as some of you may know, i am going to give building the ir rx a try. most of it doesent look too hard(or at least of what i coould see by looking at the diagram in the DIY IR Lfers forum) and i want to get some things cleared up firs before building it. the only thing that looks hard in the diagram here
is that i am nervous about soldering the pins on the PIC12C509A that connect to the rudder and elevator, because there is only a small space to solder those pins to the board, and i was just wondering if for ONLY those pins, i could solder the 2 actuators directly to the pins before placing the chip on the board instead of soldering the chip to the board and risk the 2 pins on each side touching, and then place the chip on the circuit board as shown in the diagram, and solder the remaining pins to the board. would this work? also, what is the the "sensor" and "link" for? what do these things go to? do i need these? also, where do i get small enough wire to make 200ohm actuator coils? does this rx come with a built in speed controller?
btw, are there any schematics and parts lists for this transmitter yet?
also here, what is the blue wire in the middle of the board connecting?
it doesent show it in the blue schematic that i showed above. please be patient with me on these questions, i want to clear up EVERYTHING on my mind before attempting this, and make the chance of failure as little as possible
