Old Jan 05, 2005, 10:00 PM
Raptor00! is offline
Find More Posts by Raptor00!
United States, CA, Bakersfield
Joined Aug 2000
Post your TENSOR motor/battery set-up
As topic says. Post your combo to include battery used and flight times and if your happy!!
Al
Raptor00! is offline Find More Posts by Raptor00!
Old Jan 05, 2005, 10:08 PM
Bigrc2 is offline
Find More Posts by Bigrc2
Omaha, Ne
Joined Sep 2004
E-FLITE 370 outrunner 1080kv with a cc 10 and 3 cell 700 Kokam. 10 minutes maybe. But I'm looking at getting some Thunder Powers. From what I hear they are buy far a better battery. As far as the moter goes. I couldn't be happier!! Bigrc2
Bigrc2 is offline Find More Posts by Bigrc2
Old Jan 05, 2005, 10:16 PM
Michael Bogh is offline
Find More Posts by Michael Bogh
Michael Bogh's Avatar
Mount Vernon Skagit, Washington, United States
Joined Dec 2001
Happy?
Damn skippy thrilled is more like it.
Eflite 370 1200 1080 kv, Apogee 830 3sp, 10X4.7, CC-10, HS-55's
Flight times on a fresh off the charger are 18 mins of 3D...off the charger overnight, kept in the garage, more like 13 minuets.
Here's the video, in case you haven't seen it.
http://www.greatthingswa.com/stuff/TENSOR4D_01.wmv
Good luck,
Michael Bogh is offline Find More Posts by Michael Bogh
Old Jan 05, 2005, 10:21 PM
Bigrc2 is offline
Omaha, Ne
Joined Sep 2004
So Mike I take it you like the 830s.
Old Jan 05, 2005, 10:23 PM
Joined Aug 2000
Good stuff Mike!! Also, add any mods or reinforcements. It's so hard reading through every post that comes through.
Al
Old Jan 05, 2005, 10:50 PM
Boss248
Boss248
Guest
n/a Posts
What prop are you using on the E-Flite 1080??..same as Mike?? I will be doing a Tensor real soon and I am at the power plant decision stage. I fly almost 100% outdoors..do the 1080's have enuff power for good outdoor stuff??
Boss
Old Jan 05, 2005, 10:52 PM
TailTwister is offline
Find More Posts by TailTwister
Currently between sponsors...
TailTwister's Avatar
Menasha, WI USA
Joined Jun 2003
Axi 2208/34, CC P-10, Tanic 830mah 3S, 10x4.7 APC sf (GWS too)prop.
I'd guess 10 minutes of flight. My Tensor weighs 10.25 ounces.
TailTwister is offline Find More Posts by TailTwister
Old Jan 05, 2005, 10:55 PM
Bigrc2 is offline
Omaha, Ne
Joined Sep 2004
More than enough and ya I'm also using a 10x4.7 prop. You wont be disappionted!! Plus the 1080 gives you the option of 2 cells for indoors 3 for out!!
Old Jan 05, 2005, 11:48 PM
JonMann is offline
Find More Posts by JonMann
Clayton, CA
Joined Oct 2002
E-Flite 370-1360, CC 10 amps ESC, TP 860 2 cell and 3 cell packs, 10x4.7 prop. 10 miniute flight times, packs take about 700maH recharge after 10 min flight.
I've also flown the E-Flite 370-1080, prefer the feel of the 1360 motor. It is definitely better with 2cells. Sacrifice a little (very little) in flight time, but the extra RPM is nice.
Love this plane!!!
JonMann is offline Find More Posts by JonMann
Old Jan 05, 2005, 11:49 PM
Joined Dec 2001
YAYAYAYAYA, smartarse, I have 2 more comming along with the 1050 to try in my somewhat less than stable EF Yak. I really do love the Apogees, they are so light and compact.
One of the best "heads up" I've gotten here, thanks Bigrc2.
Old Jan 06, 2005, 12:07 AM
mjws is offline
Find More Posts by mjws
Airdrie, AB Canada
Joined Sep 2004
Axi 2208/34 9x4.7 3s apogee 830's, 2s TP700's. Nice on 3s inside and out, a little weak on 2s outside in the breeze.
Same motor 10x4.7 Very nice indoors and out. The larger prop helps 2s significantly.
I've thrown 3s 830's, 1200's, 1550's on this plane. Unlike a shocky the larger packs don't really seem to bother it with all the extra wing. Lighter is better inside.
mjws is offline Find More Posts by mjws
Old Jan 06, 2005, 10:17 PM
MTwallet is offline
Find More Posts by MTwallet
Gotta have more cowbell!!
MTwallet's Avatar
Clawson, MI USA
Joined Sep 2002
Hey Guys, I'm gettin ready to build my Tensor and was thinking about getting the Eflight 370 1080 but then I looked at the weight, 1.6oz. I have a Razor MHv.2 in a Gws Gb that weighs 1.5oz. and I'm sure it has more power than the outrunners. Even with the stick it will prolly be a push in the weight dept. I think that's the way I'll do it. So why don't more people look at this as an option? Am I missing something?
MTwallet is offline Find More Posts by MTwallet
Old Jan 06, 2005, 10:20 PM
Bigrc2 is offline
Omaha, Ne
Joined Sep 2004
How much does the razor cost?
Old Jan 06, 2005, 10:31 PM
Boss248
Boss248
Guest
n/a Posts
Good question Mike...I was wondering the same thing.. ..it may be that the amps needed for the Razor will require the bigger 860mah and above to get the Razor cranked but I doubt that with that kind of power full throttle shots will be very short but butt loads of fun... I think if I were going to go that route, I would drop the prop size to a GWS 10/4.7..6.6:1 gearing, Himax 2015/5400, CC10 and some HES 2003 servos and I bet a 2s or 3s 860 TP 2nd Gen would be sweet..
I don't have a Razor but I do have several 2015/5400's that weigh just a little more but I would bet would do the job nicely.
Also after really studying the foam used on the Tensor I believe it's the same foam that comes sandwiched between the paper backing on SturdiBoard..it's almost 4.5mm just like the SB foam center, feels exactly the same in texture, strength, and stiffness..if this stuff is not the same as the SB foam center then I'll eat my hat.....
Boss
Boss
Old Jan 06, 2005, 10:32 PM
Boss248
Boss248
Guest
n/a Posts
Last time I looked it was about $90.00.
Check out: www.allerc.com
Boss
Discussion Post your Blade CX Radio Set-Up Joe Simmons Coaxial Helicopters 2 May 04, 2007 02:13 PM
Post a Pic Of Your T-Rex Electronics Set-Up! STaNgXs Mini Helis 37 Jan 23, 2006 01:16 PM
Feild battery set up Ed Franz Batteries and Chargers 2 Sep 13, 2003 11:05 AM
MiniFlash Motor, Battery and Set up questions Aobid Parkflyers 3 May 15, 2003 10:20 PM
ECO8 Motor/Pinion/Battery Set-up Combination Kou Electric Heli Talk 1 Sep 29, 2001 09:37 PM
