Go Back   RC Groups > Aircraft - Electric - Airplanes > Scale Electric Planes
Old Mar 08, 2002, 08:00 AM   #1
Bristol Scout prototype kit flies
Hi,
For all those who expressed an interest in the soon to be released kit for a s400 Bristol Scout, I have finished building the prototype kit.
Her maiden flight was made in far from ideal weather conditions but she coped well. No final attempt at trimming was made because it was just too windy, but more flights are to come.
Here's how she looks, she's 34.5" span and weighs 21 oz. ready to fly.
  • Name: bsk1.jpg
PETERRAKE is offline Find More Posts by PETERRAKE   Reply With Quote
Old Mar 08, 2002, 08:08 AM   #2
The model is powered by a 6volt 400 in a Mini Olympus gearbox and uses 7x500 AR cells. For more acurate information about release dates contact Kurt Bengtson at :- kurt@bengco.com
  • Name: bsk2.jpg
Old Mar 08, 2002, 08:11 AM   #3
Just to prove she flies.
  • Name: bsk4.jpg
Old Mar 08, 2002, 08:23 AM   #4
bob h
Peter,
As usual it looks great When and from who will the kits be available? Bob H
Bob H is offline Find More Posts by Bob H   Reply With Quote
Old Mar 08, 2002, 10:01 AM   #5
Bob,
Kurt Bengtson will be handling all sales, see his e-mail address above.
Thanks for the kind comments
Pete
Old Mar 08, 2002, 01:11 PM   #6
Designing on the edge
Bengtson's Avatar
Send a message via AIM to Bengtson
I think I should mention here the plans for this model. Now, that Pete has taken our prototype kit and we have found the bugs in the plan, I hope to get the changes to our laser cutter service by next week. I believe that we can see a release date of somewhere in early to mid April. The kit will include all necessary laser cut parts, CAD designed plans, complete instructions, neoprene/balsa/ply wheel kit and a CD with building instructions, and other goodies. We are aiming to produce the top tier in quality kits available. Tentative price for the kit is $69.95 We will sell it on the net and we can take all major credit cards.
Bengtson is offline Find More Posts by Bengtson   Reply With Quote
Old Mar 08, 2002, 03:00 PM   #7
Great kit design Kurt, beautiful building job Peter! It looks so good flying!I hope you have lots of success selling the kit.
Airnut 2 is offline Find More Posts by Airnut 2   Reply With Quote
Old Mar 08, 2002, 04:28 PM   #8
Bengtson's Avatar
George,
Thank you for the comments. BTW, the design is Pete's. I modified it a little to make kitting it easier, but the credit for the plane should go to Pete.
Old Mar 08, 2002, 04:45 PM   #9
Will the kit have ailerons, or if not, do you have any comments about if they could/should be added by the builder? In flying similar sized bipes lately I have found myself wishing for ailerons.
4 Scale is offline Find More Posts by 4 Scale   Reply With Quote
Old Mar 08, 2002, 05:13 PM   #10
Bengtson's Avatar
Greg,
No, the kit does not have ailerons. Pete can tell you about the flying qualities of this plane. From what Pete told me, this plane really flies very well without them. As for adding ailerons, I suppose that it could be done. I can imagine a center servo in the wing with a snake system to wing tip ailerons. A torque rod arrangement could also be done. I will check to be sure that the position of the scale ailerons is on the plan.
Old Mar 08, 2002, 08:11 PM   #11
Ian Easton's Avatar
Another beauty Peter. I hope the one I'm working on will look as good as yours. I'll post pictures when it's complete.
Ian Easton is offline Find More Posts by Ian Easton   Reply With Quote
Old Mar 08, 2002, 08:59 PM   #12
Gerry Markgraf's Avatar
Beautiful job Peter. What is the paint you used on the top surfaces? It has the right look to it - a slightly purple hue that I noticed on the Shuttleworth Bristol F2B. I have decided your pre WW I & WW I designs just fit the bill for any future building I start. I have an Eastbourne Monoplane framed up (I confess - its a Pat Tritle kit) and have Peter Rake WWI plans spread all over the spare room. Now I will wait to order the Scout kit as well. I'm still getting over the heartbreak of looking all over the LA area for the latest issue of Flying Scale Models to get that wonderful BE 2c plan and finding an obscure little French lightplane instead. Its a cute little plane, but just not the same thing as the BE 2c. Oh well. I will live with the disappointment until the next issue comes out. I called the distributor here in LA and will attempt to get back issues and a subscription to assure a steady supply of your designs. Perhaps when I retire in a few years I will use your design philosophy and a few old peanut scale plans to scale up some other types.
Gerry
Gerry Markgraf is offline Find More Posts by Gerry Markgraf   Reply With Quote
Old Mar 09, 2002, 01:48 AM   #13
max z's Avatar
Peter, what a beautiful plane. The Bristol Scout is one of my earliest scale favourites, ever since an article with 3-views and color schemes was published in "Air Enthousiast" in the early eighties. I ordered a plan from Radio Modeler (I think) and started construction, but I got stuck on producing a decent cowl. Later I found the perfect cowl by chance in a shop near London, but then my interests had already shifted to something else. Seeing your pictures sort of rekindles it!.
Max.
max z is offline Find More Posts by max z   Reply With Quote
Old Mar 09, 2002, 01:51 AM   #14
Hi All,
Thanks for the nice remarks about the little Bristol Scout.
Gerry,
The upper surfaces are actually Olive Drab Litespan, rather than paint. It's not quite as purple as the photo shows, must have been the light conditions, but it does have a greyish purple tinge and looks acceptable. Some people liked the Sablier, but like you many were disappointed. The BE2c plan definitely is in the next issue.
Greg
Ailerons would work fine, and be fairly easy to add. They are on all four wings, so I would suggest a micro servo in each lower wing panel. Take the leads to a Y lead in the fuselage and use wire links between top and bottom wings. Being a one piece model makes it that much easier.
Pete
Old Mar 09, 2002, 08:57 AM   #15
Ron
Nice looking plane Pete. If it flies like it looks, you have a winner.
Keep up the great work.
Ron is offline Find More Posts by Ron   Reply With Quote
Bristol Scout: Further Flights PETERRAKE Scale Electric Planes 298 Jul 07, 2008 09:04 PM
Sold Bristol Scout Laser Cut kit 34.5" span The Don Aircraft - Electric - Airplanes (FS/W) 0 Jan 08, 2007 09:34 PM
Discussion Peter Rake Bristol Scout prototype portablevcb Scale Electric Planes 18 Nov 18, 2006 09:28 PM
Bristol Scout Short Kit Bengtson Scale Electric Planes 3 Aug 31, 2002 07:07 PM
Bristol Scout Availability Bengtson Scale Electric Planes 0 Mar 21, 2002 01:26 PM
11
