolff's Avatar
I'll second taping the outer rotor tips. I do top and bottom rotors. Scotch tape works just fine. Std. scotch tape width covers enough of the length and wrapping half way back top and bottom keeps the rotor tips from cracking and chipping when the rotors clash.
Adding the 10mm extra spacer between the rotos make a world of difference too.
Tim Wolff is offline Find More Posts by Tim Wolff   Reply With Quote
Old Jan 17, 2005, 04:22 AM   #38
Send a message via AIM to farmer911
The Solution to Forward Fight
The solution to the forward flight problem is as follows. Tape a penny to the front bottem of the Blande Runner, and this solves the forward flight problem. You dont even need to remove the plastic gard around the tail rotor, aka catkiller mod, unless you want to.
farmer911 is offline Find More Posts by farmer911   Reply With Quote
Old Jan 17, 2005, 06:34 AM   #39
uav51's Avatar
Return to Petter's original concept of using rubber bands and pulleys - no gear meshing problems, no gear wear, easier on motors and rotors, easy to replace a rubber band, very quiet, and I would assume cheaper to produce.
uav51 is offline Find More Posts by uav51   Reply With Quote
Old Jan 17, 2005, 09:24 AM   #40
MP4 Player
Hey guys,
Just a suggestion...but how about a MP4 player included too??? <LOL>
Kidding aside, really you guys have come up with some great suggestions. Can't think of anything to add. With all the positive input I'm sure the BR is here to stay!
__________
Best regards,
Ron Osinski
aka - GMRO
GMRO is offline Find More Posts by GMRO   Reply With Quote
Old Jan 17, 2005, 07:23 PM   #41
Very interesting posts - keep 'em coming....
A few responses to various issues raised in this thread.
1) I did not invent the BR- that honor falls to Petter
2) I manage ITC
3) Yes, the idea behind this thread is to allow us to respond to what *you* want in next gen BRs.
Fotta is offline Find More Posts by Fotta   Reply With Quote
Old Jan 17, 2005, 10:00 PM   #42
Infinitisqrd
FOTTA: Do you have any ballpark idea when we might look forward to the nex/gen BR ? My credit card is burning a hole in my pants !
Steve Shepard is offline Find More Posts by Steve Shepard   Reply With Quote
Old Jan 17, 2005, 10:33 PM   #43
Alan
Send a message via Yahoo to alan_gbk
Originally Posted by petter
And the inventer is also listening ....
Thank you all for good suggestions. Hopefully we will be able to put at least a few of these improvements into future models.
Petter
Hi Petter, glad to know u. Great invention!! But I have problem with the flight time. Less than 30 seconds.
Maybe I will get one Kokam Lipo soon.
alan_gbk is offline Find More Posts by alan_gbk   Reply With Quote
Old Jan 18, 2005, 03:20 AM   #44
ok now the only problem i seem 2 be having with the Blade Runner is rotor control, for some reason my Blade Runner keeps swinging to the right... any suggestions on how 2 fix the problem. Also can a nip in the blade cause this problem....
Old Jan 18, 2005, 03:03 PM   #45
Steve_Shepard - sorry all I can say is that we are working on new versions.
Discussion Charger manufacturers, time for next gen? MrMel Batteries and Chargers 34 Jul 07, 2007 09:56 AM
Whoops! Next Gen BR gizmointhesky BladeRunner Heli 5 Feb 05, 2005 11:18 AM
suggestions for next plane LuckyArmpit Beginner Training Area (Aircraft-Electric) 11 Jun 29, 2001 12:29 PM
Want a Biplane for next model sgil2001 Electric Plane Talk 7 Jun 14, 2001 07:12 PM
What transmitter for next step ?? JensJakob Electric Plane Talk 1 Jun 04, 2001 07:39 AM
Bored? Want to fight?
Join the RCGroups clan!
