Old Mar 10, 2002, 02:33 AM
Tuomas Pietinen is offline
Find More Posts by Tuomas Pietinen
F5D father
Tuomas Pietinen's Avatar
Vantaa, Finland
Joined Mar 2001
Voltage regulator as BEC?
Has anybode tried to replace the rx battery of an F5D plane with a voltage regulator from the main battery? The idea seems to work in helicopters where BEC is sometimes too weak for gyro and servos together. Just the idea of loosing that extra weight and charging in the field seems tempting.
Tuomas Pietinen is offline Find More Posts by Tuomas Pietinen
Old Mar 10, 2002, 06:32 AM
Jeff Meyers is offline
Find More Posts by Jeff Meyers
Jeff Meyers's Avatar
Fayetteville, GA
Joined Oct 2000
Hi Tuomas,
My buddy and I just sent out 10 beta samples of our new commercial switching power supply to some local E Zoners.
The product is called the Ultimate BEC.
3 amps continuous / 5 amps peak
input voltage: up to 35 volts
weight is about 2/3 oz. with long leads to cut to length.
It may not save any weight compared to the small rx packs that you are using...but no charging is required.
The primary purpose of our product is the high cell count applications where a speed control BEC is not available.
Jeff Meyers is offline Find More Posts by Jeff Meyers
BEC == Voltage Regulator? TMP00283 Electric Heli Talk 25 Nov 23, 2008 04:26 AM
Question What's everyone using as a voltage regulator? NumbSkull Sport Planes 26 Dec 21, 2006 06:34 PM
7.2-7.5V Voltage regulator Bleriot Power Systems 4 Dec 13, 2001 12:22 AM
Source for RX pack voltage regulator Ben Diss Power Systems 13 Jul 24, 2001 09:35 AM
Voltage Regulator wtghost1 Electric Ducted Fan Jet Talk 3 Jun 23, 2001 11:08 AM
