Espritmodel.com Heli Air
Old Jan 12, 2005, 04:28 PM
Think 3D :)
Aidan's Avatar
England , north lincolnshire
Joined Jul 2004
Gws Formosa Group
HI,
im starting a gws formosa group u can post your pics here and your setups or if you have had any probs or need help building it!!
Aidan is offline Find More Posts by Aidan
Old Jan 12, 2005, 05:01 PM
don't think.. just fly!!!
Littleton, Colorado
Joined Apr 2004
hey, i'm 14 too... how fast is the roll rate on the formosa?
xoon is offline Find More Posts by xoon
Old Jan 13, 2005, 08:42 AM
Think 3D :)
Aidan's Avatar
Joined Jul 2004
it depends on what movement you put on i fly with my jrxp642 with 150% travel adjustment each way and on 60% dual rate for normal flying still pretty fast roll on that but the flick the rates to 125% for a faster foll i have only got the servo ctrl rods in the middle i will try the outer hole to see what its like i looooveee this plane and fly it every night!!! on the 9.6v and 9x7 prop it climbs well as well
do you have one?? i need 2 find out how 2 post big video files 1st!
Old Jan 13, 2005, 09:01 AM
"Walk of shame" Master!!!
NoM'rcrashPlease's Avatar
West Chicago Il
Joined Jul 2004
go to "my gallery" then "upload photo" now search for your video on your computer.......and done! I believe you're allowed 30mb.?
NoM'r......
NoM'rcrashPlease is offline Find More Posts by NoM'rcrashPlease
Old Jan 13, 2005, 12:23 PM
Doh!
scurrier's Avatar
McHenry, IL
Joined Apr 2004
Cool, this is just the kind of thread i was looking for to post a question:
Where do you guys put your larger batteries in your formosa? I have a Tanic 2220 that I want to put in there. I am thinking about either removing foam or using 2 wing servos out on each wing instead of the one in the middle of it 'inside' the fuse. Anyone have experience with these methods? What do you do? Any pics?
P.S. I believe it limits you to 10 mb per file.
scurrier is offline Find More Posts by scurrier
Old Jan 14, 2005, 11:48 AM
Think 3D :)
Aidan's Avatar
Joined Jul 2004
kk ,
to get larger batterys in the battery tray you cut out chunks of foam with ouut going through and causing a hole!!!!! of course! what size is your battery approx i dont do lithum thats all heres some pics and heres a short vid!!
http://www.rcgroups.com/gallery/data...871battery.avi
Aidan,
Old Jan 14, 2005, 12:34 PM
West Chicago Il
Joined Jul 2004
Nice vid
I used Radio Shacks 1200mah 9.6V NiCad's. But my formosa was verry slugish and flight times were close to 8min(had to use WOT in order to stay in the air) with Lipos I stayed close to 10min WOT and around 15min with throtle management
This is my old formosa! I had to sell it. To fund a new one I'm ganna use inexpensive ParkZone equipment, so I can use the "combat module" with my buddies
What setup are you using Aidan?..........Can't wait for the flight video
NoM'r......
Old Jan 14, 2005, 01:10 PM
FLY PEMBREY (PFC)
milky2971's Avatar
Wales (UK)
Joined Aug 2004
Go on then lts join in..nice idea
got 2 formosa's
no. 1 is a 'bit' tatty now to say the least (blue and white)
powered by Tornado micro 6 Direct drive silent and awesome
9x7 gws slowfly cutdown to 7.5x7 and loads to choose from APC etc
Castle creations P25
Gws 4 channel reciever
2 cheap servos out of a RTF cub (it was retired once)
this as been a fantastic plane and used to do all the stuff I wont do on No.2
No.2
Himax 2025-4200 brushless in alloy gearbox
Gws 9X7 slowfly prop 'D' gearing
4 channel GWS reciever
3 GWS Naro servo's
both flown with my thumbs and a Sanwa RD6000 tranny
All the best
Trev
milky2971 is offline Find More Posts by milky2971
Old Jan 14, 2005, 01:12 PM
Weymouth, Dorset, UK
Joined Feb 2004
Hi Aidan,
I am 65 and new to foamies. I like the look of the Formosa and was pleased to find a UK thread. Other threads I have followed seem to go for high performance with Himax motors and LiPo batteries.
My concern is that foamies will break on my, usual, heavy landings. I note that some builders have strengthened the Formosa with carbon fibre and glass tape, is this necessary?
What setup are you using?
E.Gerry
Electric Gerry is offline Find More Posts by Electric Gerry
Old Jan 14, 2005, 02:42 PM
Doh!
scurrier's Avatar
McHenry, IL
Joined Apr 2004
Just because it's made out of foam doesn't necessarily mean that it's flimsy. "If it does not bend, it will break."......That being said, I think most people find foam to be pretty durable. Also, if you break it cleanly (like how a hard landing might break it), you can just glue it back together. The glue is stronger than the foam and it won't break in that spot again.
Old Jan 14, 2005, 03:14 PM
Joined Feb 2004
Thanks for your reply Scurrier,
A further question, can the motor be changed after building the model, say, if I want to go brushless (plus gearbox)?
Old Jan 14, 2005, 04:36 PM
Joined Apr 2004
Yes, the motor can be changed after it is built very easily. I have flown the Formosa with the stock 350 and with a brushless. It's a good plane either way, better with the brushless naturally.
More Formosa info here - several guys flying it with different set ups.
www.novellahub.com
Look for the Formosa under GWS Parkflyers
WolfeWind is offline Find More Posts by WolfeWind
Old Jan 14, 2005, 05:18 PM
AMA 353531
rdeis's Avatar
United States, CO, Colorado Springs
Joined Aug 2003
Originally Posted by NoM'rcrashPlease
I'm ganna use inexpensive ParkZone equipment, so I can use the "combat module" with my buddies.
There's a gadjet that will connect the combat module to standard gear, look in the DIY electronics section- a kit to solder the thing up is super cheap!
rdeis is offline Find More Posts by rdeis
Old Jan 14, 2005, 05:22 PM
AMA 353531
rdeis's Avatar
Joined Aug 2003
On heavy landings I wouldn't worry much, but a lot of people have added a glass skin to foamies like this one with fantastic results- lots of added strength and ding resistance, little added weight. Look for J Morgan's "How I finish my planes" thread in the Parkie forum. Red61's P-38 thread over there has some good info on glassing as well. It's not difficult to do and makes a *huge* difference in durability.
That said, I've broken my GWS A-10 (same foam construction) into more pieces than I care to remember (more times, too), and always been able to piece it back together pretty easily. It's still flying!
Old Jan 14, 2005, 06:18 PM
West Chicago Il
Joined Jul 2004
Kool Thanx.....
I trust more my regular equipment than PZ's stuff
Do yo happen to have any links??? The search feature is broken! LOL
thanx
NoM'r.......
Yippee! GWS formosa group ***Part 2*** Aidan GWS (Grand Wing Servo) 207 Jun 20, 2007 04:56 PM
Discussion GWS Formosa mini F3A GWS4CEO GWS (Grand Wing Servo) 20 Sep 07, 2003 04:27 PM
GWS FORMOSA mini F3A. Are you get ready to date with her!? GWS4CEO Parkflyers 42 Aug 14, 2003 10:05 AM
Who will be the first to carry the GWS Formosa? Jeffro Parkflyers 6 Aug 06, 2003 12:14 AM
GWS Formosa Video? chas1025 Foamies (Kits) 0 Jul 23, 2003 07:52 PM
