Old Jan 06, 2005, 09:28 AM
Joined Sep 2002
What to Expect from LiPos
I have a stock Hummingbird II with birdseed battery, Century gyro, GWS Receiver and Century ESC/Mixer.
I'm considering moving to LiPo power but I am not sure what to expect.
My local store sells two LiPos of interest
2 Cell, 700mAh, 8C, weighing 31g
2 Cell, 1000mAh, 10C, weighing 42g
Now the LiPo is 7.4V compared with the birdseed's 8.4V, so there is less power but less weight - so how will the performance compare?
The LiPo is 700/1000mAh compared with the birdseed's 600mAh - so how will the flight times compare?
Finally, the 700mAh and the 1000mAh LiPos are the same price. Obviously the 1000 has a greater capacity but it is also heavier, so which battery would give the best performance/duration combination.
Please note that I don't want to spend much on my HB (it's just a bit a fun for when I can't take my Raptor out) so please don't suggest upgraded motors, brushless setups etc.
Thanks for any advice.
Nigel
nheather is offline Find More Posts by nheather
Old Jan 06, 2005, 11:14 AM
A man with too many toys
United States
Joined Feb 2001
The 2-cell 1000 MAH would be perfect. A capacity in the 1000 to 1350 range seams to work out best for micro helicopters.
You should get about 12-15 minutes with a 1000 MAH battery. LiPo batteries last longer if you don’t run them down to much – I would suggest that you fly about 10-12 minutes then land and recharge.
I hope you are aware that you need a special charger to charge a LiPo battery.
RC Man is offline Find More Posts by RC Man
Old Jan 06, 2005, 05:32 PM
Joined Sep 2002
Yes I was aware that I need a LiPo charger but many thanks for the warning anyway.
Out of interest how does the weight saving alter the flight - better performance, better duration or both.
For example a 600mAh birdseed last about 6 minutes realistically. For arguments sake if I were to fit a 600mAh LiPo would the duration be the same or greater - and would the heli fly better in terms of performance and response.
Cheers,
Nigel
Discussion What to expect from Hobby in next 6 - 9 months.. mcf34 Micro Helis 1 Feb 17, 2007 06:19 AM
Question what to expect from new telmaster electro ejreiss11 Electric Plane Talk 8 Nov 17, 2006 01:06 PM
Question What to expect from my CD motor? ecologito Power Systems 25 Apr 10, 2005 01:20 AM
Question what to expect from my CD rom motor? ecologito Power Systems 4 Feb 17, 2005 07:21 PM
What to expect from a larger prop size? AirAmerica Electric Plane Talk 6 Dec 06, 2002 02:26 AM
