Old Jan 06, 2005, 07:21 AM
Jim_W is offline
Find More Posts by Jim_W
Jim
North Alabama
Joined Mar 2004
Tanics, to buy or not to buy...I'm hung up on....
I'm hung up about buying lipos without the balancing taps! I guess I'm worrying too much about this, as most other brands DO NOT have this feature, and are being used by the majority.
I had my first lipos ordered from a vendor here on the forum, but did not get them! (I won't get into that now!)
Someone recommend another good brand for me please! I have a new ICE charger and am in the market for 830 to 1500 mah 2s1p size lipos.
Thanks, Jim.
Jim_W is offline Find More Posts by Jim_W
Old Jan 06, 2005, 07:39 AM
Aio_1 is offline
Find More Posts by Aio_1
Aio_1's Avatar
Ireland, Kildare, Leixlip
Joined May 2002
I think taps are a good idea.
Tanic and Polyquest both provide them.
I would be inclined to go with one of these 2 from what I've experienced and heard.
For small cells the Kokam 340s perform well (although a bit heavy) but at larger sizes I think Tanic and Polyquest will out-perform them. TP seem pretty good but like Kokam they don't supply taps (at least not last time I checked). The Apogee cells are pretty similar to Polyquest but I don't think they supply taps (they may be the same cell type, I can't remember but I think the answer is in the links below)
There are some good threads on the this forum to help you decide (if you want to put the research time in - it can take a while).
For starters I'd suggest a look at the following 2 threads.
They get a bit heated but have a lot of good data too (particularly the first one). They start out about Kokam's specifically but end up having just as much in them about other brands.
Exploding the LIPO high hischarge myth
New High Discharge Kokams
Aidan
P.S.
Don't get the idea I'm picking on Kokam - these just happened to be the most informative threads I could find among my recent subscribed threads.
Aio_1 is offline Find More Posts by Aio_1
Old Jan 06, 2005, 08:11 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
I have read that Tanic and Apogee are made by the same manufacture and both of these brands have a very good reputation. I like the fact that Tanic uses JST connectors for the taps and they have a very neat secure means of installing them or at least this vendor does.
http://www.rcgroups.com/forums/showp...93&postcount=4
If you want taps for sure I would always check the fine print and be very specific due to the fact that some brands only come with taps on larger packs.
Charles
Old Jan 06, 2005, 08:29 AM
unbalanced prop is offline
Find More Posts by unbalanced prop
unbalanced prop's Avatar
Washington, PA, USA
Joined Aug 2003
It seems as if more and more manufacturers are going to taps and or balancers on their packs. Apogees now have "voltage ports"
http://www.pfmdistribution.com/
And TP now has a "balancer connector" on their new packs.
http://www.tppacks.com/products.asp?cat=10
Tanic has always had taps and I think that Polyquest has always had them also. I guess word is getting out to make a "safer" product.
Doug
unbalanced prop is offline Find More Posts by unbalanced prop
Old Jan 06, 2005, 08:50 AM
Southern Pride
Doug
I would like to point out that Poly Quest does not have their Tap on smaller packs and the same can be said of others.
It seems to me that the taps are become more popular / necessary as the higher C capable cells are being pushed to their limits. Cells which are not used at above 70% of their maxi mun safe discharge rate and that are not discharged below 3.7 volts be cell resting(stable open voltage) do not tend to go out of balance.
Many problems can be avoided by just not trying to operate on the raged edge.
If you must have 8 amps. then a 700-730 rated 10C continues with burst to 12C will get you by but it will be short lived if you use a lot of WOT.
If you went up to 1200 size cells rated at 10C then you would only have to operate them at 70% to get the same 8 amps.Your flight time would just about double and the pack will last a lot longer.
Charles
Old Jan 06, 2005, 09:09 AM
Washington, PA, USA
Joined Aug 2003
Charles
Not sure what you mean by smaller packs as I have several 850 Polyquest 3S and 830 Apogee 3S packs that have taps. A buddy of mine also has a Tanic 830 3S pack and if I remember right , it has taps.
I do agree completely with your 70% theory. My cells that aren't pushed too hard seem to last longer then the packs that are used on the "ragged edge". Hopefully the newer generation of lipols will allow them to be pushed harder without going out of balance.
Doug
Old Jan 06, 2005, 09:19 AM
Southern Pride
Charles
Doug
Well according to this site
http://www.batterystation.com/lithiu...gPQ2S-0600.htm
Poly Quest 600 packs do not have taps ,850 and above do.
I have never seen a pack of between 320-820 with taps unless it was a custom made one. Part of this maybe due to the increased cost of material and labor to add taps .
Charles
Old Jan 06, 2005, 09:29 AM
Washington, PA, USA
Joined Aug 2003
You are probably right as I have no personal experience of packs under 830mah. Although to me, some of those size packs get pushed pretty hard and maybe should have taps. I fire is a fire, and a small pack could burn a house down the same as a big pack.
Doug
Old Jan 06, 2005, 09:31 AM
Aio_1 is offline
Aio_1's Avatar
Joined May 2002
Originally Posted by everydayflyer
I have read that Tanic and Apogee are made by the same manufacture and both of these brands have a very good reputation...
I have read suggestions that these and also Polyquest were the same cells from the same cell manufacturer. However this has been denied for at least one of them. Tanic I think.
If you want to check have a read through the threads I posted earlier. I think Vintage1 had pretty solid information on the subject. If I remember correctly both Apogee and Polyquest are 'Enerland' cells and Tanic are not. This is just from memory so best to check it out if it's important to you. As you say they all have a good reputation so I wouldn't worry too much about whether or not they are identical. For comparable cells from these brands I'd base my choice on cost and availability of taps.
Aidan
Old Jan 06, 2005, 09:40 AM
Southern Pride
Li Pos by manufactors?
http://www.rcgroups.com/forums/showp...1&postcount=14
Charles
Old Jan 06, 2005, 09:52 AM
scurrier is offline
Find More Posts by scurrier
Doh!
scurrier's Avatar
United States, IL, Naperville
Joined Apr 2004
Thanks, Jim.
Is there any reason that you are avoiding Tanics? If you are worried about it what's wrong with just buying them and getting it over with?
For what it's worth, my opinion is you need taps.
scurrier is offline Find More Posts by scurrier
Old Jan 06, 2005, 09:55 AM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
Tanic Packs Made with Pride and Craftsmanship in USA
Tanic and Apogee R made in the same factory APL according to Brian
Tanic packs R built with pride and craftmanship in America by Americans
Can anyone say that about any other brand.
hall woo is offline Find More Posts by hall woo
Old Jan 06, 2005, 10:13 AM
Jason M is offline
Find More Posts by Jason M
20 years on RCG!
United States, IL, Champaign
Joined Dec 1996
Only some Tanic packs are built in the US - many of the smaller ones I believe are assembled by APL in Malaysia. At least thats the information thats been posted...
ALL Thunder Power packs are built in America by Americans. I believe they are currently the only ones still assembling their entire product line of LiPo packs in the US.
Jason M is offline Find More Posts by Jason M
Old Jan 06, 2005, 11:39 AM
mt_100 is online now
Find More Posts by mt_100
I have no friends
United States, MI, Holland
Joined Dec 1996
What about the Great Planes packs that have the seperate charge connectors, aren't they good?
mt_100 is online now Find More Posts by mt_100
Old Jan 06, 2005, 11:49 AM
Southern Pride
Originally Posted by mt_100
What about the Great Planes packs that have the separate charge connectors, aren't they good?
Well that depends on your meaning of good.
First off the separate charging plug only goes to a device which prevents the pack from being charged to the wrong voltage . A 2 cell can only be charged to 8.2 volts , a 3 cell to 12.6 v. etc. It does not balance the pack,and it does not provide any means to check cells or balance them.
I have a few of these which I purchased from Towers and the cells look like Kokams and I have had very bad performance from the Electri Fli and Kokams.
Read the first post here very carefully
http://www.rcgroups.com/forums/showthread.php?t=315205
Part of my data at
http://www.rcgroups.com/forums/showp...9&postcount=22
Charles
Discussion Who do you buy or not buy from? Milesc Dock Talk 26 Feb 05, 2007 12:16 AM
Discussion Looking for opinions to buy or not to buy??? jettvolks Micro Helis 0 Oct 23, 2006 10:28 PM
Question To buy or not to buy a Triton charger. Mad-Man Slope 45 Oct 11, 2006 05:12 PM
Discussion to buy or not to buy a CORONA????? wingfoot Electric Heli Talk 19 Aug 25, 2006 08:13 PM
Alert GWS Retracts... to buy or not to buy? Lucke Scale Kit/Scratch Built 12 Jan 26, 2006 08:07 AM
