This thread is privately moderated by glue_sniffer, who may elect to delete unwanted replies.
Old Dec 02, 2009, 10:38 AM
Montag DP is offline
Find More Posts by Montag DP
Sink stinks
Montag DP's Avatar
Joined Apr 2005
Originally Posted by KJMDES2 View Post
The only way I know to do an eliptical wing in SW is to cheat. I've been on SW since '98, and its not yet in my toolbag.
One way, if you are just messing around, is to add taper to an extruded root section. It means you can only use a root section, no tip.
Other than that, when I need to CNC an eliptical wing, I build it in SurfCam. SW is fine for most wing design, but eliptical has eluded me also. I would be intersted to hear about a method also.
Cheers,
Kevin
It's easy in Rhino. Draw the leading edge, trailing edge, and do a 2-rail sweep on the root airfoil and you're good to go.
Montag DP is offline Find More Posts by Montag DP
Old Dec 10, 2009, 09:11 PM
ptxman is offline
Find More Posts by ptxman
Calgary, AB, Canada
Joined Oct 2002
Somebody, somewhere said for the purposes of flying surfaces you actually want more airfoil sections stationed down the length of the planform & incorporated in the sweep. Otherwise this (2-rail) technique tends to distort the section airfoil outboard as its being influenced by the planform shape itself. (ie as opposed to using a single root). Fair enough. But its a very simple matter to use the scale & orient button-click commands to put as many sections as you like to attain tighter control. Or for that matter, smoothly blending different airfoil sections which serves aerodynamic purposes. Here are some 'eliptical-based' wing surface examples just for show. Note the one surface has smooth, upswung tips ala F5x wings.
ptxman is offline Find More Posts by ptxman
Old Dec 11, 2009, 03:15 PM
Sink stinks
Montag DP's Avatar
Joined Apr 2005
I haven't checked it out in detail, but wouldn't the 2-rail sweep automatically scale the airfoil heightwise based on the distance between the two rails in order to maintain the same cross-section shape?
Old Dec 11, 2009, 06:23 PM
ptxman is offline
Calgary, AB, Canada
Joined Oct 2002
I think... the swept surface is influenced by the relative deviation of the rails. Without intermediate (rib) control, the fitted surface iso-contours may take on a different orientation.
In the orange surface I only used the root rib, see how the cross-chord iso-contours are drifting? In the green surface I included more 3d scaled rib stations in the same rail sweep. See how the cross chord iso-contours are now better lined up paralel to the normal chord direction. So the issue is with 'only root' you may not end up with the same section airfoil (meaning perpendicular to airstream) on the outboard panel, where it generally it counts more aerodynamically. When it comes to high perf stuff, this becomes an issue.
Once upon a time I did do a comparison by sectioning the root-only surface & it was indeed (very) slightly different. I guess 'how' different is a function of the particular airfoil + planform combination. As mentioned, its such a simple thing to place more control sections its not a big deal. Where it gets interesting is blends of different airfoils, sym>semi-sym varying camber, washout/twist etc. There you hav eno option but to place appropriate sections & loft through them.
Im not sure what to make of the zebra striping business, but I know funky tips always seem to create some weird results. Supposedly need even more control (rib stations) out there as the tip is deviating more. Maybe someone more 3d experienced can comment.
On rectangular or straight taper planforms, it doesnt matter I dont think. The single rib develops a proportional surface.
Old Dec 23, 2009, 03:37 PM
jjmouris is online now
Find More Posts by jjmouris
Needs to do 52 legs !!
jjmouris's Avatar
Verenigd Koninkrijk, Fareham
Joined Aug 2008
Very interresting. Thanks for the heads up ptxman!
Oh and if any of you guy's do requests. I would like to see the following done in simple 3D to help design a plane around it;
Hyperion DS09 servo with one sided horn as seperate part
Neu 1512 series motor with gearbox
Optional;
Thunder Power 5S 3850mah and 6S 3300mah packs
Files need to be usable in Rhino.
Joe
jjmouris is online now Find More Posts by jjmouris
Old Dec 23, 2009, 04:38 PM
GLM is offline
GLM
Find More Posts by GLM
GLM
AMA 209854
GLM's Avatar
Check Six!
Joined Oct 2003
Optional;
Joe
Here is 9 gram servo modeled on an HXT900 from HK. I hope it works for you. Not familiar with the Hyperion servo you mentioned.
Cheers!
Gary
Hang on - need to make zip file for you.
GLM is offline Find More Posts by GLM
Old Dec 23, 2009, 04:50 PM
jjmouris's Avatar
Joined Aug 2008
The Hyperion is almost the same shape as the Dymond D60 or Ripmax SD150, both are only 9mm thick.
Old Dec 23, 2009, 05:06 PM
GLM is offline
GLM
GLM
AMA 209854
GLM's Avatar
Check Six!
Joined Oct 2003
Oh,
3d scaled to 9mm thick (.354)
Cheers!
Gary
Old Jan 12, 2010, 01:38 PM
jjmouris's Avatar
Joined Aug 2008
Ok, great to see this is now in it's own RC Groups section!!! Good stuff!!!
So how about a proper file of a Hyperion DS09 servo?!
Old Jan 12, 2010, 01:42 PM
Kwok_Yu is offline
Find More Posts by Kwok_Yu
Maryland, USA
Joined May 2004
A very basic Dremel 200 in sketchup. It's not perfect, but the dimensions are right. I drew it for a cnc machine, I was drawing. -Kwok
Kwok_Yu is offline Find More Posts by Kwok_Yu
Old Jan 12, 2010, 11:38 PM
philba is offline
Find More Posts by philba
Prop Buster Extraordinaire
philba's Avatar
Seattle
Joined Aug 2009
There is a sketchup parts thread in the scratch built foamies section.
Free 3D! Sketchup Parts!
You can also find a number of parts in the Google 3D warehouse/ Try searching for aircraft to see a lot of models. Unfortunately, most of them weren't made with actual building in mind but worth a look.
philba is offline Find More Posts by philba
Old Apr 17, 2010, 09:51 AM
dpot is online now
Find More Posts by dpot
dpot's Avatar
France, Auvergne, Lapalisse
Joined Dec 2005
TURNIGY motors
dpot is online now Find More Posts by dpot
Old May 08, 2010, 11:26 AM
Hix is offline
Hix
Find More Posts by Hix
Hix
London UK
Joined Jan 2007
Tower Pro 9g SG90 Servo 2d dxf 3D step and Iges
Hope they're fo use to some of you.
Hix is offline Find More Posts by Hix
Old Jun 14, 2010, 02:29 PM
sfahrner is offline
Find More Posts by sfahrner
sfahrner's Avatar
USA, AZ, Chandler
Joined Apr 2007
Originally Posted by Smash View Post
Hi!
If Someone has an elliptical (not trapezoidal) wing model in SolidWorks please upload it!
I try to draw an elliptical wing since a week but I can't do it
I just discovered this forum, so forgive me if I'm just replowing old ground..
Attached is quick Spitfire-like wing with an elliptical leading and trailing edge using a NACA 2412 airfoil. Just a simple swept solid body...
I think the key to making this type of thing work is to insure that the swept profile is correctly constrained, i.e., it maintains its proportional shape throughout the sweep. For airfoils, defining the swept profile as a single proportional spline usually works pretty well.
The attached .pdf show SW screen captures of the basic model. If anyone is interested, I'd be glad to go over the process step by step...
sfahrner is offline Find More Posts by sfahrner
Old Jun 22, 2010, 06:21 AM
Konstantin S. is offline
Find More Posts by Konstantin S.
KIT Designer
Konstantin S.'s Avatar
Padova Northern Italy
Joined Jun 2010
To designers 1\2 A a necessary element - G-Mark 0.4cc modify.3dm - 1.85MB
Konstantin S. is offline Find More Posts by Konstantin S.
Idea How About a CAD "Parts Bin?" glue_sniffer CAD/CAM 159 Aug 07, 2015 11:52 PM
Data Rhino CAD parts bin. vintage1 The Builders Workshop 2 Aug 27, 2009 09:18 AM
For Sale Esky/Eflight Parts Bin Garage Sale Adroc3905 Aircraft - Electric - Helis (FS/W) 7 Jul 06, 2009 11:42 PM
For Sale cleaning out parts bin.... dragrcr Aircraft - Electric - Helis (FS/W) 8 Aug 19, 2008 10:19 PM
With all the publicity against File Sharing ... what about alt.bin newsgroups?!? Peter Khor Life, The Universe, and Politics 5 Feb 10, 2004 11:21 PM
