Old Jan 07, 2005, 08:19 PM
mrbaseballny's Avatar
Joined Sep 2004
Importing jpeg,bmp,etc->tracing in Autocad 2005
Does anyone here that uses Autocad 2005 know how to import a picture file and then trace the images to create a CAD file. I have some formers that I want to put into Cad for scaling, outputting to a laser/cnc router and I can't for the life of me find a command in Autocad 2005 on how to import a picture file.
I did a web search on google,yahoo and MSn but I couldn't find any references to this command. I guess I'm not searchign for the right command
Any help would be greatful
Mrbaseballny
mrbaseballny is offline Find More Posts by mrbaseballny
Old Jan 07, 2005, 08:25 PM
Spfld, Tn (Ma)
Joined May 2004
Can't say for sure about 2005, but in both 2002 and 2004 you would use;
Insert->Raster; then browse for your image.
The insert button should be across the top.
Jim
PS: I scale the image once I have it in AutoCad, then trace on a separate layer
Jim52 is offline Find More Posts by Jim52
Old Jan 07, 2005, 11:37 PM
Think Thermals!!!!
SoCalGliderFlyr's Avatar
Costa Mesa, California
Joined Mar 2004
The Help in Acad is tricky but you can find what you need. As Jim says use the Insert/Raster for a jpeg or tiff. You can also insert other vector file formats that are listed below the "Raster".
Knowing what scale to enlarge it too is important. I've been given four sheets of parts with out a scale rectangle on any of the images. A real PITA to match them up.
SoCalGliderFlyr is offline Find More Posts by SoCalGliderFlyr
3D modeling - Spitfire Mk.IX in AutoCAD PLANE FREAK The Builders Workshop 73 Jun 29, 2011 08:49 PM
Discussion How to get the wings sheeted in Autocad 2005???? Mato The Builders Workshop 1 Nov 03, 2006 04:46 PM
Dimension changing in AutoCAD? drbird The Builders Workshop 7 Nov 01, 2002 02:47 PM
What funtion do i use in autocad 2000 to split a plan into even sections? Barrett Power Systems 3 Jan 23, 2002 10:57 AM
