Old Dec 30, 2004, 09:59 PM
Dmerino is online now
Find More Posts by Dmerino
Pollock Pines, CA
Joined Aug 2002
17.5 oz. Wing Load
Can anyone give me some advice as to what my Mig 17 will fly like with a 17.5 oz. per sq. ft. of wing loading? Any Help is most appreciative. Thanks. Dennis
Dmerino is online now Find More Posts by Dmerino
Old Dec 30, 2004, 10:01 PM
dave morris is offline
Find More Posts by dave morris
dave morris's Avatar
orlando fl
Joined Oct 2000
depends on the power loading and the total AUW
dave morris is offline Find More Posts by dave morris
Old Dec 30, 2004, 10:06 PM
Larry Dudeck is offline
Find More Posts by Larry Dudeck
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
My Kyosho T33 has a wing loading of 18.7 oz/sq.ft. Easy hand launch, flies very nice. But the T33 has a nice, flat bottom, lots-of-lift-at-low speed Clark "Y" air foil.
Larry Dudeck is offline Find More Posts by Larry Dudeck
Old Dec 30, 2004, 11:23 PM
Paranoia is offline
Find More Posts by Paranoia
Australian in the USA
Paranoia's Avatar
United States, CA, Laguna Niguel
Joined Aug 2002
Just to give you an idea.....
i have a b-25 with a 21oz loading, it runs two brushless motors at about 250watts at lunch, and i could JUST make it in to the air with a 10mhr wind!
So i install flaps, and i can lunch without a problem now everytime, it climes away at +30degrees
Paranoia is offline Find More Posts by Paranoia
Old Dec 31, 2004, 12:01 AM
Pollock Pines, CA
Joined Aug 2002
MIg 17
Thank you for all your responses. My Mig is running a Vasa fan with a 300 ballbearing motor & lipo set up (7.4 1500mah). The all up weight is 10.3 ozs. I am using a scale plan form of the wing. I am hoping that it will not fly like a rocket, but I am prepared. Peace. Dennis
Old Dec 31, 2004, 12:19 AM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Is the wing double surface or undercambered?
Eric B.
AirX is offline Find More Posts by AirX
Old Dec 31, 2004, 02:06 AM
Pollock Pines, CA
Joined Aug 2002
Mig Wing
Eric, the Mig wing is double surface. It is 1mm depron over an airfoil and rib. Dennis
Eric B.
Old Dec 31, 2004, 07:52 AM
orlando fl
Joined Oct 2000
lite wing loading, lite power loading, should fly very well, not a rocket, maiden on a low wind day. Low weight and low overall power will limit the kinetic energy so not a lot of vertical lines or zooming climbs. Can you attach a pic?
Old Dec 31, 2004, 10:33 AM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Just curious Dennis because I did not get to follow the complete construction.
Eric B.
Old Dec 31, 2004, 02:45 PM
Pollock Pines, CA
Joined Aug 2002
Thanks, Dave
Thanks for your input. I am attaching a pic of where the Mig stands at the moment. I do have a Thread in the Jet Forum of Ezone called "Mig 17 paper model to 1mm depron. Peace and have a Happy New Year. Dennis
Old Dec 31, 2004, 11:01 PM
Pollock Pines, CA
Joined Aug 2002
T33
Thanks for the info. on your T33 Larry. My wing is a complete airfoil. It is somewhat scale in cross section. I expect it to be a little on the fast side. In doing the calcs. on the wing, it shows it will have a tendency to tip stall pretty easy at slow speed. I am going to fly it with these wings, but I will be able to re-do the wings to a larger plan form if these do not work out. I won't do any detailing until I can get her flying. Peace. Dennis
Old Dec 31, 2004, 11:05 PM
Pollock Pines, CA
Joined Aug 2002
Mig 17 construction
Thanks for your input Eric. You can go into the Jets Forum and look under "Mig 17 paper to 1mm depron". This will give you more information on this build. Peace and Happy New Year. Dennis
Eric B.
Build Log 500 g/17.5 oz. dc head pusher - the Minimum JochenK Auto Gyros 372 Aug 27, 2015 10:58 PM
2.5 oz Extended Wing BUG Zhack Hand Launch 38 Apr 05, 2011 09:41 AM
Discussion Is 6.5 oz for a 60" DLG wing too heavy? screamin' eagle Hand Launch 4 Jul 16, 2006 04:13 AM
Idea 48" flying wing with 5 oz LiPo and not 12 Oz NiMH hmedina Flying Wings 2 Jan 20, 2006 09:41 PM
My 4.5 oz Depron SS replacement wing CactusJackSlade Aerial Photography 7 Feb 01, 2005 01:36 AM
