Old Mar 06, 2002, 08:54 PM
Doc Watson is offline
Find More Posts by Doc Watson
Doc Watson's Avatar
UK
Joined Mar 2000
EDF thrust calculator
Anybody interested in me 'knocking up' a program which will calculate the thrust for some Wemotec fans given the cells and amp draw???
Im gunna include 2400, 1700, 1300 any others?
I'm also going to assume 1v per cell and use the equations on my site.
Any other 'bells and whistles' you guys might want??? other fans??? etc.
Doc
Doc Watson is offline Find More Posts by Doc Watson
Old Mar 06, 2002, 08:59 PM
DanSavage is offline
Find More Posts by DanSavage
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Re: EDF thrust calculator
Sure! On one condition. That it doesn't take you away from your X-35 for too long. I want to see that fly much more than I want a thrust calculator.
Dan
DanSavage is offline Find More Posts by DanSavage
Old Mar 06, 2002, 09:08 PM
Tim H. is offline
Find More Posts by Tim H.
FoamyFactory.com
Tim H.'s Avatar
USA, TX, Fort Worth
Joined Nov 2001
I would love to see The Jepe and Shuebler fans included. Then we'd have a good all around tool to use for most any application. I also second the motion that it shouldn't take too much time away from your big project. I can hardly wait to see it hover, then transition and climb away!
Tim H.
Tim H. is offline Find More Posts by Tim H.
Old Mar 06, 2002, 09:14 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
How do you correlate the number of cells, RPM, and current draw?
Cells and current isn't enough information, I think. Watts would work.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Mar 06, 2002, 09:47 PM
Mikey-flies is offline
Find More Posts by Mikey-flies
Alberta, Canada
Joined Sep 2001
If watts would work, why then wouldn't cells and current as watts = volts * amps and he has said he is going with 1 volt per cell as a simplification?
Mikey-flies is offline Find More Posts by Mikey-flies
Old Mar 06, 2002, 10:08 PM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Well to some extent that works. thatinformation is already on his site.
The problem is that you need to have the motor and battery to run your test to see what kind of current draw you will have. Then you can calculate thrust.
I have made a spreadsheet that will calculate current draw based on motor constants and cells used much like the calc programs. It also outputs thrust and velocity. It works OK but Excel has fits with certain combinations of motors and will not give results.
Greg
Old Mar 06, 2002, 10:12 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
I am not sure I understand what you mean by "calculate". The data has already been measured and is available here for a variety of motors:
www.wemotec.com
Watts (or Volts and Amps) in will give you inaccurate figures for the thrust and efflux velocity, unless you specify the motor and in particular its efficiency (as I think I already mentioned in a previous post on the same subject ).
For ducted fans the results are further affected for ex. by the use of an exit cone:
http://members.chello.at/andreas.markovic/EDFcalc.xls
Herb is offline Find More Posts by Herb
Old Mar 06, 2002, 10:29 PM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Herb, I agree. The data is already there.
Of course watts input is a problem. That is why I made my spreadsheet several years ago. It needs to be updated a bit with things that I've learned about motors and fans since I put it together. The biggest problem is adding effects from ducting. Ducting will drastically effect resulting current draws and thrust figures.
Greg
Old Mar 07, 2002, 09:43 AM
JasonJ is offline
Find More Posts by JasonJ
Dude, where's My Plane?
JasonJ's Avatar
Green Lane PA USA
Joined Mar 2001
I am all for it Doc, that would be great, forget all the graphs! .
I suppose watts in and then a field to plug the motor efficency in and then calculate the watts to the rotor, static thrust out with no duct or cone is just fine, we all know that ducting and exit cone affects thrust.
While your at it you could have a FSA and optimum cone diameter for efflux speed calc that spits out Area for 80 to 90 % FSA, figuring that out is a pain!
I should have never said "Ill never use this stuff man!!! " to my poor math teachers . If she whould have only said " you need this to build RC jets " I would have hit the books!
JasonJ is offline Find More Posts by JasonJ
Is EDF thrust that important? Question on fan thrust comparison dw1122 Electric Ducted Fan Jet Talk 60 Mar 01, 2004 11:20 AM
Easy EDF Thrust Test Stand Tim H. Electric Ducted Fan Jet Talk 16 Dec 11, 2003 04:43 PM
GWS EDF Thrust Rings? BigDave GWS (Grand Wing Servo) 4 Sep 27, 2003 04:14 PM
Lift (thrust) Calculator HankF Electric Heli Talk 0 Aug 27, 2003 04:15 PM
GWS edf Thrust with ducting Mikey-flies Electric Ducted Fan Jet Talk 1 Mar 02, 2002 05:50 PM
