Old Jan 01, 2005, 01:45 PM
chlee is offline
Find More Posts by chlee
chlee's Avatar
Atlanta, GA
Joined May 2000
Isthmus Models Zephyr II build thread
Hi everyone,
Despite the popularity of DLGs, I enjoy flying built-up javelin-style HLGs. A simple hi-start made from a $2 pack of #84 rubber bands, monofilament line and red streamer can take these planes up to 100-150 ft without too much setup time. Because of the lower structural requirement, these balsa gliders can be built relatively light, which in turn allows tighter circling in small, low bubbles.
Mark Miller of Isthmus Models was kind enough to send me a beta kit for this model:
http://www.isthmusmodels.com/pages/zephyr2.html
I totally dropped the ball and proceeded to build at a snail's pace. No longer!
I'm now waiting for some the wing sheeting glue to dry, so here's a build thread for everyone's viewing pleasure. Your comments and advice are welcome.
Also see this page for the Liftzone review by Paul Johnson:
http://www.rcgroups.com/links/index.php?id=4732
I'll see if I can get anywhere close to his 7.5 oz.
- Chung
Here's the kit:
chlee is offline Find More Posts by chlee
Old Jan 01, 2005, 02:16 PM
chlee is offline
chlee's Avatar
Atlanta, GA
Joined May 2000
(Approximate measurements)
Wing area: 358 sq.in.
Aspect ratio: 10
Airfoil thickness: 9.4% (modified S3014)
Equivalent dihedral angle: 12.5 degrees
Vertical tail volume: 0.017
Horizontal tail volume: 0.49
The fuselage builds in about three hours (less if you use CA throughout; I used aliphatic resin on many parts).
The fit of the lasercut parts is similar to most other lasercut kits.
When I put the fuselage sub-assemblies together, the nose block protruded slightly past the fuse sides (see below). This is of little consequence, because the nose is shaped and sanded anyway.
Old Jan 03, 2005, 09:45 PM
Mark Miller is offline
Find More Posts by Mark Miller
Mark Miller's Avatar
United States, WI, Waunakee
Joined Oct 2002
WooHoo! I love the smell of balsa shavings in the morning.
Mark
Mark Miller is offline Find More Posts by Mark Miller
Old Jan 03, 2005, 10:13 PM
spaulj is offline
Find More Posts by spaulj
In the (inclined) loop
Up North
Joined Mar 2001
Originally Posted by Mark Miller
WooHoo! I live the smell of balsa shavings in the morning.
Mark
Pillow Stuffing! For sweet dreams!
-PJ
spaulj is offline Find More Posts by spaulj
Old Jan 06, 2005, 03:45 PM
chlee is offline
chlee's Avatar
Atlanta, GA
Joined May 2000
Shaping the canopy and nose was quite satisfying. Just remove anything that doesn't look like an airplane...
Tail feathers and wing build!
The tail parts aren't sanded yet in these pictures. Mark seems to have carefully selected some hard B and C-grain balsa sticks for the tail. I tried to make the parts lighter by building them out of contest-grade wood--and found that they were ridiculously flimsy. So I chucked them, used the supplied wood, sanded/tapered the tail feathers razor thin.
Since the stabilizers are built up from sticks, you can easily adjust the tail size to your own preference.
I personally like more yaw damping, so I've built the tail with a vertical tail volume of 0.025 rather than 0.017. Obviously, if I end up with poor lateral handling qualities, I've nobody to blame but myself. I've attached the vertical stab with just a few of drops of thick CA, so that I can pull it out easily and compare it with the stock stabilizer.
Flight pictures coming up, as soon as: 1) I locate a USB cable to upload more pictures, and 2) the blasted sleet/snow/hail in Boston lets up.
Can't wait to get this thing in the air!
- Chung
Old Jan 10, 2005, 05:22 PM
chlee is offline
chlee's Avatar
Atlanta, GA
Joined May 2000
The build is finished.
Wing and tail feathers covered with 1.5 mil Doculam, fuse painted with a single coat of Minwax Polycrylic and blotted, and a small patch of 0.75 oz glass applied to the 'chin' with Polycrylic for dent-resistance.
GWS R-6P II Rx, 110 mAh NiCd battery, and HES 5.4 g servos yields an AUW of 7.8 oz. However, I still haven't hollowed out the solid balsa canopy, and this should reduce weight.
Still waiting on weather for a test flight. Stay tuned...
- Chung
Old Jan 11, 2005, 03:10 PM
Griffin is online now
Find More Posts by Griffin
WAA-08 Survivor
Griffin's Avatar
Joined May 2004
Very nice looking! This one is on the list to build. thanks for the comments and pics--looking forward to hearing about your first flights. -Steve
Griffin is online now Find More Posts by Griffin
Old Jan 11, 2005, 03:26 PM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Great job on the build! Let us know how you like it!
Old Jan 29, 2005, 04:43 PM
rand24 is offline
Find More Posts by rand24
Joined Jan 2004
well i just ordered one of these - how's it go? Mark is certainly a helpful vendor. Great stuff!
rand24 is offline Find More Posts by rand24
Old Jan 30, 2005, 06:48 PM
chlee is offline
chlee's Avatar
Atlanta, GA
Joined May 2000
rand24,
Unfortunately, I've still not had a chance to fly it between work and a huge snowstorm. Will update soon, hopefully.
-Chung
Old Jan 30, 2005, 09:58 PM
thermite is offline
Find More Posts by thermite
thermite's Avatar
London, England
Joined May 2003
Beautiful bird! nice build, I like the finish, simple and light.
thermite is offline Find More Posts by thermite
Schuebeler Vector II Build Thread Gordon Electric Ducted Fan Jet Talk 198 Jun 02, 2012 08:18 AM
Bitstream-II build thread bwanajim Electric Sailplanes 2 Dec 11, 2004 07:46 AM
Yippee! E*STAR Models 3D YAK54 build thread Happy|Harry 3D Flying 122 Sep 20, 2004 09:43 PM
FoamyFactory Pitts Challenger II Build Thread. Boss248 3D Flying 44 Aug 29, 2004 05:59 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
