Old Mar 08, 2002, 12:09 PM
bpu6999 is offline
Find More Posts by bpu6999
racine, wi
Joined Jan 2001
how to reverse rotation with a brushless motor
ah, but the catch is that it has a hall sensor. Its the astro 805k motor. Whish leads do I switch???
bpu6999 is offline Find More Posts by bpu6999
Old Mar 08, 2002, 01:27 PM
Chris True is offline
Find More Posts by Chris True
St. Mary, Maryland, United States
Joined Dec 1996
It is not that easy. Aside from switching leads you need to reset the timing and the backplate is glued on with a laquer material. Best to send it back to Astro.
Alternatively you could switch to a sensorless ESC...
Chris True is offline Find More Posts by Chris True
Old Mar 08, 2002, 06:06 PM
Ray Lowinski is offline
Find More Posts by Ray Lowinski
Ray Lowinski's Avatar
Napoleon, Ohio
Joined Dec 1996
Just go sensorless, switch any two leads and go the other way. Worked great with my Mega when adding the GB.
Keep 'em hummin'
Ray
Ray Lowinski is offline Find More Posts by Ray Lowinski
Discussion how do you reverse the shaft on a brushless motor? suitcase Power Systems 4 Jun 18, 2007 06:12 AM
Discussion Help with brushless motor running reverse... tnsfrk Power Systems 5 Sep 10, 2006 04:34 PM
How good is GWS gearbox when use with brushless motor hty GWS (Grand Wing Servo) 32 Apr 04, 2005 01:27 PM
FS: Voyager E with brushless motor fchristian Aircraft - Electric - Airplanes (FS/W) 0 May 10, 2002 07:38 PM
JR. Voyager with brushless motor misskimo Aircraft - Electric - Airplanes (FS/W) 3 Mar 07, 2002 06:16 PM
