Old Jun 19, 2001, 05:27 PM
rayc is offline
Find More Posts by rayc
rayc's Avatar
Indianapolis, IN, USA
Joined Jun 2000
how to build a vaccum forming box?
I need to build a samll VFB to make plastic cowls, etc... Anyone have plans or can point me to URL.
I have only found 2 sites that describe them. I just need something simple and cheap. Less than $20 in parts if possible.
I read several thread here on ezone but none of them where vacuum boxes they just pulled the hot plastic over the mold.
I need to make a cowling from my 24" wing span P40-D.
Thanks, Ray
rayc is offline Find More Posts by rayc
Old Jun 19, 2001, 09:01 PM
bruce ryan is offline
Find More Posts by bruce ryan
USA, WA, Bellevue
Joined Apr 2000
I built a box 17" square and about 3" high, because that was the size plastic I use. The top needs to be peg board material, then you need a picture frame like structure to hold the plastic in, which then fits over the box neatly. The plastic is held in the frame with staples and tape(for air tightness).Of course you need a hole in the box, that matches your shop vac hose. reverse the shop vac hose , put the plastic in it's frame in the oven- watch it, it will sag after a bit then you are ready. more or less.
bruce ryan is offline Find More Posts by bruce ryan
Old Jun 20, 2001, 12:18 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
If I might suggest that you buy some electronic 'perf' board to use as the platten for your vacu-former, being 1/16 epoxyglass and having hundreds of tiny holes it's very cheap ($5) and perfectly suited to the purpose..
Bare is offline Find More Posts by Bare
Old Jun 20, 2001, 03:03 PM
Aero-BearAZ is offline
Find More Posts by Aero-BearAZ
Aero-BearAZ's Avatar
Mesa, AZ USA
Joined Mar 2001
Ray,
A few issues ago in RCM (march 2001, page 26) David Anderson wrote an article that talked about a "two pass mothod for forming crystal clear canopies". He said that he used an aluminum cake pan for his vac-box. Sounds cheap to me. Get one that has a flat flange around it, the kind that has a matching lide that slides on. Quite honestly I'm not sure if they make that type anymore, I was considering stealing my mothers. The reason for the flange around the outside is that it will allow you to clip/bolt/screw the perforated top to it. Just make sure that it is sealed. Cut an appropriate sized hole in the side for the vac source plug your shop vac in and make sure it seals well and there ya go! On a larger unit you might need to put a brace across the inside of the box to keep the vac from collapsing the top. The Electronic perf board sound perfect too!
Tom
Aero-BearAZ is offline Find More Posts by Aero-BearAZ
Old Jun 20, 2001, 04:48 PM
rayc is offline
rayc's Avatar
Joined Jun 2000
Well I broke down and ordered one from www.crosshobbytools.com
$49.95 + 6 shipping.
Hopefully it will be a good one that will last and last. The guy I talked to was nice and very helpful in explaining the process to me.
I'll let you know if it turns out to be a good deal...
Thanks everyone,
Ray
Old Jun 21, 2001, 01:57 AM
David T is offline
Find More Posts by David T
UK
Joined Aug 2000
Some more references: http://www.proto-form.com/index2.htm http://www.crosshobbytools.com/diagrams.html http://www.flyelectric.ukgateway.net/matter.htm#vac
David T is offline Find More Posts by David T
Old Jun 28, 2001, 04:45 PM
Dsegal is offline
Find More Posts by Dsegal
Dave Segal
Philadelphia PA USA
Joined Jun 2001
The November, 1995 issue of Model Airplane News has an article on how to build a vacuum box for making small parts.
Dave Segal
Dsegal is offline Find More Posts by Dsegal
Old Jul 02, 2001, 10:19 AM
rayc is offline
rayc's Avatar
Joined Jun 2000
Here is a short review on the cross hobby's vaccum box.
I got the kit Friday nite and it went together ok.
the directions are poor. If it weren't for the 2-d and 3-d design photos I don't think I would have figured it out.
Despite this aspect the material was top notch and everything was included in the kit except for wood glue and 5-min epoxy.
I tried it out Saturday night and it works great! I never expected to get the level of satisfaction that I got out of this.
It has a great design with the hinged lid and the soft rubber connector for the vaccum.
Overall this is a great little product that I would recommend for anyone who is not sure about making a vaccum forming box.
Good luck,
Ray
Old Jul 03, 2001, 01:03 AM
Bare is offline
Canada
Joined Nov 2000
C'mon .. it's a flat box with a perfboard top, costs $6 in raw materials and takes 3/4 hour to scratchbuild..
not a decision to lose sleep over.
Anyhow glad you like it.. now try heat shrinking 'pop' bottles for even easier and much more durable parts.. dosen't do reverse curves though.. still need a Vacu box for that
Old Jul 07, 2001, 11:17 PM
AndrewM is offline
Find More Posts by AndrewM
Boca Raton, FL USA
Joined Jul 2001
http://www.studiocreations.com/howto/index.html
Check out this web site. He has a tutorial for making a vacuum form box. His is large but could easily be scaled done.
AndrewM is offline Find More Posts by AndrewM
Old Feb 28, 2008, 07:50 AM
John Barrett is offline
Find More Posts by John Barrett
Goose
Ireland, Dublin, Dublin
Joined Feb 2008
Vacuum Box
Thanks, Ray
Hi, If you look at thomanie's blog he gives a very simple and cheep way to build a very ingenious vacuum box, I built one and it works perfect. John
John Barrett is offline Find More Posts by John Barrett
Old Feb 28, 2008, 11:39 AM
lake flyer is offline
Find More Posts by lake flyer
lake flyer's Avatar
Joined Nov 2005
I have seen an article where a plastic dishpan and peg board were used to make the box.
lake flyer is offline Find More Posts by lake flyer
Old Feb 28, 2008, 11:42 AM
lake flyer's Avatar
Joined Nov 2005
A lot of our shapes can be made by the pull down over a mold method .
That is how I made the canopy for my RV6 , it was about 7"x7"x3".
Old Feb 28, 2008, 11:44 AM
lake flyer's Avatar
Joined Nov 2005
And of course there is the mold in a bottle and shrink with a heat gun method .
Old Feb 28, 2008, 11:46 AM
sperry is offline
Find More Posts by sperry
St.Petersburg, FL
Joined Feb 2004
The book Scratchbuilt! by John Alcorn has plans on P.48
sp
sperry is offline Find More Posts by sperry
How did you build your hot box? Sled Driver Composites Fabrication 24 Dec 01, 2005 12:29 PM
How to build a GWS Gear Box enigmabomb Parkflyers 12 Dec 05, 2003 12:44 PM
How To Build Foam Wing - Really Neat! hoppy Foamies (Kits) 0 Feb 17, 2002 09:35 PM
Got my Soarstar, any tips on how to build? f2racer Foamies (Kits) 2 Sep 06, 2001 11:56 PM
Anbody know how to build a prop? Pork Tornado Parkflyers 4 Aug 03, 2001 05:10 PM
