Old Jan 10, 2005, 04:06 AM
djgorman23 is offline
Find More Posts by djgorman23
djgorman23's Avatar
Joined Dec 2004
Wire gauge versus amps ?
Is there a guide which says how many amps a particular wire gauge (e.g. 16 awg) can handle??
djgorman23 is offline Find More Posts by djgorman23
Old Jan 10, 2005, 05:07 AM
snowjackal is offline
Find More Posts by snowjackal
When in doubt whip it out
French Polynesia
Joined May 2004
It depends on what wire your are planing on useing. below is what I use for referance using Silicone Rubber High strand count wire
13AWG Wire
100+ amps
14AWG Wire
50-75+ amps
16AWG Wire
25-74 amps
18AWG Wire
up to 25 amp
20AWG Wire
up To 20 amp
22AWG Wire
up to 10 amp
Your milage may very!
-SNoWJackal
snowjackal is offline Find More Posts by snowjackal
Old Jan 10, 2005, 05:13 AM
jswjimmy is offline
Find More Posts by jswjimmy
Whatever happens..Happens
jswjimmy's Avatar
Sanford, Maine, United States
Joined Aug 2004
this is from www.cheapbatterypacks.com
13=100+amps
14=50 to 75 amps
16=25 to 74 amps
18=less than 25 amps
20=less than 20 amps
jswjimmy is offline Find More Posts by jswjimmy
jswjimmy is offline
jswjimmy's Avatar
Joined Aug 2004
13AWG Wire
100+ amps
14AWG Wire
50-75+ amps
16AWG Wire
25-74 amps
18AWG Wire
up to 25 amp
20AWG Wire
up To 20 amp
22AWG Wire
up to 10 amp
-SNoWJackal
you beat me to it...
Old Jan 10, 2005, 05:26 AM
French Polynesia
Joined May 2004
yeah and we got the info from the same sorce! www.cheapbatterypacks.com
-SNoWJackal
Old Jan 10, 2005, 05:51 AM
djgorman23's Avatar
Joined Dec 2004
cool, thanks guys
Old Jan 10, 2005, 09:49 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Just in case anyone wants a more complete chart and a few formulars aloso.
http://www.powerstream.com/Wire_Size.htm
Charlest
Old Jan 10, 2005, 10:13 AM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
I have noticed battery/esc wiring and connectors getting warm when I pulled 8+ amps though servo type connectors and 26 guage wires on 720 mah 8-cell NiMh packs. It probably better to use larger guage wire and connectors in this range.
E-Challenged is offline Find More Posts by E-Challenged
Old Jan 10, 2005, 10:56 AM
Southern Pride
Originally Posted by E-Challenged
I have noticed battery/esc wiring and connectors getting warm when I pulled 8+ amps though servo type connectors and 26 gage wires on 720 mah 8-cell NiMh packs. It probably better to use larger gage wire and connectors in this range.
That would be pushing the limits for sure. Most of my 860 and under Li Po packs have 20 gage and JST connectors. The only Li Po packs which I have purchased which had smaller than 20 gage wires were Kokams.
Charles
Old Jan 11, 2005, 10:34 PM
roccobro is offline
Find More Posts by roccobro
Watts your motivation
roccobro's Avatar
San Bernardino, CA
Joined Aug 2003
I always went by the following chart. I think it came from Backyard flier or Q&E Flier.
Justin
roccobro is offline Find More Posts by roccobro
Old Jan 11, 2005, 11:13 PM
Helicool is offline
Find More Posts by Helicool
Helicool's Avatar
Toronto, ON Canada
Joined Jul 2002
How about paralell wiring?
I probably know better then to ask this, but I am curious to see what others think.
For arguments sake, lets say that I have a 3S2P Pack at 11.1 volts (nominal). While each 3S pack is capable of delivering 15A continuous, when I paralell 2 banks of 3S I can now draw 30amps.
So... which of the following is "correct'?
- 18G wire for each bank, "Y"ing to 16G
- Paralell using the tabs on each bank and just use 16G wire (Can the tabs take 30A?)
- just use 12G cable for everything just to be safe.
I tend to think #3 is the "Safe" way to go - how do you all feel?
Helicool is offline Find More Posts by Helicool
Old Jan 11, 2005, 11:21 PM
roccobro is offline
roccobro's Avatar
San Bernardino, CA
Joined Aug 2003
The first is what I'd do. But then again I have the odd chart that I go by.
Justin
Old Jan 11, 2005, 11:33 PM
martyh1104 is offline
Find More Posts by martyh1104
Joined Dec 2004
just remember, the bigger the wire the better the current flow and the lower the temp of the wire due to less resistance of the wire. I would also go with your first choice.
Marty
martyh1104 is offline Find More Posts by martyh1104
Old Jan 11, 2005, 11:42 PM
roccobro is offline
roccobro's Avatar
San Bernardino, CA
Joined Aug 2003
And 12 gauge is REALLY big for 15 amps!
Justin
Old Jan 11, 2005, 11:45 PM
Chamkeeper is offline
Find More Posts by Chamkeeper
Joined Nov 2004
This is VERY important the in amp ratings of wire. If you go to your local electronics store to buy wire, the standard stuff will not be either high strand count or silicone rubber coated. Therefore, the amp ratings will be FAR less than mentioned above.
Chamkeeper is offline Find More Posts by Chamkeeper
Wire gauge amps PenguinWaddle GWS (Grand Wing Servo) 16 Oct 02, 2014 11:04 AM
Question DIY CDrom motor WOT current versus wire gauge kinsa_manka Power Systems 4 Jun 16, 2005 06:17 AM
What gauge wire for 15 Amps continuous... ajm201 Power Systems 5 May 03, 2005 09:59 PM
Question Wire Gauge and Amps Question Lobo Power Systems 9 Feb 05, 2004 08:30 PM
Wire gauge??? planecrash Electric Plane Talk 3 May 09, 2001 04:35 PM
