Old May 15, 2005, 07:40 PM
mildewing is offline
Find More Posts by mildewing
Salem, Oregon
Joined Mar 2005
Originally Posted by radfordc
I'm finding that weight is critical. I have two different lipo batteries. With the light one, the heli flys at 275 grams, while the heavy battery pushes the weight up to 300 grams. I can feel the difference in how the heli flys. Also, the 150 motor just gets warm with the light battery and gets much hotter with the heavy battery. I think that once I get the training gear off and can fly at less than 275 grams it will perform great.
You should get the training gear off as soon as possible. It hovers alot easier without it and for me it was the difference between 1 minute and a full pack.
mildewing is offline Find More Posts by mildewing
Old May 16, 2005, 02:32 AM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
Originally Posted by mildewing
Thank You Mr.Lin! Thats exactly the kind of info i was looking for.
It will keep running though even if i don't trim the rudder while in flight.
I will try and trim the tail RPM better while on the ground. I will also try and make some kind of turntable setup so i can adjust at hover point. Is GWS still planning on selling a setup jig like the one you showed us?
By all means.
The set up jig will continiously. But I must make her very nice as perfect as possible, otherwise some peoples will have another reason to attack me again!
GWS4CEO is offline Find More Posts by GWS4CEO
Old May 16, 2005, 02:39 AM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
You are right!
EM150 version can fly with 1050mAh for 10~12 minites, very light weight. Or 1300mAh for 13~15 minites.
Old May 16, 2005, 11:47 PM
Jarhead is offline
Find More Posts by Jarhead
The Cocky One!
Jarhead's Avatar
Modesto CA
Joined Nov 2004
Sunday Flyer
I'll be at the RCX show. Come to the GWS booth and visit. Jarhead
Jarhead is offline Find More Posts by Jarhead
Old May 19, 2005, 02:36 PM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
Bring your PHA-01 and GWS Dragonfly to GWS booth, if you have any problems?
Welcome to 2005 RCX show to see GWS booth.
Steve and me arrival late last night.
Jeff Hunter ( Jarhead ) is here in GWS USA office. GWS staffs are busy for set up booth...
You are welcome to visit GWS booth, bring your PHA-01 and GWS Dragonfly, if you have any problems? We would be more than happy to help you.
Old May 22, 2005, 06:33 AM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
PHA300 at RCX show performed by Jarhead and Steve Lo.
As above.
The happy family with GWS Dragonfly!
Jarhead set up jig.
Old May 25, 2005, 09:52 AM
TheLost is offline
Find More Posts by TheLost
My Bulldog is my copilot ..
TheLost's Avatar
Joined Feb 2004
How are you guys attaching your servos to the frame? I was using double sided tape that came with the kit... but after my last rebuild i noticed the servos would wiggle ALOT.
I then tried some hot glue... One of the servos popped off while i was doing some 'trimming' flights .
So... Whats the recommended way to secure those servos?
~Brian
TheLost is offline Find More Posts by TheLost
Old May 25, 2005, 09:53 PM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
Must use a good quality double side tape such like 3M or Japanese good one.
Do not use a bad unknown quality one!
Old May 25, 2005, 10:02 PM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
More happy customers who visit 2005 RCX.
Old May 27, 2005, 12:33 AM
Jarhead is offline
The Cocky One!
Jarhead's Avatar
Modesto CA
Joined Nov 2004
Check this out
Went out to a freinds house to deliver a slow stick and pic up his heli to sell. Did a quick demo with mine in the barn and front yard on the same flight and now he's sticking it out. Jarhead
Old May 27, 2005, 02:07 AM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
End of May 2005, GWS will finish first lot of PHA-300 production!
http://www.gws.com.tw/english/news/20050425.htm
I kept flying so many times GWS Dragonfly EM150 and EM300H with PHA-01or PHA-300.
So far I can't find the problems like I had read the posts here. But I will continiously try to find out what going on?
Old May 27, 2005, 09:56 AM
Jarhead is offline
The Cocky One!
Jarhead's Avatar
Modesto CA
Joined Nov 2004
Nice question
~Brian
Don't use junky tape. I watched one gon in because the servo fell off. Jarhead
Old May 27, 2005, 10:43 AM
tallflyer is offline
Find More Posts by tallflyer
tallflyer's Avatar
United States, CA, San Diego
Joined Jul 2002
Here is the tip of the day for mounting GWS servos or any servo to the Dragonfly helicopter frame.
Cut a piece of strapping tape out so you can wrap it all the way around the base of the servo and make the seam on the outerside.
Now stick the a piece of Scotch-Double sidded foam tape or the GWS tape that is in the kit on the the side of the servo, tape sticks better to tape then it does the servo then press in place on the frame of the dragonfly.
Will hold rock sold also make cleaning tape of your servo later alot better just remove the packing tape!
I getting ready to add a tips and tricks section to my website and this will be one of them for sure.
www.electricmicro.com
Robert
tallflyer is offline Find More Posts by tallflyer
Latest blog entry: My Official 3DR Solo Blog
Old May 27, 2005, 05:59 PM
Tonystott is offline
Find More Posts by Tonystott
Its all fun
Tonystott's Avatar
Australia, NSW, Forster
I use contact cement (eg Shoogoo or similar) because when it lets go, it does so partially, so handling gets a bit squirelly, but you don't lose control, and you can then redo it. Lots of people suggest that there is too much flx in double-sided tape, whereas contact cement holds the servo really tightly.
Tonystott is offline Find More Posts by Tonystott
Old May 27, 2005, 07:52 PM
GWS4CEO is offline
Houng-wen Lin
GWS4CEO's Avatar
Joined Sep 2001
How to upgrade your PHA-01:
1. Mail your PHA-01 (Still in good working condition, if your PHA-01 has been damaged, an additional re-condition & service fee may be applied.)
2. Download GWS User Data Form (from www.gws.com.tw). Print and mail together with your PHA-01 unit(s).
3. For each piece of PHA-01, pay US$35.00 difference for replacement of PHA-300 and handling. (Please download or contact GWS HQ* or GWS USA* for credit card authorization form.)
*For Flyers in the USA, please contact and mail to GWS USA.
GWS USA
138 South Brent Circle, City of Industry, CA 91789-3050
Richard@gws.com.tw
Tel: 909-594-4979; Fax: 909-594-8051
For flyers outside the USA, please contact and mail to GWS HQ in Taiwan.
Grand Wing Servo-Tech Co., Ltd.
153, SEC. 2, DATUNG RD. SHIJR CITY, TAIPEI 221, TAIWAN, R.O.C.
service@gws.com.tw
TEL : 886-2-86926255; FAX : 886-2-86926842
If you don't like to send CC info by web or e-mail, you may print: http://www.gws.com.tw/english/servic...m%20pha300.doc
Fill this foam send by FAX to GWS USA or GWS Taiwan HQ.
OC Heli Club techcoast Micro Helis 2 Feb 20, 2004 12:21 AM
E-Heli Club FlyNHi Electric Heli Talk 0 Sep 12, 2003 11:49 AM
Start a Heli club in NE Indiana squirrel Electric Heli Talk 1 Mar 14, 2002 06:28 PM
