Old Dec 30, 2004, 02:04 PM
HardDrive is offline
Find More Posts by HardDrive
United States, TX, Seguin
Joined Dec 2004
SR-71 BlackBird Plans
I am looking for a good set of Detailed Plans to construct one of these babys.
I have read just about every thread on these forums I can find and I see poeple building these things but I never see any body post and real plans that shows measurments of pieces or anything like that.
I am not looking for a free run or anything "though I wont turn down free!!!"
but if anyone can either get me or point me tp some detailed Plans I would be very greatful!!!!
jrader1@GMail.com
HardDrive is offline Find More Posts by HardDrive
Old Dec 30, 2004, 02:17 PM
The Max-Q is offline
Find More Posts by The Max-Q
The Max-Q's Avatar
Mississauga, Ontario
Joined Mar 2003
Are these of help? Usually a 3-view with cross sections of the fuselage is the ticket for a rudimentary set of plans. Although it isn't very high resolution, it is good enough for balsa (IMHO.)
Good luck,
Cameron Aach
The Max-Q is offline Find More Posts by The Max-Q
Old Dec 30, 2004, 02:29 PM
Ceeray is offline
Find More Posts by Ceeray
Finland
Joined Jul 2004
hmmm.... this one calls for depron...must resist!!! AAAAAaaaarrrrggg.... (steps running away...)
Heh, seriously, this would be pretty easy to fold from depron , whichafter setting pusher motor in the rear spike...
Or two motors in nacelles..
Ceeray is offline Find More Posts by Ceeray
Old Dec 30, 2004, 08:54 PM
Joined Dec 2004
yeah thanks, this is one of the ones I have been able to find.
I was hopeing to find some cut away details that actually show measurments of individual pieces ya know......
Old Dec 31, 2004, 10:23 PM
Joined Dec 2004
anyone?
Old Jan 01, 2005, 09:08 AM
The Max-Q's Avatar
Joined Mar 2003
Hi,
Regarding the plans, you actually don't need more than the picture above to create a good scale rendition of the SR-71. I know that you asked for a set of good scale plans to make an SR-71, and I've come up with nothing in regard to actual plans-but the above 3-view with crossections is all you need if you're willing to do a little bit of designing yourself. Although the picture doesn't have dimensions, it is proportional to itself (everything is the same scale) so you could blow it up to whatever size you want.
Check out the pictures below. The excelent Sr-71 below was built from the exact same 3-view that I posted. The builder, Willmsy, enlarged the 3-view and built the fuselage and wings right over the 3-view and added in the crossections-rather shrewd design I must say! You could do the same as him with balsa, or you could do it with foam instead.
Happy New Year,
Cameron Aach
Old Jan 01, 2005, 10:19 AM
ost is offline
ost
Find More Posts by ost
ost
Germany
Hi,
look at this thread in Germany.
Michael Beck has built one with alot difficulties.
I think, he will answer any questions.
http://www.rc-network.de/cgi-bin/bei...=5;t=000287;p=
By Oliver
ost is offline Find More Posts by ost
Old Jan 02, 2005, 02:45 AM
Joined Dec 2004
Originally Posted by ost
Hi,
By Oliver
Unfortunatly I know no german....
Old Jan 02, 2005, 06:02 AM
ost is offline
ost
ost
Germany
OK, but you can ask Michael about the problems he had!
Its a model with retracts and after start the trouble begins.
Now, after long discussion and ideas the bird flies very well- there is also a video of it. (but starts only with bungee!)
http://www.rc-network.de/cgi-bin/ubb...&t=000287&p=14
The plane comes in stall very quickly(not soon!) Must be careful with flying angles, because a deltawing produce lot of resistance and the fuselage of a SR71 too!
Possible there is another guy who can read german and will help you.
Im still reading this thread and will write when there are problems.
Michaels SR 71 flies, because I and other guys had a few ideas to solve the problems
By
Oliver
By the way:
The SR 71 is not like a deltawing, you can see it as an canard-wing with fixed canards!
Old Jan 02, 2005, 02:35 PM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
There is, as of right now anyway, a free translator sevice. This allows one to translate just about any web page or block of text from one language to another. IMHO, it really helps to make this world more united. I use it all the time, it works on just about any text. It makes it easy to go from link to link and automatically translates things.
Babel Fish Translation
GregG is offline Find More Posts by GregG
Old Jan 02, 2005, 03:44 PM
Joined Dec 2004
Now that is going to be VERY usefull....Thanks a Lot!!!!
Old Feb 04, 2005, 01:40 AM
sledge29 is offline
Find More Posts by sledge29
Joined Mar 2004
jrader1@GMail.com
i just started a thread sr-71 foamy ive blown those plans up to 27" span 50"lengs useing adobe illustrator im just geting started and will try to be as thorough as i can with pictures and dimensions.. as i go
sledge29 is offline Find More Posts by sledge29
Old Feb 04, 2005, 05:05 PM
CRAZYPILOT is offline
Find More Posts by CRAZYPILOT
CRAZYPILOT's Avatar
Denmark
Joined Jul 2004
Hej harddrive
I have send you a PM.
Kenneth
CRAZYPILOT is offline Find More Posts by CRAZYPILOT
Old Feb 07, 2005, 01:08 AM
sledge29 is offline
Joined Mar 2004
here i the liknk to my thread.. i have aposted quite a few photos of my sr-71 build in progress
http://www.rcgroups.com/forums/showt...ght=sr71+foamy
Old Feb 07, 2005, 02:15 PM
CRAZYPILOT's Avatar
Denmark
Joined Jul 2004
Nice plane
Kenneth
SR 71 Blackbird daveswall Electric Plane Talk 4 Apr 28, 2014 10:13 PM
Scratch Building an SR-71 Blackbird SR-71 Pilot The Builders Workshop 18 Jul 15, 2010 09:23 PM
Discussion looking for an arf or rtf sr-71 blackbird aferguson Electric Ducted Fan Jet Talk 6 Jan 24, 2009 09:55 AM
Has there ever been a R/C SR-71 Blackbird? snowman610620 Electric Ducted Fan Jet Talk 15 Mar 08, 2005 10:01 PM
Edf-50 SR-71 Blackbird Tyson Electric Ducted Fan Jet Talk 21 Aug 11, 2002 12:07 PM
