Old Mar 07, 2002, 10:08 AM
fregon45 is offline
Find More Posts by fregon45
Northern New Mexico
Joined May 2001
Electronics kit for CNC Foam cutter--Anyone interested?
Hi, I'm working on putting together a CNC foam cutter, and a few people have contacted me about helping them out with PCB's. Well after doing a lot of leg work in tracking down parts for my own setup, I got to thinking that if there are enough people interested, I could put together about 10 kits that would include basically all of the electronics needed to put together a full CNC foam cutter with wire temperature control and the works. I would ask about $60 (basically the cost of parts and PCB) plus $10 shipping, and initially I would only do a run of 10 kits.
The kit would include:
All electronics, connectors, PCB's, drill bits (you'll have to drill the board yourself) and cabling needed to build the MM2001 driver board that is used with the french CNC foam cutting software.
The kit would not include:
-4 stepper motors (about $5 each or can be salvaged from old dot matrix printers)
-Power supply--Can be salvaged from old PC
-Hot wire bow and cable
-CNC software. ($30 from the French guys)
I think that the entire cost of the project can be held to about $200 (including software, stepper motors, and bow). I am just starting on my own, and more than anything, I'd like to have other people working on the project at the same time so that we can collaborate.
The design I intend to build requires no machining of metal parts and is basically made whith particle board and high precision drawer slides. I think it would be easily do-able by anyone who can build and fly an R/C aircraft. See for yourself:
http://www.teaser.fr/~abrea/cncnet/table/ta_ag.htm
Just so that you know, I'm not officially volunteering to go through with this, but if there is enough interest I probably would. Just send me a short email if you are interested and I'll get back to you.
Nathan
P.S. The software, and documentation for the controller board can be found here:
http://gm.cnc.free.fr/index_en.html
fregon45 is offline Find More Posts by fregon45
Old Mar 07, 2002, 10:14 AM
Eddie P is offline
Find More Posts by Eddie P
Official Boat Bum
Eddie P's Avatar
United States, NV, Reno
Joined Mar 2000
Nathan-
You the man! I'll hopefully be able to jump into this w/ you soon, I'll email in a couple weeks.
Ed
Eddie P is offline Find More Posts by Eddie P
Link Links to foam cutting software for CNC wing cutter sloper steve CAD/CAM 38 Mar 20, 2014 02:01 PM
Discussion Looking for CNC foam cutter plans tomskk CAD/CAM 25 Jan 07, 2011 10:13 PM
CNC foam cutter electronics kit--anyone interested? fregon45 Foamies (Kits) 14 Jun 11, 2008 12:02 PM
WTB Power supply for CNC Foam Cutter FHHOBBIES The Builders Workshop 6 Mar 08, 2005 08:00 PM
Stepper motors for CNC foam cutter Milton Foamies (Kits) 10 Jan 29, 2005 01:49 AM
