Old Dec 30, 2004, 12:54 AM
damiens75 is offline
Find More Posts by damiens75
Sydney, Australia
Joined Dec 2004
What Lipo should I be looking for?
Hi all,
Not really sure about these Lipos. I keep reading stories of how good they are (weight saving) but then read stories of nasty accidents with them.
Currently got an E-glider that I am changing the power system which will be pulling about 40Amps. Brushed system with a gearbox (no i dont want brushless).
My charger is Lipo ready, my new ESC on its way from Aircraft World is also Lipo friendly. I am currently using 8.4V NiCad packs (1700).
So what should I be looking for in Li-po's??????
A little explanation in how they are categorised (terminology) would be helpful.
Cheers
damiens75 is offline Find More Posts by damiens75
Old Dec 30, 2004, 08:16 AM
RD Blakeslee is offline
Find More Posts by RD Blakeslee
Joined Jan 2002
One of the problems with conversions from nickel-based cells to lithium is the voltage-per-cell increment difference. Nickel are about 1.2V per cell or so nominal, whereas LiPos are 3.7.
So, your 8.4 volt requirement calls for 2 1/2 LiPos, and there ain't no such animal. If your system will work OK on either 7.4 volts or 11.1, you're in business.
Let us know.
- RD
RD Blakeslee is offline Find More Posts by RD Blakeslee
Old Dec 30, 2004, 08:57 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
He will also need a Lipo friendly LVC speed controller or a device such as the Li-Saver
http://www.rcgroups.com/forums/showthread.php?t=291387
I have flow one of my 2 meter AF Geared Cobalt 05 on 2 cell Lipos inplace of the 7-8 Sub C SCR Nicads which I have used in it for th past 15 years.
I had to limit throttle to max of 80% to keep amps below 30 and ,limit motor runs to 30 seconds to prevent over heating the Lipos. Weight reduction was major and climb out was still good. Not like with Nicads but witout any effort I managed 5 climbouts and a 20 minute flight in dead air.My guess would be that a 7 cell Nicas would have been a 8 minute flight under same conditions.
I am not a pro. glider pilot however I do have many flights over 30 minutes and a few over an hour.
Charles
Old Dec 30, 2004, 10:07 AM
hall woo is offline
Find More Posts by hall woo
Permanently Banned
San Jose Ca / RSA flyer
Joined May 2003
Best Lipo U can Buy
Tanic 2220 Mah packs, new slim size with 10 mm wide TABs, the best LIPO U can buy
hall woo is offline Find More Posts by hall woo
Old Dec 30, 2004, 12:15 PM
jbird is online now
Find More Posts by jbird
Which way is up?
Ft Myers, Fl
Joined Feb 2003
hall woo,
Is that a single tanic pack delivering 40a or two paralleled packs?
Jim
jbird is online now Find More Posts by jbird
Old Dec 30, 2004, 04:02 PM
hall woo is offline
Permanently Banned
Joined May 2003
Jim
Call Brian at 800 728 6976
He can customize a 2220 3S2P pack for 40 amp service with no problems
New Product New lipo's should be great for D/F use raido56 Foamy EDFs 5 Jun 11, 2007 09:03 AM
Discussion What Transmitters/Reciever should I be looking at? LuckyDuc Micro Helis 4 Mar 10, 2006 12:51 PM
What features should I be looking for in a charger? Yardbird Batteries and Chargers 4 Feb 16, 2005 10:36 PM
Everybody seems to be looking for a quality small fan Dr. Jet Electric Ducted Fan Jet Talk 4 Dec 01, 2001 12:34 AM
Soarstar what mods. need to be done for a succesful flight? JEWINE Foamies (Kits) 10 May 06, 2001 09:36 PM
