Old Jan 10, 2005, 08:54 PM
austinflyer is offline
Find More Posts by austinflyer
Joined Dec 2002
Replacement parts for Aveox 3.7:1 gearbox for 36/30/2 motor
Was hit with radio interference for the first time this weekend and my spacewalker II conversion nosed into the ground. I have an Aveox 36/30/2 with an aveox 3.7:1 planetary gearbox from diversity model. The shaft on the gearbox snapped off, and I need to replace it.
I have not been able to locate replacement parts for this gearbox...anyone know who manufactures it or where a website for replacement parts might be found? Everything else looks good (motor, ball bearings, gears, etc...)
austinflyer is offline Find More Posts by austinflyer
Old Jan 10, 2005, 09:05 PM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
Ask Steve at Diversity to get you a carrier for the Neumotors version of the drive. They use the same internal parts as the one you have. The is one difference in that the output shaft is 6mm which means a different adapter might be needed as the original Aveox ones were 5mm. They will fit otherwise.
Steve
sneu is offline Find More Posts by sneu
WTB Aveox 6.7 planetary gearbox for 36 series shalo Aircraft - Electric - Airplanes (FS/W) 1 Mar 15, 2005 06:44 PM
Ebay: Aveox 1415/3Y with 3.7:1 Gearbox, NIB soareyes Aircraft - Electric - Airplanes (FS/W) 0 May 29, 2004 09:32 AM
Anybody use the Aveox 3.77:1 gearbox? astroboy Power Systems 9 Jul 06, 2003 08:20 AM
How many watts can aveox 3.7 to 1 redrive take? rparigoris Power Systems 1 Dec 12, 2002 12:51 AM
Astro 010 with Robbe 3.7:1 gearbox? led Electric Plane Talk 0 Jul 26, 2002 11:16 PM
