Old Jan 05, 2005, 05:11 PM
Bill Bunn
Bill Bunn
Guest
n/a Posts
Fuel proof aluminum spray paint?
Can anyone recommend a good fuel proof aluminum spray paint?
Some of the paints that I have used in solid colors are fuel proof, but the
aluminum or silver is iffy.
Is there a source for spray cans of butyerate (sp?) dope?
Old Jan 05, 2005, 09:11 PM
Paul McIntosh
Paul McIntosh
Guest
n/a Posts
Re: Fuel proof aluminum spray paint?
See if you can find SnJ Products Spray Metal. I used to fly with the guy
who made it. It was targeted at the plastic modelers but worked great on
slimers too. You can even burnish it with the available powder to get the
aged panel look. I finished an entire EZ P-51 with the stuff and it LOOKED
like aluminum!
Paul McIntosh
http://www.rc-bearings.com
"Bill Bunn" <bbunn@highstream.net> wrote in message
news:10ton09l2eg3e19@corp.supernews.com...
the
Old Jan 05, 2005, 11:11 PM
strathboy
strathboy
Guest
n/a Posts
Tremclad comes in aluminum and is fuelproof. Not sure if you can get it in
the USA if that's where you are. An earlier post mentioned Rustoleum which
is similar and I believe it is made in the USA.
"Paul McIntosh" <paul@mcintoshcentral.com> wrote in message
news:41dc888c$0$48129$ed2619ec@ptn-nntp-reader02.plus.net...
> LOOKED
> like aluminum!
> Paul McIntosh
> the
Old Jan 06, 2005, 03:11 AM
Paul McIntosh
Paul McIntosh
Guest
n/a Posts
The metallic Rustoleums are not fuel proof.
Paul McIntosh
"strathboy" <strathboy89@rogers.com> wrote in message
news:CvmdnRJTyaQ8NUHcRVn-3A@rogers.com...
guy
on
the
> > LOOKED
> > like aluminum!
> > Paul McIntosh
> > the
Old Jan 06, 2005, 01:04 PM
Ledbetter is offline
Find More Posts by Ledbetter
Central California
Joined Aug 2003
I have used automotive factory match paint with good results. Like you get in spray cans at Pep Boys. I use Honda Silver for aluminum.
Ledbetter is offline Find More Posts by Ledbetter
Old Jan 06, 2005, 01:11 PM
Ted Campanelli
Ted Campanelli
Guest
n/a Posts
On 1/5/2005 4:28 PM Ted shuffled out of his cave and grunted these great
(and sometimes not so great) words of knowledge:
"Dupli-Color Truck and Van" paint is available in silver. This is an
acrylic lacquer that is as close a match as you will be able to find
(unless you custom mix) for SolarTex silver/aluminum covering. The cans
come with the adjustable vertical/horizontal spray tip that put down a
very nice, smooth, even coat with no "spitting". It is available at
Wal-Mart for about $4 for an 11 oz can. I can verify it is fuel proof
with 10% nitro. I don't know about higher nitro since all I use is 10%.
Another possibility would be the LusterKote silver/aluminum. Personally
I do not like the way that sprays though. I have had quite a bit of
"spitting" with the Lusterkote paints.
I would suggest buying a can and seeing if it is aluminum color enough
for you. It is not the shiny silver, but a lot closer to aluminum in color.
Old Jan 06, 2005, 11:11 PM
strathboy
strathboy
Guest
n/a Posts
Ted, I too have had less than desirable results with Lusterkote. The
coverage was poor and I also experienced the spitting problem.
"Ted Campanelli" <tcamp@grumpyoldmen.com> wrote in message
news:08eDd.11587$_X7.1311@newssvr33.news.prodigy.c om...
> Another possibility would be the LusterKote silver/aluminum. Personally I
> I would suggest buying a can and seeing if it is aluminum color enough for
>> the
Old Jan 20, 2005, 09:11 PM
Aeromodler
Aeromodler
Guest
n/a Posts
Rustoleum aluminum is not fuelproof at all. I sprayed a set of floats with it
and I had to use an overcoat of clear. Even the clear was tricky to apply. It
tended to disolve the rustoleum. So use thin coats. When it was finished the
color was an exact match for used Alclad aircraft aluminum. Good luck
fuel proof paint? spencer6891 Fuel Plane Talk 5 Dec 30, 2004 11:42 PM
Anyone used bright aluminum spray paint? sammy Scale Kit/Scratch Built 2 Dec 01, 2004 03:58 PM
Question Fuel proof spray bombs? robd The Builders Workshop 3 Apr 25, 2004 02:17 PM
Fuel Proof Spray Paints Danny The Builders Workshop 6 Mar 27, 2003 12:52 PM
