Old Jan 08, 2005, 04:11 PM
Wayne R. Russ
Wayne R. Russ
Guest
n/a Posts
Air Tool Oil After Run Oil
Hello Everyone,
On Jul 25 1997 Lyman Slack posted in reply to someone else,
You sure are making your life complicated! Engine guru Clarence Lee notes
that
as an after run oil, MARVEL AIR TOOL OIL is all you need. Period. He assumes
you also
run out the fuel in your engine after your last flight.He does recommend,
however, that
for prolonged storage, you pickle the engine in a 50/50 mix of MATO and ATF
(auto
transmission fluid).
After reading the whole thread, it sounds like good advice. My question is;
Does it have to be Marvel brand Air Tool Oil ? AutoZone has Campbell
Hausfeld ST1270 Air Tool Oil.
It is , Specially formulated with rust inhibitors, anti foaming and anti
gumming additives to maximize tool performance.. Not designed for use in air
compressors.
Is there something mystical about Marvel, or will other Air Tool Oils work
as well ?
Any thoughts, or advice will be Greatly Appreciated,
Wayne R. Russ
Old Jan 08, 2005, 06:11 PM
Martin X. Moleski, SJ
Guest
n/a Posts
Re: Air Tool Oil After Run Oil
On Sat, 8 Jan 2005 14:07:39 -0500, "Wayne R. Russ"
I'll bet that would work just as well.
>as well ?
I don't think Marvel publishes a complete recipe for its oils.
Maybe they've got a "secret ingredient" that others haven't
found. Dunno.
Marty
Old Jan 08, 2005, 08:11 PM
TX_QBALL@webtv.net
TX_QBALL@webtv.net
Guest
n/a Posts
I couldn't find the Marvel stuff and had to settle for Senco...Using it
for bout a year,no problem yet.
When I bought the Jet engine from Dub he strongly recommended the Marvel
Air Tool stuff but just haven't been able to find it.
Good luck
Mike Norton
Mike Norton
Guest
n/a Posts
Hausman is what I use. Seems to work - things don't rust.
"Wayne R. Russ" <NOwaynerrSPAM@olg.com> wrote in message
news:10u0dfj79fnum06@corp.supernews.com...
> Hello Everyone,
> that
> assumes
> you also
> however, that
> ATF
> (auto
> is;
> air
> compressors.
> as well ?
> Wayne R. Russ
Old Jan 08, 2005, 10:11 PM
Paul McIntosh
Paul McIntosh
Guest
n/a Posts
My guess is that ANY name brand air tool oil will do the job. They are all
made with the same function in mind: prevent corrosion and keep the parts
lubed.
Paul McIntosh
http://www.rc-bearings.com
> Hello Everyone,
> that
assumes
> you also
> however, that
ATF
> (auto
is;
air
> compressors.
> as well ?
> Wayne R. Russ
Old Jan 09, 2005, 06:11 AM
bear
bear
Guest
n/a Posts
I got some at O'Reilly's Auto Parts. Interestingly they didn't have any on
the shelf. When I asked about it they had plenty in the back room. Go
figure. . . .
-rodger
<TX_QBALL@webtv.net> wrote in message
news:11536-41E05D81-80@storefull-3358.bay.webtv.net...
> Good luck
Lyman Slack
Lyman Slack
Guest
n/a Posts
Hey Wayne --
MATO is basically Marvel Mystery Oil with an anti-rusting additive
(ever noticed how much an air tool sweats?). Off hand, I'd bet any Air Tool
Oil would be about the same. MATO is usually available at auto parts stores,
rental tool companies, and even some auto paint supply stores. The nice part
is that it comes in handy
4 oz. size.
Cheers -- \__________Lyman Slack_________/
\______AMA6430 IMAA1564___/
\____Flying Gators R/C______/
\__Gainesville FL _________/
Visit my Web Site at: http://www.LymanSlack.com
> Hello Everyone,
> is;
> air
> compressors.
> as well ?
> Wayne R. Russ
Old Jan 09, 2005, 12:11 PM
Wayne R. Russ
Wayne R. Russ
Guest
n/a Posts
Ok Thank You everyone,
I got the Campbell stuff. It came in a 8 oz. bottle and I believe it was
approx. $1.50, so it didn't drain my wallet.
Your advice has been Very Much Welcomed.
Thank You again,
Wayne R. Russ
> Hello Everyone,
> that
assumes
> you also
> however, that
ATF
> (auto
is;
air
> compressors.
> as well ?
> Wayne R. Russ
Old Jan 10, 2005, 06:11 PM
Elmshoot
Elmshoot
Guest
n/a Posts
>Lee notes
>that
>you also
>however, that
>(auto
>compressors.
>as well ?
>Wayne R. Russ
He specifically mentions MATO as the product then he mentions" ANY" ATF so I
would think that he ment it the way I typed. MATO and ant ATF 50-50 for long
term storage. Cheap insurance in my opinion.
Sparky
Old Jan 12, 2005, 12:11 AM
pcoopy
pcoopy
Guest
n/a Posts
Wayne,
Walmart has Marvel Mystery Oil, but if you don't want to fool around
with after run oil, buy Omega (Morgan Fuels) and read the label.
Phil AMA609
Wayne R. Russ wrote:
> Hello Everyone,
notes
> that
assumes
> you also
recommend,
> however, that
and ATF
> (auto
question is;
anti
in air
> compressors.
work
> as well ?
> Wayne R. Russ
Old Jan 12, 2005, 10:11 AM
Six_O'Clock_High
Six_O'Clock_High
Guest
n/a Posts
I have never had much success finding Marvel Mystery Oil when I thought
about it, but I have been using Rislone for 20 some odd years with no
problems. A couple of very hard run engines needed new bearings, but in
each case I shut down in the rain and probably failed to burn off the left
over fuel or oil the engine.
"pcoopy" <pjcoopys@aol.com> wrote in message
news:1105505315.878892.182790@c13g2000cwb.googlegr oups.com...
> Wayne,
> Phil AMA609
>> Hello Everyone,
> notes
>> that
> assumes
>> you also
> recommend,
>> however, that
> and ATF
>> (auto
> question is;
> anti
> in air
>> compressors.
> work
>> as well ?
>> Wayne R. Russ
After Run Oil rabosr Fuel Plane Talk 28 Jun 12, 2015 03:44 AM
