This thread is privately moderated by glue_sniffer, who may elect to delete unwanted replies.
Old Sep 10, 2008, 10:24 AM
dpot is offline
Find More Posts by dpot
dpot's Avatar
France, Auvergne, Lapalisse
Joined Dec 2005
have a look at the units in the format menu
dpot is offline Find More Posts by dpot
Old Sep 10, 2008, 11:51 AM
bmutlugil is offline
Find More Posts by bmutlugil
bmutlugil's Avatar
Turkey
Joined May 2002
I was wrong in stating that A9CAD had no object snap, these had to be turned on from the graphical menu on the left of the working window..
dpot,
If you were addressing me, there is no format menu or unit selection in A9CAD, or I can not find it.. and there may be a misunderstanding; it is not the drawing size but the file size that is getting larger - as below.
A 900KB ACAD2000 file has turned into 5.23 MB when saved from A9CAD in DWG format, and to 21.7 MB when saved in DXF format - and there is no other choice. Maybe getting the DXF back into ACAD could cure the problem, I wil try that..
Bulent
bmutlugil is offline Find More Posts by bmutlugil
Old Sep 28, 2008, 05:26 AM
Smash is offline
Find More Posts by Smash
Joined Nov 2005
Hi!
If Someone has an elliptical (not trapezoidal) wing model in SolidWorks please upload it!
I try to draw an elliptical wing since a week but I can't do it
Smash is offline Find More Posts by Smash
Old Sep 29, 2008, 10:57 AM
dpot is offline
dpot's Avatar
Joined Dec 2005
that is one of the hardest thing to draw it is harder then a spring
this is as close as i can get
Originally Posted by Smash
Hi!
Old Oct 02, 2008, 05:09 PM
flyguy93 is offline
Find More Posts by flyguy93
Atlanta, GA
Joined Oct 2007
Is there anything for Autodesk Inventor? It is available to me through school so it would be great if I could get some rc stuff for it.
flyguy93 is offline Find More Posts by flyguy93
Old Oct 05, 2008, 05:19 AM
dpot is offline
dpot's Avatar
Joined Dec 2005
will it import dxf format and What rc stuff are you in to
Old Nov 07, 2008, 07:46 PM
Mike James is offline
Find More Posts by Mike James
Mike James's Avatar
Anchorage, AK.
Joined Jan 2003
Parts
For a few years, I've offered this little set of RC parts, free, from my 3D Catalog page. (Scroll down to the bottom, at http://www.nextcraft.com/3d_catalog_000.html )
There you'll find a free download of these parts, in DXF format:
Fixed landing gear, with wheel pants, generic 2-stroke engine, generic 4-stroke engine with tuned exhaust, fuel system with tubing, servos, plug-in type wing attachment hardware, 2-blade prop and spinner, Klett-style tailwheel assembly, etc.. This might help some of you visualize your models quickly, if you don't want to make those parts.
Enjoy!
Mike James is offline Find More Posts by Mike James
Old Dec 19, 2008, 06:00 AM
bmutlugil's Avatar
Turkey
Joined May 2002
I prepared an Autocad drawing of the Hitec HS-50 servo (2 views). See attached in zipped DXF format.
Bulent
Old May 06, 2009, 09:13 PM
plane_tech is offline
Find More Posts by plane_tech
Theoretical balsa dust maker
plane_tech's Avatar
United States, MI, Kalamazoo
Joined Oct 2007
does anyone have a .dwg file of a .46 2 stroke in 2d? perferably side, top and front view?
plane_tech is offline Find More Posts by plane_tech
Old May 18, 2009, 04:38 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Motor mount for brushed and brushless.
I thought this might be useful to someone, so have unusually included actual laser cutting details on the sheet.
Its a result of a day's head (and butt)) scratching on how to make a mount suitable for both a geared brushed cobalt motor and a typical brushless.
2 degrees down and right thrust is built in..
Extra packing shims can be cut from the template to shim a shorter brushless further forward.
Hope its of use.
Old Jun 22, 2009, 08:02 PM
bluesky123 is online now
Find More Posts by bluesky123
Crash=change of flying medium
bluesky123's Avatar
Boulder, CO
Joined May 2002
3D model of OS .55 AX
Here's is my contribution, a 3D CAD model of OS .55 AX in SAT (version 10.0) format. SAT models can be imported in most 3D cad systems--I intentionally saved the model in an old SAT version, so that even old CAD systems could read it.
The only discrepancy with the real motor is a different carburetor (I used a 3D carburetor model from MDS .58).
Hope someone can use this model.
Boris
bluesky123 is online now Find More Posts by bluesky123
Old Sep 04, 2009, 04:22 AM
KJMDES2 is offline
Find More Posts by KJMDES2
KJMDES2's Avatar
Joined Feb 2007
I have a fairly good collection of HiTec servos, batteries, etc. They are all done in Solidworks. I can output IGES or STEP for those who are interested.
Cheers,
Kevin
KJMDES2 is offline Find More Posts by KJMDES2
Old Sep 04, 2009, 04:38 AM
KJMDES2 is offline
KJMDES2's Avatar
Joined Feb 2007
The only way I know to do an eliptical wing in SW is to cheat. I've been on SW since '98, and its not yet in my toolbag.
One way, if you are just messing around, is to add taper to an extruded root section. It means you can only use a root section, no tip.
Other than that, when I need to CNC an eliptical wing, I build it in SurfCam. SW is fine for most wing design, but eliptical has eluded me also. I would be intersted to hear about a method also.
Cheers,
Kevin
Old Oct 08, 2009, 12:18 AM
plane_tech's Avatar
Joined Oct 2007
Como 40
Greetings all...
Drew this up for a project I was working on and thought I would share it. I know its not that common of an engine anymore, but it might do in place of a generic .40 size engine.
It is in a AutoCad .DXF file format.
Old Oct 30, 2009, 04:20 PM
heli_bee is offline
Find More Posts by heli_bee
Joined Mar 2005
Solidworks
Kevin,
A friend and I have just started in Solidworks and we are both interested in any parts files that you wish to put on the forum.
Martin.
heli_bee is offline Find More Posts by heli_bee
Idea How About a CAD "Parts Bin?" glue_sniffer CAD/CAM 159 Aug 07, 2015 11:52 PM
Data Rhino CAD parts bin. vintage1 The Builders Workshop 2 Aug 27, 2009 09:18 AM
For Sale Esky/Eflight Parts Bin Garage Sale Adroc3905 Aircraft - Electric - Helis (FS/W) 7 Jul 06, 2009 11:42 PM
For Sale cleaning out parts bin.... dragrcr Aircraft - Electric - Helis (FS/W) 8 Aug 19, 2008 10:19 PM
With all the publicity against File Sharing ... what about alt.bin newsgroups?!? Peter Khor Life, The Universe, and Politics 5 Feb 10, 2004 11:21 PM
